What did you do to your WJ today? - Page 347 - JeepForum.com
 566Likes
post #5191 of 43617 Old 09-06-2011, 10:28 AM
liquidxit2
Originally Posted by Thomahawk View Post
Rockauto have whole sale right now, half price on Radiator hoses and more.....
Ill check them out, but Im going to the stealership today as I wanna get the WJ back on the road.
Originally Posted by wsar10 View Post
Regualr HOAT coolant is NOT the correct stuff for our WJ's, IT HAS TO BE MS-9769 or as JEEP says "ANY OTHER TYPE WILL CAUSE ENGINE AND COOLING SYSTEM DAMAGE"
http://www.wjjeeps.com/service/cooling.htm#DRAIN40
Im getting my coolant from the stealership. You can also use zerex if need be, but Im going mopar for 100% peace of mind.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #5192 of 43617 Old 09-06-2011, 10:41 AM
wsar10
2003 WJ
only the zerex that IIRC is called G5 or something like that, (gold bottle)
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #5193 of 43617 Old 09-06-2011, 11:10 AM
Thomahawk
^^^this...
13qt needed for full drain/refill.
Buildthread
Thomahawk is offline
post #5194 of 43617 Old 09-06-2011, 11:21 AM
moPowered
Washed the wheels in the rain lol. They were dirty and bugging me.
moPowered is offline
post #5195 of 43617 Old 09-06-2011, 11:56 AM
2cflyr
Originally Posted by 2cflyr View Post
STARTED the redo of the rear main seal. got everything unbuttoned, the starter motor placed carefully and the bottom end stiffener taken off...only to discover that we dont own (between my tool and my dad's extensive snap-on collection) that we dont have a deep well 20mm or 13/16ths for the mains.
(we're still not convinced it's 13/16ths, but that's the shallow socket that we had that fitted. no 20mm to try either)
so, the jeep sits in the garage with no oil pan as we speak. a neighbor of my dad has the required socket, so the jeep will get completed tomorrow.
project done! no leak...for now. apparently the main seal can take a few days to swell up with oil.
notes:
20mm was still too small for the main caps. used the 13/16ths w/o issue. still would have liked to try a 21mm
RTV (in moderation) will not hold the gasket in place on the block when you're attempting to place the pan.
2cflyr is offline
post #5196 of 43617 Old 09-06-2011, 12:59 PM
liquidxit2
Yeah they gave me 2 gallons and I didnt even think about it and its the pre mixed mopar pink coolant as I planned. Guess Ill be taking another trip out there tonight for another gallon.
post #5197 of 43617 Old 09-06-2011, 04:13 PM
sherker55
I had to replace my MOPAR radiator (that they only warrenty for 12 months) a couple of weeks ago, they wanted $398 for a new one and wouldnt cover the one I just replaced 15 months ago...so I got one from pepboys for $168, and I bought prestone "ANY MAKE, ANY MODEL, ANY...etc"
I told the parts guy at stealership "why should I spend more money for a part from you that you only cover for a year, when I can buy the same part from pepboys that's got a lifetime warranty (no labor) and I can save $200..." then he said "well that stuff is junk, not mopar, blah, blah, blah"...so I said "well here I am again replacing a mopar radiator for the second time, so who's parts are junk???...and if your parts were so much better than anyone elses, then why won't you warranty them for more than 12 months...'''
F mopar, they can kiss my *** and suck my balls
Originally Posted by HaViiK View Post
Send me the number, she can take a ride in a real jeep
Originally Posted by WillMcD View Post
She said call her when your over 4"
sherker55 is offline
post #5198 of 43617 Old 09-06-2011, 04:31 PM
JRT403
More a culmination of what has happened over the past couple of weeks...but here it is:
Ended up putting a vinyl over the black section of the that I had painted with bedliner hood. Got into some mud and when I went to wash it, there were stains that would not come off of the bedliner. The vinyl has a perfect finish anyways. Also added a brush guard, wired some hellas onto it (all from craigslist pretty cheap), added a cb that my neighbor gave me and smoked the tail lights.
Charger is not mine...unfortunately
http://www.jeepforum.com/forum/f197/jrt403s-wj-build-thread-1242747/
JRT403 is offline
post #5199 of 43617 Old 09-06-2011, 06:30 PM
WJGERRY
Originally Posted by MichaelaCali89 View Post
I only know of Hollister...sorta far if your in Redding though
Hey thanks.. I did find a place up there.. and some others
Yes hollister is definitly on my list..
Im in the Bay Area too!!
WJGERRY is offline
post #5200 of 43617 Old 09-06-2011, 06:56 PM
ragyabuamra
WJ
fIXED The bloody leak in the power steering pump ... Finally
JEEP= Just Enjoy Endless Power
Forgive me jeep, I have sinned
ragyabuamra is offline
post #5201 of 43617 Old 09-06-2011, 10:43 PM
WJGERRY
Originally Posted by EisBlade View Post
I have OME's on it now plus 3/4in spackers front, rear, and MX-6's for a 4in, track bar, and tranny drop. Guess I just need to find MOABs. Thanks for all this. I don't see much more than curbs and light trail use so should be good; 3in lift tops. I'm trying to avoid trimming.
If you stick to a 31" (no bigger) tire I think you can avoid trimming
WJGERRY is offline
post #5202 of 43617 Old 09-07-2011, 12:32 AM
straty1987
came back form wildowood/cap may NJ and the jeep has new door dings due to the small spots.
also found some sick JK and some odd ones (22's n chrome out). best one was a lifted one in a handicap spot with no doors or top.
straty1987 is offline
post #5203 of 43617 Old 09-07-2011, 04:03 AM
MichaelaCali89
Can you let me know where it is? My grandparents have a ranch over there, it would give me more of a reason to go lol....you totally gotta go to Hollister! Where in the bay are you from?
MichaelaCali89 is offline
post #5204 of 43617 Old 09-07-2011, 06:48 AM
03wjtyler
ordered the ionic predator and lights for it. cant wait for it to come in
03wjtyler is offline
post #5205 of 43617 Old 09-07-2011, 10:56 AM
liquidxit2
Snapped a thermostat bolt.
Currently Active Users Viewing This Thread: 5 (3 members and 2 guests)
1999wjlimited , pkman , rdanield
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
