What did you do to your WJ today? - Page 1899 - JeepForum.com
 1106Likes
post #28471 of 45748 Old 02-28-2014, 02:26 PM
brouwmat
250lb torque wrench for that axle nut. Look at those ball joints real well while you are in that deep.
Sent from AutoGuide.com App
brouwmat is offline
post #28472 of 45748 Old 02-28-2014, 03:15 PM
Jer-Bear
Originally Posted by Thomahawk View Post
Sound video or it didnt happen, you know the rules.
You got it!
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #28473 of 45748 Old 02-28-2014, 05:42 PM
vagov
only took me 3 months to finally install my upgraded zone steering stabilizer ! it sucks to not have a garage to work in ! still cold out and another 7-12 more inches of snow expected tomorow
vagov is offline
post #28474 of 45748 Old 02-28-2014, 05:48 PM
SpitFyre79
Originally Posted by cr8zynelly
I know, I know. Just trying to tend to all maintenance and proper fluids before I install any hot rod mods on. On that note. . .ill be changing out both my front hubs this weekend. I've done my wife's Exploder but never the Jeep. Any tips?? Besides PB blaster on the 3 bolts on the backside of the hub.
Replace the 3 bolts on each side while you're at it. And for an extra $120 you should have gotten both CV assembly shaft's. Heat the outer of the control arm before you pound those wheel hubs out.
StormTrooper - JerseyStrong
SpitFyre79 is offline
post #28475 of 45748 Old 02-28-2014, 05:55 PM
WVUFTBAL83
Finally home for a weekend for once. Was busy last several weekends, searching for our new WJ. So today,I swept and worked on detailing the inside before it got too cold... mixed and added engine coolant. Refilled windshield washer fluid, and sprayed WD-40 on some squeeky parts. Typical Jeep stuff.
WVUFTBAL83 is offline
post #28476 of 45748 Old 02-28-2014, 06:37 PM
mbinky
2003 WJ
Installed my new OME HD springs today. Last weekend I replaced all of my control arms and bushings, so today I did the lift. The rear got the new springs, isolators, Blistein shocks, Adco sway bar w/greasable bushings and IRO links. The front got the springs, isolators, shocks, and new IRO links (kept the original sway bar). Tomorrow I need to install and adjust the new JKS trackbar, new sway bar frame mount bushings and steering stabilizer. I took it for a quick spin and I love the new ride. Much better than the 176K mile ride . I got all of my parts from Kolak, he knows how to put a system together.
Here are a few cell pics. The first is from a few years ago when I bought it, the second is from today. I forgot to measure the before height, but I am very happy with the end result.
In the next few weeks I will be doing ball joints, cv shafts, hubs, tie rod ends and drag links. Then off for some new tires (close to stock size) and an alignment. My front tires are slicks! (The reason I started this adventure) Oh yea, I got the front and rear Kolak Stillen brake upgrade on the way, so a system flush and install of those will be in the future also.
mbinky is offline
post #28477 of 45748 Old 02-28-2014, 06:48 PM
pyre24
I know. I dont like laying in a pile of snow ice or water to do anything.
pyre24 is offline
post #28478 of 45748 Old 02-28-2014, 07:07 PM
doorjamm
My jeep wasn't prepared for today's heavy rains. Sun roof doesn't seal, catch pan or whatever it is is likely broken in there too, and the drain tubes certainly have to be clogged. Why? Well maybe thecouple inches of water on the floor and the fact I had water coming down from the Evic, mirror, and just dripping down onto me from the headliner. Looks like ill be tearing out the headliner this weekend
doorjamm is offline
post #28479 of 45748 Old 02-28-2014, 07:23 PM
rdkendrick
2003 WJ
Originally Posted by mbinky View Post
Installed my new OME HD springs today. Last weekend I replaced all of my control arms and bushings, so today I did the lift. The rear got the new springs, isolators, Blistein shocks, Adco sway bar w/greasable bushings and IRO links. The front got the springs, isolators, shocks, and new IRO links (kept the original sway bar). Tomorrow I need to install and adjust the new JKS trackbar, new sway bar frame mount bushings and steering stabilizer. I took it for a quick spin and I love the new ride. Much better than the 176K mile ride . I got all of my parts from Kolak, he knows how to put a system together. Here are a few cell pics. The first is from a few years ago when I bought it, the second is from today. I forgot to measure the before height, but I am very happy with the end result. In the next few weeks I will be doing ball joints, cv shafts, hubs, tie rod ends and drag links. Then off for some new tires (close to stock size) and an alignment. My front tires are slicks! (The reason I started this adventure) Oh yea, I got the front and rear Kolak Stillen brake upgrade on the way, so a system flush and install of those will be in the future also.
Cool, now I get a sneak peek at what mine will look like lifted. I also have a silver Overland, almost the same mileage, 179k.
Mine will get done when it's warmer. I am not going to mess with cold, frozen, stuck bolts.
Sent from my iPad using my fingers
rdkendrick is offline
post #28480 of 45748 Old 02-28-2014, 07:25 PM
1999wjlimited
Ups delivered my new wheels today.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #28481 of 45748 Old 02-28-2014, 07:42 PM
mbinky
2003 WJ
Growing up in New England, I know what you mean. I kinda feel like I cheated. My jeep never saw the outside of southern CA until I bought it. I'd be embarassed to tell you how long it took me to tear it apart and put it together. Kinda felt like I was on one of those TV shows where everything comes apart and goes together just like the book says it will in the time alloted by the network...
mbinky is offline
post #28482 of 45748 Old 02-28-2014, 08:24 PM
redneck_ram
2003 WJ
replaced my front calipers, rotors, and pads today. tie rods, and sleeve from pitman arm, to knuckle tomorrow. fun fun!
2003 WJ Overland 4.7HO quadra-drive - k&n fipk, kolak 3" exhaust, magnaflow muffler, sct tuner-hemifever
2001 Dodge Ram 1500 - QCSB 4x4 built 360, 46re, not stock!
redneck_ram is offline
post #28483 of 45748 Old 02-28-2014, 09:36 PM
fayceoff
fayceoff's Avatar
Fixed my check engine light. I was throwing code P1494. I had a crack in my gas cap so i replaced it with a locking one from Advance Auto.
"It's almost always cheaper to it right than it is to do it twice." - Dad
"Be polite. Be professional. But have a plan to kill everyone you meet." - Gen. James Mattis
fayceoff is offline
post #28484 of 45748 Old 02-28-2014, 09:46 PM
SpitFyre79
Fixed my P0123 code. Resolved by replacing the aftermarket TPS with an OEM TPS. Aftermarket was throwing a high voltage surge code along with stalling out when cold, preventing cruise control to work, and hiccup throttle response. Funny how sometimes aftermarket parts are junk!
SpitFyre79 #JerseyStrong#
post #28485 of 45748 Old 03-01-2014, 11:21 AM
north50
Originally Posted by SENECA View Post
My wife said she saw you as you were leaving and told me that there was a silver WJ leaving from next to mine and said it was bigger.I said no way but now I see she was right,yours makes mine look like a stock WJ. lol
Very nice!
If your going to sell your JK rims and tires let me know,I am looking for some newer treads and I was thinking about running the JK rims in that same size if they fit.
I think the picture is a little deceiving. I work right around the corner literally so I've always looked at your Jeep as inspiration. I have another project that the wheels and tires will be going on so cant sell them. Although I would recommend the JK wheels with 1.5" spacers. They sit nicely just past the fenders, were fairly cheap and get a lot of complements. So much so it has me questioning buying these.
OT I picked up my IRO rock rails from the paint shop. Also had them paint the bug shield I got for the hood to help push air over the roof rack and soon to be LED light bar.
north50 is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
