What did you do to your WJ today? - Page 31 - JeepForum.com
 596Likes
post #451 of 43838 Old 10-14-2010, 08:26 PM
JerzeyBoyWJ
2003 WJ
Originally Posted by Scibbyz99WJ View Post
$75 !!!!!!!!!
he wouldnt happen to have another set would he???
haha sorry they were from a guy that had a freedom ed.
i saw him at WAWA and noticed he didnt have the side rails on so i asked him if he still had them and offered him 175
and he called me last week saying he will be back down where i live and i only have to pay 75
i couldn't complain at all
JerzeyBoyWJ is offline
post #452 of 43838 Old 10-14-2010, 08:30 PM
JerzeyBoyWJ
2003 WJ
Originally Posted by splitnail View Post
I love you color!!! It looks SO SICK!
thanks split..
took me awhile to find a gray wj for my first car but im glad i did!
post #453 of 43838 Old 10-14-2010, 08:47 PM
JerzeyBoyWJ
2003 WJ
Originally Posted by GFoster View Post
I used 10' uni-strut from Home Depot, cut it into 2.5 pieces, notched out the center of the last two holes to make it longer for the nuts/bolts to slide, painted them. I used 1/2" spring nuts to go into the existing channels, washers and bolts to cinch it all down. I used the same method to make my light rack several months ago. At some point I'll make a center piece so the tire rests on two bars instead of three or weld a sheet of metal diamond mesh between the two bars and make sides for additional storage rack capabilities.
how much did the unistrut cost you ?
i wanna take my lights off my factory roof rails because there not as sturdy and the rail has a slight curve to it
post #454 of 43838 Old 10-14-2010, 11:16 PM
mrjaydeeone
2007 WK
painted the bezels on my fog lights
Current 2007 WK Graystone Pearl V8 4.7 limited fully loaded. Current mods Escort 9500 IX tapped into rearview mirror and mounted under mirror with bicycle reflector bracket. 6K HIDs in Lows and 3K HIDs in Fogs
mrjaydeeone is offline
post #455 of 43838 Old 10-15-2010, 07:07 AM
waza123
Wj Radio
Replaced original radio with my Alpine CDE-114BTi
waza123 is offline
post #456 of 43838 Old 10-15-2010, 11:35 AM
GFoster
Wj Unistrut Light Rack/Tire Mount
The strut cost 15 dollars for a 10 foot piece at Home Depot. I cut the width to the lip of the roof and the door frame. I got two pieces out of it with about 3 feet left, I can use that somewhere I'm sure. I used the same strut method for the tire mount.
Here are some full view pics.
2" BB * Skyjacker Nitro 8000 Shocks * 245/75/16 BFG MT
GFoster is offline
post #457 of 43838 Old 10-15-2010, 11:41 AM
GFoster
Wj Window Decals Installed
Finally got my rear window done up.
GFoster is offline
post #458 of 43838 Old 10-15-2010, 06:12 PM
ARFuniN
Got my IRO front bar pin eliminator brackets installed.
Started to scope out the areas for the ZJ washer bottle installation. In the aft location I do not see how people keep the bottle from riding the brake lines and fluid level connector at the master cylinder reservoir. Front location requires getting rid of the factory cold air box. May end up with two smaller bottles, front in the front and rear in the rear. Did find that some of the wire harness plastic cladding is brittle, and crumbles if you rub up against it. Gotta love the effects of the summer heat.
Last edited by ARFuniN; 10-15-2010 at 06:13 PM. Reason: deleted bad attempt at including an image
ARFuniN is offline
post #459 of 43838 Old 10-16-2010, 10:28 AM
sicWJofNWA
On a 200 mile road trip to pick up a 242hd w/ SYE and the matching rear drive shaft. Thanks to the aussie locker I spun a bearing in 247. It's crazy cause I had I rebuilt under warranty less than 3000 miles ago. I'm super stoked to have 2WD!! Now all I need are some sliders. (and long arms and 35's!)
sicWJofNWA is offline
post #460 of 43838 Old 10-16-2010, 12:55 PM
ARFuniN
Question
Just curious...who's SYE is on the 242HD you mention above?
ARFuniN is offline
post #461 of 43838 Old 10-16-2010, 07:50 PM
TJSWJ
drove my jeep to go buy another wj. Just bought a 01 GC limited with 95k miles and factory tow package for 1000 bucks. All because the owner didnt know why it wouldnt steer correctly. He should have looked at the track bar bolt!
TJSWJ is offline
post #462 of 43838 Old 10-17-2010, 08:50 PM
sicWJofNWA
sadly i was mistaken when i read the craigslist add for the TC. is said new SY, i thought that he forgot to put the E in there so no SYE but... i installed it today by myself and it took me like 5.5 hours to do. the biggest PITA that i ran into was when i got to the point in the FAQ where it says to lower the cross member 2 inches. i got stuck there and then i said screw it and braced the tranny and pulled the cross member and the tranny bushing and after that it was easy. i am so glad i never have to buy another bottle of mopar gold (NV247 fluid). did my first burnout in the wj after i was done. I'm lovin it. also the Aussie locker seems to really appreciate the decreased strain by having something other than 4FT or 4LO to run in. after that was done i went to oreilys and grabbed a new water pump and the wrench to pull the fan. tried to get a tstat but they were out. thats tomorrows project depending what time i get off work.
can anyone say yay or nay as to weather i should install a transgo shift kit in the dub j? i ran across a post earlier on NAGCA that has a write up. just wanted to see if anyone had one and would recommend it. I'm gonna be changing my filters soon so it would be the perfect time to do it.
post #463 of 43838 Old 10-17-2010, 10:53 PM
ARFuniN
Congrats on the install. You will love 2WD the more you get to play with it.
ARFuniN is offline
post #464 of 43838 Old 10-17-2010, 11:33 PM
sicWJofNWA
thanks dude. yeah its a mod Ive been looking forward to for the past six months. the hardest part of the whole thing was the time it took to actually find the TC i needed. some places online are retarded on their pricing.
post #465 of 43838 Old 10-17-2010, 11:37 PM
GraKee99
Rapist Wit
GraKee99's Avatar
The 45RFE is a great transmission. I wouldn't unless you are having problems with it. I have 189K on the clock and it still shift fine.
Rocktoberfest is almost here.
Brian
WJ, WK, CJ5
GraKee99 is offline
Brill
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 11 02-09-2017 05:03 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
