What did you do to your WJ today? - Page 2001 - JeepForum.com
 565Likes
post #30001 of 43615 Old 05-07-2014, 07:46 PM
RacerX125
Sent mine today into a car crusher after having deathwoble and engine problems. better yet! owner let me crush it myself
Off I go to buy a used 2002 jeep grand cherokee laredo :S
RacerX125 is offline
post #30002 of 43615 Old 05-07-2014, 07:47 PM
rdkendrick
2003 WJ
Originally Posted by RacerX125 View Post
Sent mine today into a car crusher after having deathwoble and engine problems. better yet! owner let me crush it myself Off I go to buy a used 2002 jeep grand cherokee laredo :S
Pics?
Sent from my iPad using electrons
rdkendrick is offline
post #30003 of 43615 Old 05-07-2014, 08:51 PM
mdrum93
Cured my wj's transmission problem today with a brand new, painfully expensive mopar brand TPS. After first trying a knock off from advanced auto parts, I can now say I will only buy mopar in the first place from now on. The PO installed an off brand TPS before and this may be premature, but I swear my mpgs jumped up a hair after installing the mopar one. MOPAR or NOCAR!
Bumper Thread
mdrum93 is offline
post #30004 of 43615 Old 05-07-2014, 08:59 PM
NOTW_WJ
Hmmm, I haven't been keeping up w/ the thread lately but what tranny issues did it cure? and do you have the Mopar # ?as I think I'm in the same boat needing to replace a non-factory tps
NOTW_WJ is offline
post #30005 of 43615 Old 05-07-2014, 09:28 PM
bluejeepWJ
Originally Posted by alfaitalia View Post
Hopefully they will last longer than those usally do. Mine lasted a year before they started to rust inside and push out bubbles.....yes they do have metal inside even though they claimed to be 100% plastic when I bought mine. They was a good thread on here about how crap they are and how poor they where on there customer service...I posted a reply I got from them about them lying in there advert too! The original ones took about eights years to bubble. Im going back to Mopar.
It was $89 + shipping for the set of 4. Came to just over $100 total. We'll see how long they last. For now it makes my doors look 1000 times better so I'm happy.
bluejeepWJ is offline
post #30006 of 43615 Old 05-07-2014, 09:35 PM
mdrum93
It was shifting at odd points, sometimes it felt like it was slipping almost. Plus the jeep had a rough idle, and hovered around 1000 rpms most of the time. Under normal driving I couldn't ever get it to drop below 2000 rpms which was killing my mpg. And It would stall out at stop lights, and decelerating into turns...which made for an untimely loss of power steering. I didn't have any close calls thankfully but I could see that causing a head-on collision into another car that was sitting at an intersection
here's my thread on it: http://www.jeepforum.com/forum/f310/...e-off-2378617/
And I threw the box away, but I just got the mopar TPS from the parts desk at my dealership. It was $92.
Bumper Thread
mdrum93 is offline
post #30007 of 43615 Old 05-07-2014, 09:47 PM
NOTW_WJ
It was shifting at odd points, sometimes it felt like it was slipping almost. Plus the jeep had a rough idle, and hovered around 1000 rpms most of the time. Under normal driving I couldn't ever get it to drop below 2000 rpms which was killing my mpg. And It would stall out at stop lights, and decelerating into turns...which made for untimely loss of power steering. I didn't have any close calls thankfully but I could see that causing a head-on collision into another car that was sitting at an intersection
Well, mine actually runs great with no shifting,stalling, idling issues so maybe that's not it....Just started to clunk more shifting it into gears (park - drive...reverse to drive..etc..)and wasn't like this in the past...I know they have the typical clunk thats been posted on many threads and I just had the trans completely rebuilt including all the electronics and NO troubled codes so I was thinking TPS, IAC, Vacuum leak??? I'm scratching my head at this point
NOTW_WJ is offline
post #30008 of 43615 Old 05-08-2014, 07:25 AM
wvracer821
wvracer821's Avatar
have you checked your U joints? what about rear control arm bushings? A arm bushings and the ball joint on the axle?
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #30009 of 43615 Old 05-08-2014, 08:29 AM
Aaron00
Looks like I'm getting a rebuilt motor. Jeeps still at the shop getting a new motor put in sounds like it's around 70,000 miles on the motor. I just want my jeep back lol
Aaron00 is offline
post #30010 of 43615 Old 05-08-2014, 08:56 AM
NOTW_WJ
All upper and lower jonny joints/control arm bushings fr & rear have been replaced, Drive shafts have 6 new u-joints and I even removed the front DS to eliminate it from the equation at one point. New Motor and tranny mounts too, thinking it might be slop in them. Everything seems solid.
It's like if the idle was high(which it's not) and you shifted it into gear it kinda jumps going into gear!
NOTW_WJ is offline
post #30011 of 43615 Old 05-08-2014, 09:37 AM
Jeeples
Jeeples's Avatar
Couple of things come to mind:
1- The earlier WJ's had a TSB out regarding a clunk coming from the rear driveshaft. Basically entailed putting a light coating of oil/atf/light grease on the output shaft splines on the T-case. Might be worth a shot even though the TSB doesn't specifically apply to your year. You can search WJJeeps for the TSB.
2- Recently someone posted a procedure here for training the transmission on proper shift pressure when shifting into reverse or drive from park or neutral. I think it was Darnice that posted the instructions to do so.
EDIT:
Post 19 for the relearn procedure:
http://www.jeepforum.com/forum/f310/...53/index2.html
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #30012 of 43615 Old 05-08-2014, 10:26 AM
NOTW_WJ
EDIT:
Hmmm, I don't think #1 would apply as I have a 231 w/ a SYE and recently went through my whole Transfer case, but I'll look into the relearn process and see if that makes any difference, Thanks!
NOTW_WJ is offline
post #30013 of 43615 Old 05-08-2014, 08:59 PM
andrewx12
Bought a tow hitch receiver on the cheap. $50 Looks brand new. Goes for $150 new on amazon. Just missing the hardware. It's ok as I have a big bucket of bolts that should be rated.
It is a reese 33018. It's heavy
It will be bolted up tomorrow for the upcoming muddin trip to Southington Off Road this weekend. PM me if your going. Need a crew to make it more fun.
Current repairs needed:
AT filter and fluid
andrewx12 is offline
post #30014 of 43615 Old 05-08-2014, 10:31 PM
JeepinAaron
2003 WJ
Interior LED lights
2003 WJ Laredo
http://www.jeepforum.com/forum/f22/2003-wj-off-road-minivan-2346505/#post22320625
JeepinAaron is offline
post #30015 of 43615 Old 05-09-2014, 05:15 AM
Burakbekar
Originally Posted by Zacedward View Post
Attachment 1321881
This is a pic of the wires you have to cut
Thank you very much. First i will buy the leds. Than will do it.
Jeep Grand Cherokee/WJ 4.7/Limited 2001
Burakbekar is offline
jamesrw30
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
