What did you do to your WJ today? - Page 1891 - JeepForum.com
 793Likes
post #28351 of 44805 Old 02-24-2014, 10:25 PM
dadamets
Finished up a weekend project. I pulled out my Avital 4103L and replaced it with a 2-way Viper 5501 Remote start / keyless. I also installed a Smartstart module so I can remote start via my smartphone. I was more than happy with the Avital but with this winter being so cold, I wanted to be able to start the WJ while still at work. I work at an airport and we have remote parking. With the Avital I would only be able to start the WJ once the employee bus got to the peaking lot. Now I will not have that issue.
dadamets is offline
post #28352 of 44805 Old 02-24-2014, 10:48 PM
doorjamm
Originally Posted by pmdowd6 View Post
Holy **** I would have pissed myself
i nearly did!
Originally Posted by Jaketit View Post
May I ask what setup you are running?
6.5" critical path kit with fixed iro rear short arms. discontinued 4.5" coils from IRO and 2" spacers
Update though, it turns out the shock bolt had been vibrated out ( at least my guess with driveline vibes ) on the freeway, which was the cause of dogtailing, and that along with the sway bar disco'd allowed the jeep to roll so much when i turned and why the coil spring came out. I mustve had it all backwards, but I assumed when I couldnt find the spring at the intersection that the shock mustve been holding it to clear the tire. I got the jeep home by running out with my stock springs and a floor jack and placed the stock spring up in there with the 2" spacer still there. Luckily it allowed just enough clearance for the 35s for me to slowly drive it home. Then I decided hours later Id grab a flashlight and go look around the area again where the Jeep almost rolled and look for whatever had fallen off. Some person randomly pulled up and asked if I was looking for a big spring! nearly 5 hours later and someone that had picked it up happened to be driving by as I was out there with a flashlight. What are the chances? So luckily I have my spring back, and just need to get a new bolt for the upper shock. But inspecting those threads and not finding a snapped bolt really has me wondering if someone messed with the bolt
and pictures up tomorrow when I get my new phone
doorjamm is offline
post #28353 of 44805 Old 02-24-2014, 10:52 PM
03azwj
2003 WJ
Originally Posted by FedUp007
LED License plate update... Pretty bright. I like it!
Where in AZ are you?
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #28354 of 44805 Old 02-24-2014, 11:19 PM
wjidaho
Originally Posted by doorjamm
i nearly did! 6.5" critical path kit with fixed iro rear short arms. discontinued 4.5" coils from IRO and 2" spacers Update though, it turns out the shock bolt had been vibrated out ( at least my guess with driveline vibes ) on the freeway, which was the cause of dogtailing, and that along with the sway bar disco'd allowed the jeep to roll so much when i turned and why the coil spring came out. I mustve had it all backwards, but I assumed when I couldnt find the spring at the intersection that the shock mustve been holding it to clear the tire. I got the jeep home by running out with my stock springs and a floor jack and placed the stock spring up in there with the 2" spacer still there. Luckily it allowed just enough clearance for the 35s for me to slowly drive it home. Then I decided hours later Id grab a flashlight and go look around the area again where the Jeep almost rolled and look for whatever had fallen off. Some person randomly pulled up and asked if I was looking for a big spring! nearly 5 hours later and someone that had picked it up happened to be driving by as I was out there with a flashlight. What are the chances? So luckily I have my spring back, and just need to get a new bolt for the upper shock. But inspecting those threads and not finding a snapped bolt really has me wondering if someone messed with the bolt and pictures up tomorrow when I get my new phone
No offense but that's why I think some people is against spacers on springs, I just really glad you are ok, don't worry you will have her back up and running in no time :-)
My build thread
wjidaho is offline
post #28355 of 44805 Old 02-25-2014, 02:03 AM
et2473
Junior Member
Was the Viper system as easy to install as the Avital? I have the Avital but would like to upgrade to a 2way so I know when the car is started and maybe get some more range on the remote.
et2473 is offline
post #28356 of 44805 Old 02-25-2014, 06:03 AM
FedUp007
Live in Gilbert... work in Tempe...
Failure is the chance to begin again, with increased intelligence... 100
FedUp007 is offline
post #28357 of 44805 Old 02-25-2014, 08:49 AM
Jeeples
Jeeples's Avatar
More like why you shouldn't be running around on the street with your sway bar(s) disco'd
No offense doorjamm, but you really should get your **** sorted before the random crap flying off your rig hurts somebody.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #28358 of 44805 Old 02-25-2014, 09:03 AM
dadamets
It would have been had the first unit (Clifford made by DEI) been a working unit. Turned out the Brain was DOA! Ended up with the Viper also Made by DEI, As is the Avital. If you have your DB-All set up W2W vs D2D you could just get a Smartstart Module and connect it to the D2D port. You would then be able to Start, Lock and Unlock via your smartphone. Only Caveat is the Smartstart requires a subscription of $70 per year or $140 for 3 years. I could get you a referral to save $20 on the subscription if you wanted to go that route.
dadamets is offline
post #28359 of 44805 Old 02-25-2014, 09:34 AM
wjidaho
Originally Posted by Jeeples
More like why you shouldn't be running around on the street with your sway bar(s) disco'd No offense doorjamm, but you really should get your **** sorted before the random crap flying off your rig hurts somebody.
I guess I missed the whole sway bar disco'd part, yeah connect your damn sway bar on the street, you don't want to roll one of these trust me it's sucks ;-)
My build thread
wjidaho is offline
post #28360 of 44805 Old 02-25-2014, 09:40 AM
spud2388
Finally finished my sub box/spare tire support. It was a pain dealing with all the angles as the base shape is an octagon, but it turned out pretty nice I think. And this whole project was made out of left overs from other projects. So no money out-of-pocket. The carpet job isn't the best, but with all the angles and whatnot, and the fact that only 80% of it will actually be seen, its no biggy.
The box is bolted down with two 6"bolts through the trim and to the inner metal panel. There are spacers between the metal panel and the trim so once I tighten everything down, nothing is getting crushed and everything is just sandwiched in place.
What it looks like when you open the hatch
spud2388 is offline
post #28361 of 44805 Old 02-25-2014, 09:55 AM
et2473
Junior Member
I have my Avital setup D2D.. I followed this writeup http://www.jeepforum.com/forum/f310/...-easy-1312756/
Can I still just plug it into the D2D port or would i have to set it up W2W to use the D2D port for the Smartstart?
et2473 is offline
post #28362 of 44805 Old 02-25-2014, 10:17 AM
doorjamm
yes yes i know. i have the addco rear sway bar, and when i was on the trail the jeep was flexing a lot and it pulled the nut straight through the bolt hole on the sway bar. so i just hadnt gotten around to fixing it yet, and wasnt expecting a shock to randomly fall down and hang from the axle though.
doorjamm is offline
post #28363 of 44805 Old 02-25-2014, 10:34 AM
biffs
Originally Posted by WJ_allday04 View Post
what did you use to attach your light bar in the rack channel???
I used a couple of U-bolts with a custom piece of metal to secure both the ubolt and the mounting hardware that came with the light.
As for the light bar itself, its a 40 inch one - http://www.jeepforum.com/forum/f197/.../#post20295073
Its a temporary mounting, I will eventually be getting or building a large roof rack that will have the mounting for the rack on there. Subscribe to my build thread and I'll take a picture of the mounting and I'll post it there.
Build thread:
sure why I can't make that a real link)
biffs is offline
post #28364 of 44805 Old 02-25-2014, 11:47 AM
Jeeples
Jeeples's Avatar
Its all good my man. Glad to hear everything ended up alright
Jeeples is offline
post #28365 of 44805 Old 02-25-2014, 11:51 AM
Thomahawk
Washed the Jeep down from weeks with salt buildt ups
Seafoam threated it,
1 bottle in full fuel tank,
1/3 bottle in intake thrue brake booster hose, didnt manage to choke it out, but shut it, and let cure for 20 min,,,,
ENJOYED the smoke show!!!
Shhhh came out,
Took it out on the highway and floored it WOT about 10 times on a 15 min drive.
Remaining 2/3 bottle is going into oil later on, before next upcoming oil change.
Didnt cure any tick though, but i am pretty sure engine is clean now
Buildthread
Thomahawk is offline
wj
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
97Mule , GhostJeepWJ , LeakinOil , Redjeepwj
