What did you do to your WJ today? - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > What did you do to your WJ today?
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 09-12-2010, 10:13 PM   #271
compcrasher86
compcrasher86's Avatar
Originally Posted by straty1987 View Post
lol sorry to put you on the spot i have the same D-ring hitch for the my WJ's rear but have not used it yet. $10 as well
get 50/50 reply's on it
stock tow hooks in the front too.
just i bought a Keeper Recovery Strap With Loops 2"x 30' 10,000 lbs Vehicle Wt. figures if it too long just wrap the point back and have a 15 Ft strap worth the $31 to me lol
LOL its not your fault. You know somethings wrong when you feel the need to justify a HF purchase haha. I was eyeing the 30 footer for a while but something compelled me to test out the 20 first.
Found my lift kit:
Daystar™ - Driven by Design
restarting the Lift kit fund, shouldnt be too hard for a poly lift
01 WJ Ltd | i6 | QT2 | OME HD Lift | Bilstein 5100s | IRO Links | IRO A-Arm | Dueler AT RHS 255-70-18 (32") | JK Sahara rims | Moog HD steering | Upcountry Skids | Tow Package | KC Dayliters | Cobra 19 | Boston Acoustics Audio | Mopar subwoofer | RB1 | Lou's Catback | Stone White | Agate Interior
Build Thread
RIT Offroaders
Matt
compcrasher86 is offline   Reply With Quote
Unread 09-12-2010, 10:57 PM   #272
straty1987
Found my lift kit:
lol
if your looking for puck i believe theirs still a used pair of 2" for $50
straty1987 is offline   Reply With Quote
Unread 09-13-2010, 06:40 AM   #273
compcrasher86
I'm definately interested can somebody lead me in the right direction to it?
Edit: Nevermind I found it in the classifieds and made contact, hope I get it!!!!
Build Thread
RIT Offroaders
Matt
Unread 09-14-2010, 05:58 PM   #274
compcrasher86
Update: Still no word from the seller of the lift kit, I'm getting anxious but thats because I'm kind of excited with all the things I've been getting for the WJ lately:
  • Factory front tow hooks
  • D-Ring receiver hitch
  • 20k recovery strap
  • a drawer full of tools to work on it
  • a PIE iPod adaptor for the factory radio (Just won right now off ebay for $20!!!!)
  • I also found a 242 in the local junkyard with 90,xxx miles on it and they want $200. Its already pulled, waiting on a shelf
Build Thread
RIT Offroaders
Matt
Unread 09-14-2010, 07:34 PM   #275
jtcnj
Listen, you screw heads!!
jtcnj's Avatar
Wj
glad to hear you got it done.
how was it form start to end ?
did you get the loud sounds when the pump had no fluid?
did a freind help or it just pumped out ok?
did you take off both lines?
i believe you have the V8 and the pipe has to come off to replace the pan
should be a dana 44a but check out wjjeeps for more info
Thanks
It was just a pain to wrench the air box bolts / nuts under the fender by myself, the threads rust locked even though I went towards tight again and kept spraying them. I took both return hoses off the pump and let them drain awhile. I bumped it, let it run only 3 seconds at a time a few times.
Put them back, new hose clamp on cooler return. Never could find that filter I see in the FSM. Sounded unhappy and foamed the first time I started it, just a second or 2. Took a whole quart. The air box bolts got me feeling stupid for awhile. I'll be tackling that oil pan soon.
Got my build sheet, and reading around says its a 44, "looks like an apple laying on its side".
Starting welding class Wednesday!!
"Lay Down Sally" Silverstone Metallic 2001 xj sport 4.0L/AW4/231/8.25 mostly stock.
"Dubyuh" or "Blue Bayou": Patriot Blue 2001 Up-Country WJ Limited 4.7L V8 Quadra Drive: for now known as "Al-Dente" after my wife's "mod".
New Addition 12/2011: "Pearl" Forest Green Pearlcoat 1999 xj SE 4.0L/AW4/231/8.25 mostly stock for now.
____________________________________________
I didn't agree, but hoped for Hope and Change.
I got change for myself and my family: for the worse.
This is the reality of: Barackalypse Now. Again.
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Wilson Reagan
jtcnj is offline   Reply With Quote
Unread 09-14-2010, 07:42 PM   #276
jtcnj
jtcnj's Avatar
Wj
Originally Posted by logisticalstyle View Post
Buffed out my headlights. I used several grades of sand paper ending at 2000 and then used the Blue Magic polish. They look better than they started out looking, but I'm still thinking about just replacing them completely. I also changed my air filter and topped off all of my fluids and replaced my light bulb in the engine compartment. And I replaced my hood lifts.
I did 800/1000/2000, rubbing compound, polishing compound ( I had both laying around) then Plastex, seal with 303. Not quite new, but they look great compared to how they did before.
Unread 09-14-2010, 08:16 PM   #277
straty1987
Originally Posted by jtcnj View Post
Thanks
cool,
when your done learning want to make some slid rails for my WJ?
Unread 09-15-2010, 10:12 AM   #278
GhostKnife
picked up a nail in my work parking lot, free fix! lol
[FONT="Showcard Gothic"]2010 Dodge Ram Quadcab Sport, 5.7l with a Diablo Sport Predator.[/FONT]
GhostKnife is offline   Reply With Quote
Unread 09-15-2010, 10:22 AM   #279
smunns
Continued working on my rock rails, and bought a ZJ windshield washer fluid reservoir.
smunns is offline   Reply With Quote
Unread 09-15-2010, 12:56 PM   #280
GhostKnife
had to order new straps and screws for the front driveshaft, old ones didnt work so well. straps were 2.50 a piece and screws were 1.00 a piece. not so bad
Unread 09-15-2010, 02:22 PM   #281
compcrasher86
Got the build sheet from Chrysler today! I verified that it has a D35. I also found out it had the california emissions package on it so now I know why the underbody is in pristine condition. I am all the more motivated to replace the cat now...
Build Thread
RIT Offroaders
Matt
Unread 09-15-2010, 04:56 PM   #282
myjeeplovesmud
looked at her sitting in the driveway..... wish i could drive her.....
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
MY BUILD THREAD
BAD TO THE BONE ZONE
November 2010 GCOTM
myjeeplovesmud is offline   Reply With Quote
Unread 09-15-2010, 05:01 PM   #283
compcrasher86
Whats stopping ya?
Build Thread
RIT Offroaders
Matt
Unread 09-15-2010, 08:26 PM   #284
comptiger5000
FYI, some other states such as NY require cali emissions. Mine came from a dealer in NY originally, and has cali emissions.
comptiger5000 is online now   Reply With Quote
Unread 09-15-2010, 08:35 PM   #285
straty1987
tarts sounds odd since NY is like the the 49 other states and just California has the emission thing.
could be it was made for California and was needed at a dealer in ny so they sent it their.
