What did you do to your WJ today? - Page 2107 - JeepForum.com
 913Likes
post #31591 of 45332 Old 08-26-2014, 09:00 PM
jetrinka
Mounted a set of Duratracs and aligned it.
jetrinka is offline
post #31592 of 45332 Old 08-26-2014, 10:20 PM
gcjeeping
gcjeeping's Avatar
From the Rubicon. 1st jeep is me.
Some of the guys that left early ran into this in Tahoe. But we didnt get any of it camping in the Rubicon.
_____________
gcjeeping is offline
post #31593 of 45332 Old 08-27-2014, 03:55 AM
Jer-Bear
Did some plastidip stuff.... I think it turned out good! Greased all the tie rod ends and bushings up front.
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #31594 of 45332 Old 08-27-2014, 04:48 AM
derekmac
^I like that!
2005 TJ Rubicon
derekmac is offline
post #31595 of 45332 Old 08-27-2014, 05:38 AM
pat85
Attachment 1568482
I was thinking about this idea just a couple of days ago. Thought "Ya know, everybody does the rally style stripe in the hood humps. No one does the lower portions of the hood. I should give that a shot" I should have gone for it. Damn you... Looks good though. Glad to see something different.
If it works, it works...do it for you.
His: 01 WJ Storm Trooper
Hers: 14 FDII Patriot
Sold: 98 ZJ
pat85 is offline
post #31596 of 45332 Old 08-27-2014, 05:40 AM
ezbreezy
Originally Posted by bugeyez View Post
I've had this one bookmarked for awhile, seems like a steal compared to ones I've seen elsewhere, even ebay:
http://www.truckgeardirect.com/?ITEMID=WJ-801
Will be where I go to source one...
So cheap looks like a scam
ezbreezy is offline
post #31597 of 45332 Old 08-27-2014, 07:07 AM
Jer-Bear
That was actually my reasoning. I like to do all of my stuff different and unique. Most of my stuff is bright and different from what everyone else does. Like my engine bay lol. Thanks!! I like it was well. Turned out good.
Jer-Bear is offline
post #31598 of 45332 Old 08-27-2014, 07:37 AM
Locutus
2014 WK
just ordered a Kolak exaust
If it ain't broke, fix it till it is
Locutus is offline
post #31599 of 45332 Old 08-27-2014, 08:44 AM
Jayybirdd
I've had this one bookmarked for awhile, seems like a steal compared to ones I've seen elsewhere, even ebay: http://www.truckgeardirect.com/?ITEMID=WJ-801 Will be where I go to source one...
This is a steal! Looks good. Only thing is getting the relocated kit
Jayybirdd is offline
post #31600 of 45332 Old 08-27-2014, 08:46 AM
4x4Jeep
bought a new $600 winch for $350!
Build -
SOLD
4x4Jeep is offline
post #31601 of 45332 Old 08-27-2014, 09:33 AM
jager66
New front brake discs (Brembo), pads (EBC) and a fluid change all make for a massive improvement in stopping power.
Also changed all 4 shocks. Only put on cheap Sensen ones, but that made a huge difference too. The old ones had over 150k miles under their belt and one was rattling too!
jager66 is offline
post #31602 of 45332 Old 08-27-2014, 09:39 AM
jager66
Steam cleaned the combustion chambers by sucking a slow trickle of water (over a litre) through a vacuum hose.
Have been getting injector codes and mil light for a long time and now its off and no more codes- yet.
Always thought it was a fuel problem as I run on LPG.
Runs smoothly too. Not that it was bad before.
jager66 is offline
post #31603 of 45332 Old 08-27-2014, 12:15 PM
wjidaho
Originally Posted by gtg413i
Check out my build and my thread "opinions going from 30.5" to 32" tires" for some ideas and info on the spring retainer. You need a lower one too. When you go to 6.5" then you'll want lockers, then bigger gears, then 35" tires, sye, then new axles. It will never end. If you get the rock crawling bug and funds are tight, think about buying a yj or xj that you can bash and keep the wj for scenic trips. If funds are no problem, put some Ecgs Dana 60's, 37" tires an exocage, 242hd, then watch the wranglers try to keep up with you.
Will check it out, as far as going bigger then 33s, I don't think I will, and as far as a rock rig, been looking at a couple "built" Xjs for bashing, I will be keeping the Wj for the wife if I go this route, otherwise I will build it for me lol
My build thread
wjidaho is offline
post #31604 of 45332 Old 08-27-2014, 05:07 PM
trevord1
hay does anybody wanna tell me how to build a beefy frame side track bar mount i ripped mine off?
2004 wj freedon edition long arm lift on super swampers!
trevord1 is offline
post #31605 of 45332 Old 08-27-2014, 08:07 PM
jeepfvr
03 Overland rails and gauges onto my 99 limited and tinted front windows.
jeepfvr is offline
wj
Sociopath
