What did you do to your WJ today? - Page 23 - JeepForum.com
 1093Likes
post #331 of 45728 Old 09-19-2010, 10:27 PM
jrfrank1111
I bought my second GC last week and took it to the dealer to have the heated seats looked at along with the HVAC. Came back with nearly $2000 to repair. I forgot how bad these things are made. lol...So I made the smart choice and orderd my 4" RCX lift and 33" duratracs on 16" MB chaos 5's.(hope I can get them to fit) I dont think that will fix the AC or the heated seats, but I already feel better.....
jrfrank1111 is offline
post #332 of 45728 Old 09-19-2010, 10:52 PM
straty1987
true jeep repairs on hold for lift and tiers
the heater seat and blend door is simple fix that you can do yourself
if it is the blend door can get a $200 kit that you install threw the glove box and takes about 45 min. and get to keep dual control. this is my write up on it http://www.jeepforum.com/forum/f13/d...p-pics-884932/
for the heated seat can just solder the broken line and get to keep the stronger heater seats. also here is a write on on repairing the element Heated Seat Repair Procedure - JeepsUnlimited.com Forums
and here is the new recall but if you scroll down it shows you how to properly pull back the leather, you don't have to take the see out of the jeep to do it http://www.wjjeeps.com/tsb/recall_J14.pdf
can i ask why you bough it and then took it to a shop for a quote?
good luck and welcome
straty1987 is offline
post #333 of 45728 Old 09-20-2010, 06:33 AM
jrfrank1111
Wj
I bought it first cause it was a '02 GC Overland w/ 90k for $6800. It runs solid and tranny works good. I just forgot how bad all the acc are made in these things. I figured most of these things would be broken or will break anyways
post #334 of 45728 Old 09-20-2010, 07:11 AM
compcrasher86
Congratulations and welcome to the forums! You have a top of the line WJ there and with low miles too! Post up some pictures for everyone to drool at and dont worry about the a.c.c. its bound to happen and easy to fix for about $200. If you want to take apart the whole dash its cheaper and theres an even better solution but $200 will get you a kit to do it right through the glovebox (look right above your post )
Matt
compcrasher86 is offline
post #335 of 45728 Old 09-20-2010, 09:27 AM
kadetklapp
1997 XJ Cherokee
Changed fluid in front and rear diffs, changed oil and filter, serviced transmission, installed new wiper blades and greased the front end. Oh, and washed it finally. It was filthy.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #336 of 45728 Old 09-20-2010, 09:44 AM
GhostKnife
Gave it a mud bath goin through some mud because i got to work early lol
13 Ram Cummins, PPEI Tuned and Full Carli/Thuren. JK Arctic Edition 2dr Winter Chill
GhostKnife is offline
post #337 of 45728 Old 09-23-2010, 07:47 AM
RedlegWJ
Went over to Cascade 4WD last night and picked up some teraflex bushings and a flexjoint to build up my new a-member using DOM tube. Got the next 4 days off, so hope to make some headway. Salmon should be in the river though, so some of it will depend on how soon I get my limit. Also just ordered rear calipers and lines from Napa to pick up this afternoon. Prepping for the 44a swap-in.
RedlegWJ is offline
post #338 of 45728 Old 09-23-2010, 07:57 AM
K10roc
that bushing kit is that for your front suspension? if so, how much was it and where cna i track that down?
Joe K.
"if you can buy it, you can build it BETTER"!
2000 Jeep grand WJ limited, 245/75/16, Thrust 2 chamber muffler, 2in bb, rough country shocks, slotted and drilled rotors, Torqflo trans cooler, powder coated calipers, custom made CAI, K&N cone filter, ported and polished throttle body, Chip, Torqflo trans cooler, 6000k HID, PIAA fog, lots of powder coating and blacked out parts
K10roc is offline
post #339 of 45728 Old 09-23-2010, 08:44 AM
RedlegWJ
I am building long arms. These bushings are teraflex and used with DOM tube sleave to weld to the ends of the arms. The other ends are getting Currie Johnny Joints. None of this works with factory arms. If you are looking at building arms, the bushings run about $10-$11 each, check Teraflex.com The J Joints run $45 or so plus another $12 for the threaded insert and locknut.
RedlegWJ is offline
post #340 of 45728 Old 09-23-2010, 08:47 AM
compcrasher86
Bought a set of these guys so I dont have to mess with the blown tweeters:
Matt
post #341 of 45728 Old 09-23-2010, 09:00 AM
K10roc
nice thanks bud! just looking at getting my jeep back dialed in... basicly going to redo the entire underside of my truck this weekend with all new brake rotors (drilled and slotted), pads, rebuilt calipers (freshly powdercoated), new tie rods, new u joints, front pass wheel bearing, and figured i would do bushings if i could at the same time.
Joe K.
K10roc is offline
post #342 of 45728 Old 09-23-2010, 09:08 AM
RedlegWJ
If you have trouble finding any, the front, upper axle bushings should be standard for D30, except the metal insert would be specific to your bolt and have to be reused. Bolt and holes on control arms are specificto wj too. Might be easier just to buy replacement control arms and not worry about wasting all the time pressing bushings. You can get aftermarket, tube control arms with urethayne bushings at stock length, if that intrests you. Should last longer than oem. I'd get adjustable lowers at least, if you plan 3"-4" inches of lift in the future. Also check the bolt holes on the body side control arm mounts and make sure the bolts still fit tight.
RedlegWJ is offline
post #343 of 45728 Old 09-23-2010, 09:26 AM
K10roc
NICE! where can i track them down? any idea on costs? this sucker is going to break me!
Joe K.
K10roc is offline
post #344 of 45728 Old 09-23-2010, 10:03 AM
RedlegWJ
Couple places to start, teraflex, ironrockoffroad. Check classifieds for used.
RedlegWJ is offline
post #345 of 45728 Old 09-23-2010, 05:41 PM
jrfrank1111
Wj Oh god I think I did a bad thing....triggers have been pulled.
So I re-installed new seat heaters myself and the HVAC is still kinda works. Then I went from 0-60 in one week. See pics to explain....I I can get them to attach
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
