What did you do to your WJ today? - Page 33 - JeepForum.com
 1106Likes
post #481 of 45746 Old 10-22-2010, 09:55 PM
MissKays01WJ
Tune up! All ready for wheeling tomorrow!!! Woot woot!!!!
MissKays01WJ is offline
post #482 of 45746 Old 10-23-2010, 01:59 PM
jtcnj
Wj
Prepped my rusty oil and trans pans for Rust Reformer. I hope it lasts through the winter
Waiting for the rinse - off to dry.
AND, my lame flex pic!
"Lay Down Sally" Silverstone Metallic 2001 xj sport 4.0L/AW4/231/8.25 mostly stock.
"Dubyuh" or "Blue Bayou": Patriot Blue 2001 Up-Country WJ Limited 4.7L V8 Quadra Drive: for now known as "Al-Dente" after my wife's "mod".
New Addition 12/2011: "Pearl" Forest Green Pearlcoat 1999 xj SE 4.0L/AW4/231/8.25 mostly stock for now.
____________________________________________
I didn't agree, but hoped for Hope and Change.
I got change for myself and my family: for the worse.
This is the reality of: Barackalypse Now. Again.
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Wilson Reagan
jtcnj is offline
post #483 of 45746 Old 10-24-2010, 03:13 PM
rfjeeper
deerhunting
Took her deer hunting,saw nothing
rfjeeper is offline
post #484 of 45746 Old 10-24-2010, 06:14 PM
ARFuniN
Cleaned my IAC and layed out a silicone and aluminum tube induction system.
Ordered the following from www.siliconeintakes.com:
2 x Stainless Steel Joiner, 3.5" (JOI000380)
1 x Silicone Reducer, 3.5" to 3.25" - Blue (SIL000526)
1 x 3.5" Silicone 90 Elbow, Blue (SIL000415)
1 x 3.5" Silicone 45 Elbow, Blue (SIL000407)
1 x 2' Straight Aluminum Pipe, 3.5" (SIL000758)
5 x Stainless Steel 3.5" Worm Gear Clamp (72-95mm) (CLA001046)
2 x 3.5" Pump Mounting Kit (CLA000717)
Ordered a K&N RF-1045 Filter from Summit Racing...
Will fab the cold air box out of annealed aluminum sheet and bulb seal and duct the left most grill circuit into the box.
ARFuniN is offline
post #485 of 45746 Old 10-25-2010, 09:34 AM
wj_jeep92
looked at it and hoped im not gonna look stupid with my 245/70/16 generals on a 2.5 lift. any thoughts on this matter
1998 ZJ 5.9L
wj_jeep92 is offline
post #486 of 45746 Old 10-25-2010, 03:35 PM
straty1987
a freind had a 2.75 lift on the stock 16' and made the lift look bigger since the tiers were smaller.
but you tiers are at 29.5 now so going to 31 will look a bit better
straty1987 is offline
post #487 of 45746 Old 10-25-2010, 03:36 PM
straty1987
how much did this all cost?
can get a used K&N setup for like $150
or spend $40 max on PVC from homedepo
post #488 of 45746 Old 10-25-2010, 06:01 PM Thread Starter
SplitNail
Cut the **** out of my finger while at work I have pictures.... by request.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #489 of 45746 Old 10-25-2010, 07:18 PM
bayer
pics hahahahahhaha
bayer is offline
post #490 of 45746 Old 10-25-2010, 07:32 PM
myjeeplovesmud
well where do i begin?
yesterday i developed a horrible vibe, so today, i got my tires balanced. No luck.
so i got an alignment. my jeep was way out of wack, but still, no luck.
blew my front u joint, and found metal on my full plug on the front diff......GREAT!!!
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
November 2010 GCOTM
myjeeplovesmud is offline
post #491 of 45746 Old 10-25-2010, 07:37 PM
Steve01WJ
2005 WK
Replaced the 2 gromets and fittings on the valve cover.....Went very easy. The rear was leaking bad and I have oil all over the starter now. Going to try some simple green and hope that is where it was coming from!
12 JKU, 2.5TF BB, MTR 35s on 15"procomps
05 WK 5.7 Limited QD2
Steve01WJ is offline
post #492 of 45746 Old 10-25-2010, 08:14 PM
sherker55
did some parts reaearch to try to figure out what I am going to do about all this damn clunking and knocking since I lifted her...already got rear a-arm ball joint, and I am thinking spacer as well. In the front I am going to replace all my oem bushings since they are original and I got 98k on my 04. I also looked into KOR's Hard-KOR SUPER-hard Rockwell Durometer (60d) bushings to replace the ones that come with the jks adj TB...which I think are warped or misshaped, causing the majority of the clunking because of play in the TB due to not being able to keep the damn nut tight! (rant over) Hopefully that should tighten and quiet things...if not, then on to control arms I suppose...
sherker55 is offline
post #493 of 45746 Old 10-25-2010, 08:38 PM
ARFuniN
~$160 in parts so far, sheet metal and bulb seal to follow...but no body else will have one like it and it will be good to 400 F!
ARFuniN is offline
post #494 of 45746 Old 10-25-2010, 08:39 PM
mrJ
2002 KJ Liberty
installed the yakima loadwarrior i got on CL, as well as got the stud mount so i could install my new 3' firestik II. picked up flush and new fluid to do rad tomorrow, and maybe starting on tailgate light. (at least get the wiring run)
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #495 of 45746 Old 10-25-2010, 08:43 PM
straty1987
ok, have fun and post how it comes out.
wj
mak_v8
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
