What did you do to your WJ today? - Page 1892 - JeepForum.com
 1012Likes
post #28366 of 45570 Old 02-25-2014, 12:35 PM
dadamets
Originally Posted by et2473
I have my Avital setup D2D.. I followed this writeup http://www.jeepforum.com/forum/f310/...-easy-1312756/
Can I still just plug it into the D2D port or would i have to set it up W2W to use the D2D port for the Smartstart?
As far as know you would have to wire the DB-ALL W2W to get use of the D2D for the smart start. From what I have gathered, as you move up in the DEI line-up, you also get multiple ESP / D2D ports that would eliminate this issue.
dadamets is offline
post #28367 of 45570 Old 02-25-2014, 01:03 PM
SpitFyre79
Got rid of the wood grain and painted it to match the exterior. Also installed my scanner.
StormTrooper - JerseyStrong
SpitFyre79 is offline
post #28368 of 45570 Old 02-25-2014, 03:28 PM
Johnyre
Looks pretty nice man
Great place to mount your scanner I might have to still that idea
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #28369 of 45570 Old 02-25-2014, 04:56 PM
SpitFyre79
Originally Posted by Johnyre
Looks pretty nice man Great place to mount your scanner I might have to still that idea
I made some brackets out of some thin aluminum sheet metal then painted them black and mounted with screws and double sided tape so there was no chance of squeak or rattle.
post #28370 of 45570 Old 02-25-2014, 05:32 PM
theksmith
2003 WJ
trimmed inside the front wheel well more this weekend:
more pics...
theksmith is offline
post #28371 of 45570 Old 02-25-2014, 07:18 PM
dcorn
Did some carbon wrapping, installed some switches and finally got my trans temp gauge wired up. Don't have the temp sensor installed yet, so it's just chilling at 300*. Only switch hooked up is the front lights to my D2s in the grille, still have to buy some reverse lights and a big light bar of some sort for the others. Gotta figure out how the hell to wrap the steering wheel too...
Did you take those parts out to paint them? How?
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #28372 of 45570 Old 02-25-2014, 07:19 PM
wjidaho
Originally Posted by theksmith
trimmed inside the front wheel well more this weekend: more pics... .
Nice I am going to be doing a bunch of trimming this summer I want to fit 32s on my bb and upcountry springs, I know I will have to at least take 2" from the front and thinking 1 1/2" in the back. I guess we will see I don't want to lose any offroad capability,
My build thread
wjidaho is offline
post #28373 of 45570 Old 02-25-2014, 07:30 PM
Duh
I fit 265/70r17 with no trimming. Had slight rub when backing up hill at full steering lock, and minor rub on rear shocks when flexed, but the rub on the front bumper i let fix itself, within a month it wore enough plastic away (barely an eigth of an inch). This is 2.5" front, 2" rear lift. Cooper at3's.
Duh is offline
post #28374 of 45570 Old 02-25-2014, 07:46 PM
shockracer
I sit at 5" of lift and still had to trim front and rear.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #28375 of 45570 Old 02-25-2014, 08:00 PM
cr8zynelly
But your also running spacers.
cr8zynelly is offline
post #28376 of 45570 Old 02-25-2014, 08:05 PM
shockracer
Before I did I had to hammer in the corner of my exhaust pipe by the rear tire, my tires rubbed bad on the control arms, and I still had to trim about an inch off my front bumper.
The overall tire size is going to determine what you will happen. I like to fully stuff mine to the fenders.
post #28377 of 45570 Old 02-25-2014, 08:10 PM
SpitFyre79
Yeah I took all the trim out. Piece on dash above glove box can be accessed from behind it, had a few nuts to loosen behind it. The radio bezel and ashtray come right out and then I masked out what I didn't want painted. The door panel pieces have posts that are factory melted to the inside of door panel. Trim the melted part with a razor knife and they come right off. Paint those and then just use liquid nails or a heavy contact bathroom caulk adhesive to put them back on and allow them to dry. DO NOT USE GORILLA GLUE!
post #28378 of 45570 Old 02-25-2014, 08:33 PM
shockracer
This is with some bald 265/70/17s, as you can see it is tight even with a 5" lift on short arms with no spacers. Now if your just looking to hop curbs and mall crawl then it might work for you.
post #28379 of 45570 Old 02-25-2014, 08:33 PM
irzyxel
Originally Posted by robrilla View Post
Two new oil leaks?
*oops quoted wrong person heh
Nope I had a main seal leak and a valve cover leak. Fixed them.
2004 Overland stock with 103,000 miles
irzyxel is offline
post #28380 of 45570 Old 02-25-2014, 09:31 PM
wjidaho
Yeah I only have the top half of my front bumper and as far as cutting the rear bumper I am not scared at all, the only thing that worries me is cutting the fenders, but I will have to do that with the fender flairs
My build thread
wjidaho is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
