What did you do to your WJ today? - Page 2061 - JeepForum.com
 673Likes
post #30901 of 44124 Old 07-10-2014, 07:10 PM
Jaketit
Originally Posted by skain8
Yes. My bilstein boots (which even have the fancy drain holes most others don't) caused much more rust on the shaft than with it totally exposed to the elements. Of course, opinions will vary.
Well I agree. Many months back when I buried it, the boot was full of sand from that I didn't find until a month later.
Jaketit is offline
post #30902 of 44124 Old 07-10-2014, 08:46 PM
4x4Jeep
got these brackets in..
Build -
SOLD
4x4Jeep is offline
post #30903 of 44124 Old 07-10-2014, 10:03 PM
FedUp007
Tryied to chase down this limp mode issue since Monday... got in her belly and checked all the connections and TV cable... still kind of clueless unless it comes to dropping the pan and diggin thru it...
Failure is the chance to begin again, with increased intelligence... 100
FedUp007 is offline
post #30904 of 44124 Old 07-10-2014, 10:32 PM
03CUSEWJ
2003 WJ
Had to R & R the passenger side door and front bumper because of some sliding around I did this past winter. I decided to change my front to the 04 design. Also, I installed a set of Hella 500s that I had laying around, running 100w H3 bulbs. Now to chase down those inner fender push pins that I broke takin her apart.
03CUSEWJ is offline
post #30905 of 44124 Old 07-10-2014, 10:50 PM
1999wjlimited
I got a set of those in today also.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #30906 of 44124 Old 07-11-2014, 03:55 AM
Shaggs2Dope
Just pull a fuse and either get a special fuse holder from auto zone that allows you to run a wire off of it or just wrap your power wire around one of the little legs. I did mine to the Un switched cigarette lighter. Then ground it to a screw somewhere in metal or back to your battery for least interference.
Sent from AutoGuide.com App
juggalo
Shaggs2Dope is offline
post #30907 of 44124 Old 07-11-2014, 03:58 AM
Shaggs2Dope
Originally Posted by 01Stormtrooper View Post
Tried to think of ways to wire my cb up, and watched videos of dash removal, and it seems like the videos did so much unnecessary stuff! How have any of you guys wired it? I'm trying to avoid excess removal and work.
juggalo
post #30908 of 44124 Old 07-11-2014, 08:39 AM
FULLJEEP
Wj
Why you should take the boots out?
FULLJEEP is offline
post #30909 of 44124 Old 07-11-2014, 08:43 AM
FULLJEEP
And if you loose the bottom part (front ones), so it will drain. but for the rear (boots are down), there is no solution!!
FULLJEEP is offline
post #30910 of 44124 Old 07-11-2014, 08:47 AM
Jeeples
Jeeples's Avatar
Because:
and:
That being said, the Bilsteins on my wife's WJ is running the boots and I periodically check them every few months. So far so good. I decided to run the boots on them due to Rubicon Express denying a warranty on one of their monotubes due to a rusted shaft.
Admittedly her WJ sees more road than dirt.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #30911 of 44124 Old 07-11-2014, 09:14 AM
JayIV
JayIV's Avatar
What part of Orlando? I live Downtown. Would love to see another WJ around.
2004 Overland
JayIV is offline
post #30912 of 44124 Old 07-11-2014, 09:18 AM
JayIV
JayIV's Avatar
Originally Posted by Thomahawk View Post
Dynamat and new speakers both rear doors,
What kind of improvements, if any, have you noticed from the Dynamat?
2004 Overland
JayIV is offline
post #30913 of 44124 Old 07-11-2014, 12:04 PM
Thomahawk
Reduce Road noise, and "hollow" sound from door metal,,,, deff worth it, makes the speaker sound 10X better.
Buildthread
Thomahawk is offline
post #30914 of 44124 Old 07-11-2014, 12:05 PM
Thomahawk
Did both front doors,
Dynamat and speakers,,,
Now off for a beer
Buildthread
post #30915 of 44124 Old 07-11-2014, 01:16 PM
wjidaho
Nice I hoping in a couple weeks to order mine along with Rcs quick discos, then maybe I can disco without take ten minutes
My build thread
wjidaho is offline
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 08:20 PM
