What did you do to your WJ today? - Page 1888 - JeepForum.com
 562Likes
post #28306 of 43610 Old 02-23-2014, 05:21 PM
robrilla
Originally Posted by Thomahawk View Post
^^^Look tits!!!
I will have to redo my CF grill soon, be careful with very hot water and high pressure,,,
Really Nice Work man, thumbsup
Thanks man! It was your mod ;-)
robrilla is offline
post #28307 of 43610 Old 02-23-2014, 06:27 PM
wj-jeepdrew
Cleaned battery terminals and connections.
What can cause to corrode so fast? Cleaned them about 2 weeks ago.
wj-jeepdrew is offline
post #28308 of 43610 Old 02-23-2014, 07:03 PM
rdkendrick
2003 WJ
Originally Posted by robrilla View Post
I'm in for this as well. I need to replace my blinds.
I got a free set of blinds over in the free Jeep parts, just had to pay shipping. I have never figured out how to take the Grand Cherokee shifter knobs off. The knobs on my '91 Cherokee were easy.
Sent from my iPad using electrons
rdkendrick is offline
post #28309 of 43610 Old 02-23-2014, 07:23 PM
cr8zynelly
Originally Posted by Locutus
Added LEDs to the shifter console. Removed and cleaned the selec-trac blinders. now the slide nicely. BTW pulling off the 4wd knob was pretty easy.
Pics when it gets dark. It looks F-in awesome
How'd u get the knob off?
cr8zynelly is offline
post #28310 of 43610 Old 02-23-2014, 07:45 PM
robrilla
There's a great looking set at the JY I just couldn't figure out how to take the damn shifter apart to get them.
robrilla is offline
post #28311 of 43610 Old 02-23-2014, 08:01 PM
wjidaho
Originally Posted by 99WJ539918
What did you get for it? I live the look of mine, but I might want to change it up.
Sold it to a buddy in my club for $125 but I was going to ask $150 on Craigslist
My build thread
wjidaho is offline
post #28312 of 43610 Old 02-23-2014, 08:30 PM
gcjeeping
Here ya go...
Originally Posted by gcjeeping
Originally Posted by gcjeeping View Post
You don't. Cant be done. Have to take the knobs off.
The long story. I just explained it to someone that bought a bezel from me. From the start. You may already know how to remove the center console, so if you do ignore that part.
Console out.
2 screws under the rubber piece under the ash tray.
2 screws under the cup holder.
2 screws in the box under the arm rest.
Pull the box out .
2 screws inside the center console under the box at the back each corner.
Console will come out.
Ways to remove bezel. All ways require removing the knobs.
You have to pop off both shifter knobs.
**BE VERY CAREFUL WITH THE GEAR SELECTOR KNOB**. There are two wires running up into it for the OD button. There is no play in the wires to pull the knobs off, they will break. Follow the wires from the connector up the the arm for the gear selector and undo it from the points securing it to the arm. This will give you slack when you pop up the knob.
The will pull off with a real good tug (Watch you head on the roof).
My preferred method is to use a really big crescent wrench or wrench. I have a 1 5/8" one that is over 18" long. I put a rag over the open end and put it around the base of the trans selector (in 1st) and the handle on top of the 4x4 selector (in 4lo). The leverage will pop off the trans selector pretty easy with a good smack on the end of the wrench with my hand.
Do the same with the 4x4 selector and put the handle on the trans shifter shaft. Then a good smack. Both knobs are off now.
Unclip the bezel from both sides. Will slip over 4x4 shaft .
At this point you have a couple choices.
You can cut the 2 wires to the OD. Slide the bezel off and put new one on and splice the wires back together. Put the console back in and your done.
Next choice disassemble it.
Figure out how to get the pins out of the connector. Remove wires from the Slide the bezel off and put new one on.
Remove the light strip.
The light strip just slides over 2 pins on a little elect box. Untuck the strip from under the plastic at the front. Lift it out towards the back and then slide it of the transformer or what ever that little power box is. Set aside.
Remove light pwr box.
This box will need to come out as it is part of the harness and cant be unplugged. There are two little tabs holding it in in top. These are a pain in the a$$. I found that a sharp screw drive pushed across the tabs and remove them makes it easy to get it out. Wont effect it staying in place when you put it in. Remove box. and unattach the harness from the frame
Harness connector.
Either pop it off the metal bracket or slide it off the plastic bracket.
Wiring harness to OD should be loose already.
If you have the type shifter with the solenoid in the front that will have to be taken loose and take the bracket that the bezel clips to off.
It is held on by 2 clips in the back and sorta hinged in the front. Gently pry the clips loose and the lift by the back and the front will slip off.
Remove the wiring harness on the gear selector and light strip.
Feed the harness and shifter blinds out the old bezel.
Reassemble in reverse.
And your done.
I would just figure how to get the wires out of the connector or splice the OD wires and be done with it.
_____________
gcjeeping is online now
post #28313 of 43610 Old 02-23-2014, 08:56 PM
robrilla
Here ya go...
You are the man gcjeeping! I think I'll head back to the JY next weekend to pickup the blinds for my WJ.
Thanks a million!
robrilla is offline
post #28314 of 43610 Old 02-23-2014, 09:04 PM
gcjeeping
Upgraded from Teves to Akebono calipers from an 04 for $25. Replaces the serpentine belt because its about time (kept old one as spare. Replaced spark plugs because it was also time for them (kept old ones as spares). Cleaned throttle body. Thats just about it. Was gunna put half doors back on since its been in the 70's but expecting rain and low 60's at the end of the week.
_____________
post #28315 of 43610 Old 02-23-2014, 09:13 PM
irzyxel
New front pads and rotors, shocks all around, two oil leaks, and front steering dampener and bushings.
2004 Overland stock with 103,000 miles
irzyxel is offline
post #28316 of 43610 Old 02-23-2014, 09:20 PM
robrilla
Two new oil leaks?
robrilla is offline
post #28317 of 43610 Old 02-23-2014, 09:51 PM
WJ_allday04
took a casual Sunday drive, cleaned the wj inside, washed the salt off and went to see my wrecked wj :-( I decided to pull the home link info center out of the old girl. does anybody know if the home link info center can swap in to a wj that didn't come with the option and work fine?
2004 WJ 4.7 - 7in lift
Rustys Long Arms//Rustys f+r springs//Rustys crossmember
CSL RLCA//Poly D30 bushings//IRO A arm
Skyjacker Nitro's//JKS trackbar//242HD+IRO SYE
WJ_allday04 is offline
post #28318 of 43610 Old 02-23-2014, 09:56 PM
gcjeeping
Yes it can and it will work. I did it in my 01'.
Check out WJJEEPS.COM EVICS to see what years came with what options.
http://www.wjjeeps.com/evic.htm#EVICPARTS
_____________
post #28319 of 43610 Old 02-23-2014, 10:04 PM
WJ_allday04
cool thanks! I'm basically swapping an 04 to an 04 haha. I wish I had the Tpms though, it would be nice to have.
post #28320 of 43610 Old 02-23-2014, 10:18 PM
Stimmel
I did a TON to my 01 WJ today including a 242 SWAP
Oil change with mobile 1
Front and rear dif fluids with royal purple and mopar Friction modifier
replaced leaking oil pressure sensor
replaced all my ujoints
INSTALLED A 242 HD TRANSFERCASE!!!
I did all of this in no time at all! I work at IPSmotorsports in ohio so I have access to lifts and organized tools
Stimmel is offline
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
