What did you do to your WJ today? - Page 2116 - JeepForum.com
 826Likes
post #31726 of 45002 Old 09-03-2014, 10:27 PM
wjidaho
Originally Posted by afearlesshunter
Got DW....
Happens to us all ;-) now to fix it check your track bar, your ball joints, your tie rod ends, make sure your tires are balanced.. Pretty much check your whole front end... Get back to us with what you find and have fun it's a jeep!! :-D
My build thread
wjidaho is offline
post #31727 of 45002 Old 09-04-2014, 03:16 AM
SierraRipper
Broken axle
SierraRipper is offline
post #31728 of 45002 Old 09-04-2014, 08:01 AM
Hierotochan
RTV'd my PCVs:
Also did the LED bonnet light strips:
50% ideas, 50% guesswork. 100% winging it!
Hierotochan is offline
post #31729 of 45002 Old 09-04-2014, 12:23 PM
Spyder328
Put my JGCJeeps dash speakers in today, no more buzzing
2000 WJ Laredo, 255/70R16, 2.5" front and 2" rear BB, 1.25" wheel spacers
Spyder328 is offline
post #31730 of 45002 Old 09-04-2014, 12:47 PM
Beagle751
Just refreshed the gas tank with flat black looks good as new. Also picked up a new fuel filter "Wix" WJ has a 117k think it's about time after reading some posts here and getting close to posting pics
Beagle751 is offline
post #31731 of 45002 Old 09-04-2014, 01:43 PM
Zacedward
Do they sound pretty good
UJC #181 2004 jeep Grand Cherokee 4.7L v8, 2"bb, kolak 3 " exhaust flowmaster 50 SUV , Rola roof basket, k&n cai,245/75 /16 A/T
Zacedward is offline
post #31732 of 45002 Old 09-04-2014, 02:30 PM
4x4Jeep
removed my brush guard/lights and bumper cover, painted the bumper and radiator support black...because i'm having a tube winch bumper built. also painting my long arms black cause p.o. had them yellow
Build -
SOLD
4x4Jeep is offline
post #31733 of 45002 Old 09-04-2014, 06:40 PM
Spyder328
Yeah, I think they sound pretty darn good
post #31734 of 45002 Old 09-04-2014, 06:44 PM
ace4usmc
Replaced the CV shaft that had recently sprung a leak an was slinging grease every where. It's so much easier to remove the hub when you have the right tool i.e. a slide hammer.
ace4usmc is offline
post #31735 of 45002 Old 09-04-2014, 06:53 PM
Jaketit
Originally Posted by StrokedWJ
Spent a little time over the long weekend doing odds and ends. Replaced the hood struts and passenger window motor/regulator. Neither of those have worked for probably 10 years LOL. I also finally painted over the cladding. I cleaned with dish soap, and Krud Kutter, lightly sanded, sprayed plastic primer on the cladding, and Rustoleum bed liner from the spray can. I like the way it came out...just hope it lasts.
Looks better as it ages in my opinion. More salted.
Jaketit is offline
post #31736 of 45002 Old 09-04-2014, 07:13 PM
Zacedward
I am going to have to get me some you just got them from the website
post #31737 of 45002 Old 09-05-2014, 07:48 AM
WJ02FNG
Freaked out cause my WJ was overheating. Since I have read about the radiator fan relays going bad- I replaced it and it worked perfect. Thank you all on jeep forum!
2002 Jeep Grand Cherokee 4.0L, 4x4, Selec-Trac TC, Auto Transmission
K&N drop-in air filter, B&M Supercooler Transmission Cooler, Rusty's Off Road Front Tow Hooks, Mopar Hitch. Iron Rock Off Road 3 inch lift.
WJ02FNG is offline
post #31738 of 45002 Old 09-05-2014, 08:19 AM
alfaitalia
Originally Posted by EmeraldGreenXJ View Post
Replaced tail lights and used it to pull a rim off a junk xj
Amazing.....you would not think a tail light would be strong enough to do that!!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #31739 of 45002 Old 09-05-2014, 09:23 AM
derekmac
Ordered a Viair kit, coiled hose, and a couple of odds and ends for the install. I'd rather run the power cable on the passenger side, but can't seem to find a grommet to run it through.
I'm running 4 gauge to a fused distribution block in the back, as I plan on adding a power inverter down the road, and doing this will save me from having to run a separate power wire for the inverter. If I have to drill a hole in the firewall, that's ok (as long as I can get my drill in), but looking in the footwell area, I'm not sure where I should drill.
Anyone else run power wire down the passenger side instead of the drivers?
2005 TJ Rubicon
derekmac is offline
post #31740 of 45002 Old 09-05-2014, 10:08 AM
alfaitalia
I did. Found a grommet on the firewall about six inches from the inner fender and about the height of the glovebox. The cable that powers my 1000w inverter (that lives under the steering column) goes through it along with the relay trigger wire for my roof lights. Ok, Im right hand drive but nearly everthing else is just mirrored so worth a look.
wj
