What did you do to your WJ today? - Page 251 - JeepForum.com
 1086Likes
post #3751 of 45718 Old 06-25-2011, 06:29 PM
MadMonk
Changed the oil and filter yesterday (I went with Mobil1 0w-30 this time) and changed out the fuel filter/regulator earlier today (151,180 miles on it). Wasn't too bad once you figured out how the connectors worked. My rough-ish idle has disappeared.
'99 WJ Limited 4x4, 4.0L, Patriot Blue Metallic, IRO 3" springs, track bar, and rear sway bar links, Doetsch Tech 8000 shocks, Tenneco steering stabilizer, Carolina Driveline double-cardan front drive shaft.
MadMonk is offline
post #3752 of 45718 Old 06-25-2011, 07:23 PM
Woods0319
2003 WJ
Replace the front bearings and bled the breaks today. I'm blown away by how easy it was for the bearings. No pressing or packing grease. Just unbolt and bolt. Flippin sweet! Rides super sweet now. 
Travis Woods
2003 WJ, 4.7, 6" Clayton Long Arm, Magnaflow, Superchips PP, homemade intake, the rest...inw
Woods0319 is offline
post #3753 of 45718 Old 06-25-2011, 07:40 PM
4x4Jeep
Originally Posted by Dewey09 View Post
Rough Country 4" lift?
Spacers?
Tires? 265?
Low miles...need suggestions
daily driver?
full time off-road vehicle?
Build -
SOLD
4x4Jeep is offline
post #3754 of 45718 Old 06-25-2011, 08:40 PM
snobrdrkid07
Was that 0w-30 and not 10w-30? Why so not think? Can't think of a word? Water like. Haha
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #3755 of 45718 Old 06-25-2011, 09:18 PM
ARFuniN
Spent the afternoon purging the AC system. 30 minutes of vacuum + 15 minutes leak detect + 20 minutes vacuum followed by the fill and oil. Final pressures after 24 oz. R134a and 2 oz compressor oil was 55 psi/Low Pressure and 260 psi/High Pressure @ 107 deg F today in Tucson. Should be 45 psi/Low Pressure and 300-370 psi/High Pressure @ 110 deg F per the FSM. 'Pressure Diagnosis' says the compressor is to blame. All I need to do is get through the next 3 months and then the windows alone will do it till next summer.
One Nation,under God, indivisible, with Liberty and Justice for ALL.
ARFuniN is offline
post #3756 of 45718 Old 06-25-2011, 09:32 PM
PRNDL
Started getting the "TIRE SENSOR BAD/MISSING" message on my EVIC today. Still getting pressure readings from all 4 tires (only a 4-tire system). Probably need to replace all the sensors.
Replaced the front rotors and calipers today. Found a lot more rust than I expected on the axle tubes/knuckles. I hope its just normal surface rust. We shall see.
Gavin
'04 WJ Special Edition | 95k miles | 4.0L | Auto | NV247 | bone stock
Still a game for America, this baseball. - Ernie Harwell
PRNDL is offline
post #3757 of 45718 Old 06-25-2011, 09:40 PM
xJoshxx
2012 WK
Did you use a Vacuum gauge? like micron rating?
Yellow Jacket 8CFM Vacuum pump.
Oldman does commercial heating and air so eh. actually your supposed to compensate 2 ounces for the hoses. so more like 26 ounces but eh.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3758 of 45718 Old 06-25-2011, 10:41 PM
ARFuniN
No gauge used during the vacuum session. The Harbor Freight vacuum pump I bought advertises 75 Micron. I had thought about a gauge but did not want to set myself up for disappointment in the event the pump did not work as advertised.
That is a good looking pump you show in your response. Good to have connections...:-)...!
ARFuniN is offline
post #3759 of 45718 Old 06-25-2011, 10:45 PM
xJoshxx
2012 WK
Anything under 1000 Micron is a keeper. that one is 8CFM it pulled it to 450micron in under 20minutes
that's an $900 yellow jacket 2 stage 8 cfm pump lol.
Tip the louder the Vacuum pump is the less vacuum it has, they get quiet the LARGER the vacuum their pulling
So leave her run blindly for 20-30 minutes close your gauges not to lose to much vacuum, attach your r134a purge the hose to the gauges then let open you gauges weigh out what you need, IF you have to start the jeep Close the High side it will be a higher pressure than the jug and you will be feeding the jug... after your done close the gauges and disconnect your good.
2011 WK2 ORA2 sold
xJoshxx is offline
post #3760 of 45718 Old 06-26-2011, 07:00 AM
Dewey09
Eh....typical New Englander looking to go off roading here and there but yea will be driving on the streets as well
Dewey09 is offline
post #3761 of 45718 Old 06-26-2011, 10:24 AM
MadMonk
It was 0w-30 (zero dubya thirty). Protects as well as any 30-grade oil when warmed up, but flows better at engine startup.
MadMonk is offline
post #3762 of 45718 Old 06-26-2011, 11:24 AM
snobrdrkid07
oh okay, makes start up easier? any other gains?
-Michael-
post #3763 of 45718 Old 06-26-2011, 12:00 PM
MadMonk
Mostly, less wear on start up. Some say better fuel economy (not sure I believe that one or not). Its actually marketed as a "fuel economy oil".
http://www.mobiloil.com/usa-english/motoroil/oils/mobil_1_0w-30.aspx
I decided to change to this grade of oil after reading this article.
http://www.bobistheoilguy.com/motor-oil-101/
MadMonk is offline
post #3764 of 45718 Old 06-26-2011, 05:55 PM
justn
Drove my WJ back from Pismo Beach / Oceano Dunes last night, and got her almost all cleaned up today. Still have to do some cleaning underneath to get off the some pesky sand that the car wash didn't get. I had a great time, and was on the beach and back in the dunes every day of the week. Needless to say, having a WJ is pretty darn awesome!
I also had my dad take a few videos of me having some fun, so here they are!
Playing around in the river:
Doing a little climbing in the dunes:
justn is offline
post #3765 of 45718 Old 06-26-2011, 06:30 PM
xJoshxx
2012 WK
Do you like your A/C? If so i'd be lifting it because your condenser is where you hit.
2011 WK2 ORA2 sold
xJoshxx is offline
wj
Redjeepwj , Soem0
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
