What did you do to your WJ today? - Page 2097 - JeepForum.com
 827Likes
post #31441 of 45008 Old 08-17-2014, 04:37 PM
Jaketit
Originally Posted by Ben_dover4dover
did some tweeking on the alignment and took her out for test drive then boom my wheel goes flying half a mile down the street. new rotor and snapped all the lugs off, snapped the ends of the bolts that hold the hub on, and hollowed out the stud holes so i had to get a whole new hub bearing after replacing it 5000 miles ago. yay! went to the junk yard, WJs galore! grabbed a couple new bolts and a new fender for $40. cant beat that! the best part, none of the WJs were wrecked, just all V8s haha. all of them had pretty straight panels. remember everyone make sure the lugs are tightened down!
CRAZY!! I recently seen a grand on the side of the road with the same issue. Rear though. That musta been sketchy.
Jaketit is offline
post #31442 of 45008 Old 08-17-2014, 05:53 PM
trevord1
Originally Posted by wvracer821 View Post
any more pics of that bumper and how it ties in to the unibody?
front or rear?
2004 wj freedon edition long arm lift on super swampers!
trevord1 is offline
post #31443 of 45008 Old 08-17-2014, 05:59 PM
trevord1
more pics of wheeler lake a lot of fun good routes for everyone!
10396974_10204614005060079_3498374634357408715_o.jpg   10446236_10204614004820073_6368913400259130753_o.jpg   10495048_10204614006980127_4462289800762473104_o.jpg   10530539_10204614003580042_7182661735717620009_o.jpg   10547942_10204613985099580_5161208494297924152_o.jpg
10560586_10204613983099530_5010048463580604215_o.jpg   10571921_10204613988739671_136859330725372075_o.jpg   10623529_10204613983899550_8287179991182895424_o.jpg   10547893_10204614007780147_2547102939121160357_o.jpg   10535572_10204613977859399_6475296795365879033_o.jpg
trevord1 is offline
post #31444 of 45008 Old 08-17-2014, 09:28 PM
Ben_dover4dover
it definitely was not a fun trip! there was some awful grinding then i clunked to the ground and my wheel was taking off.
completely ruined the barrel, stud and hub holes of the wheel, but luckily I had a spare and get the wheels at wholesale.
after realizing i snapped the hub bearing bolts i paid a visit to the junk yard. WJs galore. got the bolts and a straight fender for $40. pretty good trip for me
I have a Jeep. There are things done to it
Ben_dover4dover is offline
post #31445 of 45008 Old 08-17-2014, 10:39 PM
Hack
2003 WJ
That trail is on my to do list. Looks like fun!
I rented this
So I could FINALLY install this
and go from this
back to
Nearly ends my maintenance marathon.
Rear bearings and seals
Front crank seal
Harmonic balancer
Serpentine belt
Upper and lower rad hoses
Plugs
Clean throttle body
pcv valve
Flush PS fluid
Flush brake fluid
Flush coolant
Fix cruise control
Fix evap code
Grease and inspect suspension joints
Couple more things to do, but I finally drove it today for the first time in nearly a month.
Hack is offline
post #31446 of 45008 Old 08-17-2014, 11:18 PM
SirSilvia
took a pic at work. then google decided to go all hipstagram on it when it backed it up. looks good though
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline
post #31447 of 45008 Old 08-18-2014, 08:18 AM
jfaulk
Not today, but yesterday. Got underneath and checked my ABS sensor connection that I fixed the other day. Just wanted to give it a once over again. Also, cleaned the seats with some Meguiars(sp?) and cleaned/polished the headlights again. I had to really sand em hard about a year ago and now I do it every 6 months or so just to touch them up with the 1000, 3000, and polishing wheel so they stay in good condition.
jfaulk is offline
post #31448 of 45008 Old 08-18-2014, 11:30 AM
Spartan-463
Spent way long then i should trying to take an old rusted caliper off just to find out napa gave me a teves
Spartan-463 is offline
post #31449 of 45008 Old 08-18-2014, 11:45 AM
Cirruslydakota
New parking breaks going on with new hardware today. Hopefully this gets the entire braking system ready for tow duty in two weeks. Next project on the horizon? Turns out were driving to Denver to see my in-laws instead of footing a $2,200 plane tickets. Wife has given me the OK to equip the jeep as I see fit for the trip so I've already started some minor repairs and I'm getting a rotopax mount for my roof rack. Expedition Jeep project is now in full swing.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #31450 of 45008 Old 08-18-2014, 12:47 PM
Aaron00
Fixed the door wires in my drivers door today for the 3rd time think I got it so it won't break this time, and got a bottle jack that's just tall enough to get the jeep off the ground I only need one price of woof to put under that jack much better then the getto mess I had before with the stock one over all great day!
Aaron00 is offline
post #31451 of 45008 Old 08-18-2014, 01:12 PM
SirSilvia
there def needs to be someone that makes new door wiring harnesses. would make a good amount of cash on WJ owners alone lol
post #31452 of 45008 Old 08-18-2014, 01:16 PM
BrianBSHS
It just needs to be 1 wire size bigger. It seems its really only the ground wire that gets pinched. I put in a bigger gauge wire the last time I did mine.
2004 Onyx Green Overland 242HD
4.5" Clayton long arm kit + 35" Duratracs
Instagram: @_brianb
BrianBSHS is offline
post #31453 of 45008 Old 08-18-2014, 01:38 PM
SirSilvia
multiple wires are broken in mine. old coatings and the strands are too thick and not very flexible. needs more stands but smaller at the same time maybe.
post #31454 of 45008 Old 08-18-2014, 01:44 PM
wxmanWJ
My driver door ground and power wire have been repaired prior to me owning it, but the insulation is cracking again on it at the edge of the heatshrink they used. My power wire is split right in half at the edge of the old repair. I think it's a combination of the short wire, bending, and a poor quality wire with insulation that is prone to cracking and becoming brittle with age. It only appears to be the two 12g wires, the smaller wires still seem to be holding up well.
Anyone know how to get this connector apart? I pulled the red security tab out but can't seem to separate the plugs.
My "stocker" build thread: http://www.jeepforum.com/forum/f310/my-first-jeep-owning-adventure-1532212
wxmanWJ is offline
post #31455 of 45008 Old 08-18-2014, 01:50 PM
fayceoff
fayceoff's Avatar
Found this in a dumpster at work ....
It had some brackets on it that I cut off and ground down. Then I hit it with some primer and paint. I'd like to widen it, then have it sandblasted and powdercoated, but for now this is how it sits.
"It's almost always cheaper to it right than it is to do it twice." - Dad
"Be polite. Be professional. But have a plan to kill everyone you meet." - Gen. James Mattis
fayceoff is offline
wj
volvite
