What did you do to your WJ today? - Page 20 - JeepForum.com
 1096Likes
post #286 of 45731 Old 09-15-2010, 08:37 PM
straty1987
did part of my led conversion for the inside and it looks good.
just waiting for the rest of the led and will do a side by side comparison.
my trunk is now bright like i want it lol
straty1987 is offline
post #287 of 45731 Old 09-15-2010, 08:40 PM
comptiger5000
My mom's WJ came from NY originally as well, and is also CA emissions.
I don't remember where I first saw this, but I know NY and a few other states have required new vehicles to be 50 state compliant (rather than 49 state, non-california) for a while (I think it started in 96 for NY). I'm not sure if CT requires it or not.
comptiger5000 is offline
post #288 of 45731 Old 09-15-2010, 09:00 PM
compcrasher86
Well it just had the muffler and tailpipe replaced completely so all that leaves for me to rip out is the cat. I'll check out how it is and if I notice its not what I'm used to I'll swap a magnaflow SS on there like I did with my XJ. Which, by the way, was an amazing improvement
Matt
compcrasher86 is offline
post #289 of 45731 Old 09-16-2010, 08:58 AM
Ideford Jeep
Changed my dip beam lights (dims?) to HiDs - took 1 1/2 hrs including finding the right tools in my shed & stopping for a cup of tea
On re-assembly I put a smear of vasoline on the 'balls' as the bottom ones had surface rust on them. Much brighter than the 60w bulbs that I was running.
Ideford Jeep is offline
post #290 of 45731 Old 09-16-2010, 10:57 AM
compcrasher86
This came in today...
I bought it two nights ago on ebay. Good shipping! Can't wait to enjoy my tunes
Matt
post #291 of 45731 Old 09-16-2010, 12:23 PM
roboll
2003 WJ
how much did you pay for that? ive been looking for a good deal on one.
2003 Silver WJ 4.0L
Work in Progress..
roboll is offline
post #292 of 45731 Old 09-16-2010, 12:59 PM
myjeeplovesmud
Whats stopping ya?
manifold bolt is broken, and i fear if i drive it, i'll break more before i have the time to get it fixed
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
November 2010 GCOTM
myjeeplovesmud is offline
post #293 of 45731 Old 09-16-2010, 04:11 PM
compcrasher86
$20 but it was a freak ebay auction . Usually they go for $40-70. Thats why I jumped on it so quickly. I though somebody was going to outbid me but I won it for minimum reserve
Matt
post #294 of 45731 Old 09-16-2010, 06:12 PM
techRob
tuesday I replaced the axle shaft on the passenger side. I realized later that the driver's side cv joint is also busted so I have that to look forward to.
today though I de-ambered the tail lights. I think it looks a lot better.
techRob is offline
post #295 of 45731 Old 09-17-2010, 09:06 AM
compcrasher86
Techrob I agree that looks so much better than stock, its right up on my list of things to do when I get home. If you dont mind me asking what kind of paint did you use with them??
I got a FSM for my wj today and my plans to turn a spare set of heated seat switches into factory switches for my lights and such was struck down when I read and found out they dont carry full current they just carry a resistor value to the PCM or wherever and then the PCM decides whether to put them on hi/lo based on the switch and some temp sensor. Damm. Well I have the switches anyways so I might as well rip them apart and see what I can do
Matt
post #296 of 45731 Old 09-17-2010, 11:55 AM
RedlegWJ
Finally got around to putting the ZJ washer tank into my WJ (Anybody have a spare ZJ fluid cap?). Used a 3/4" bit (closest I had) to drill for the level indicator. Went into the hole pretty tight, but went in with wetting the seal. Took out the old airbox. Used the intake tubing sections off the shelf at auto zone. Not cheap, but plastic... The 90* elbow went on real tight over the throttlebody using the oem donut gasket and clamp. Wiping a little oil on it got it to go. Need to get a beeter adaptor for the K&N cone filter though. Just wrapped foam tape over the outside of the tube and clamped the filter over it to get by for now. Gonna check out a plumbing section somewhere for a gasket. Would like to find a bag/cover for the filter though.
RedlegWJ is offline
post #297 of 45731 Old 09-17-2010, 01:01 PM
cracked
Last night I had to change my fan relay as it died on my way home from school and almost overheated the WJ. Had no choice but to get to from autozone. Spent a few hours with that simple job because I couldn't get one of the rivets out of the old relay, then when installing the new one the rivet didn't catch all the way, broke half way through and wasn't even flush with the metal backing and had to drill it back out. After I got all that fixed my fan still wasn't coming on, and it took me 30 minutes to find that the prongs in the fan connection had been pushed back into it's housing when I unplugged and plugged the fan back in, resulting in no contact being made and the fan not coming on
Today I'm replacing a rear tail light because I dropped and broke my already cracked old one when I removed it to paint my cladding last week.
techrob I like the deambered look, how do you go about doing that?
cracked is offline
post #298 of 45731 Old 09-17-2010, 01:07 PM
GhostKnife
I believe you use stained glass paint for that, obviously mask and sand and clear and paint lol
13 Ram Cummins, PPEI Tuned and Full Carli/Thuren. JK Arctic Edition 2dr Winter Chill
GhostKnife is offline
post #299 of 45731 Old 09-17-2010, 01:07 PM
4x4kingx889
2005 KJ Liberty
Got the build sheet from Chrysler today! I verified that it has a D35. I also found out it had the california emissions package on it so now I know why the underbody is in pristine condition. I am all the more motivated to replace the cat now...
how do you get build sheet?
4x4kingx889 is offline
post #300 of 45731 Old 09-17-2010, 01:42 PM
GFoster
Wj
Switched out the TPS yesterday... quick and painless. Runs much better now. Also recently had the windshield replaced due to a wheeling incident.
Next on the list is to make another couple rack bars out of Superstrut 1-5/8 in. x 10 ft. Metal Framing Channel (cut to 4' ish) to mount the spare and a few other things on top as needed, and use the spare well for storage.
GFoster is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
