What did you do to your WJ today? - Page 1875 - JeepForum.com
 906Likes
post #28111 of 45326 Old 02-16-2014, 02:30 PM
rdkendrick
2003 WJ
Finally got the gumption, and, since tomorrow's a holiday, for me, to add some FM to my rear diff, because it has been groaning on left turns. I also installed my Fog light LEDS.
They are supposed to be
"One Pair (2 Pieces): LED 18 SMDs Bulbs
H10 (Fog Light Only)
Compatible with 9145, 9140, 9045, and 9055
** Light Color: Super White 6000K **"
But they don't really look all that much brighter than my regular bulbs, just whiter. I'll know at night, I guess. I had to remove the whole fog light housing on the right side. Body shop put a junker of a fog light in there the last time they worked on it, about three years ago. I hit a big dog and he broke everything under my right bumper. I was too tired to mess with trying to drain and refill my TC fluid. I also considered swapping in my JK Moabs 255/75/17 GoodYear Wranglers, just to see how they'd fit under the wheel wells. Another day. God, I can hardly walk, now, even WITH a cane.
Sent from my iPad using electrons
rdkendrick is offline
post #28112 of 45326 Old 02-16-2014, 05:40 PM
curbry
2012 WK
Just did the 2" IRO springs and Bilstein shocks. Tomorrow its steering stabilizer time.
2012 WK2, 4x4, basically the family car
2004 WJ 4.0L, 4x4 automatic 42re select trac, 242 tcase, d30 & d35, manual AC - my run around
2014 Mustang GT 5.0 with some goodies but nothing major yet...
curbry is offline
post #28113 of 45326 Old 02-16-2014, 06:10 PM
Revo-Lution
This is what I did to my wj today!
Revo-Lution is offline
post #28114 of 45326 Old 02-16-2014, 06:36 PM
SpitFyre79
Installed these bad boys from eBay in my reverse lights tonight. Holy brightness batman!
http://www.ebay.com/itm/300999120470
SpitFyre79 is offline
post #28115 of 45326 Old 02-16-2014, 06:41 PM
Son-of-Beast
2010 JK Wrangler
Continuing TAG Rock Slider Saga
So I made another attempt at getting the Rock Sliders on this morning and still no joy. The U shaped brackets are just not quite right and I am fed up with fighting with them. I got close, about 1/2", but the U brackets won't let me get the location and tightness I want.
Plan now is to cut the L shape part of the bracket off, so I will just have the plate (outboard side) the tube mounts to. I will cut another inch or so from the top of the bracket to get closer to the pinch seam - currently sitting about 2" below the pinch seam. I'd cut more but that would be getting deeper into the meat of the gusset from the tube to the mount plate.
I was also not happy with the front-to-back location the U brackets mandated due to the shape of the unibody frame rails - I had about 2" clearance from the back tire but 4 " from the front - it was more than enough to see and it was bugging me.
Once I get the cuts made I'll mock it up again.
2010 JKU Rubi, 6-spd, AEV Frt, Warn 9.5, SRC Side Armor, Rancho Rr Carrier, 730RER, BFG M-T KM's
Son-of-Beast is offline
post #28116 of 45326 Old 02-16-2014, 09:34 PM
cr8zynelly
U set the e brake or almost get run over takin that pic? Looks good. Do they have amber or red?
cr8zynelly is offline
post #28117 of 45326 Old 02-16-2014, 09:47 PM
SpitFyre79
Ha ha ha! Key in ignition turned off, then turned it to where shift lock disengaged, applied ebrake, then shifted safely into reverse, walked around back and took a pic. You have to look under the sellers other items, that's why I posted the link. I am gonna try tomorrow night and see if these will work in the turn signals and brake lights. If they work with out issues I am buying two more sets.
JERSEY STRONG - KCCO
post #28118 of 45326 Old 02-16-2014, 09:55 PM
cr8zynelly
I know. I wanted you to look for me, lol. I guess I'll try. Ugh, haha. Lemme know if they work in the brake and signals.
post #28119 of 45326 Old 02-16-2014, 10:01 PM
cr8zynelly
Why isn't this compatible with my 2002 Overland? Does it stick out too far? Hhhmmmm.
http://bit.ly/193NTYu
post #28120 of 45326 Old 02-16-2014, 10:24 PM
vagov
Ordered a 126w cree led flood spot combo lightbar to replace the cheap wallyworld fogs i got on my bullbar now
vagov is offline
post #28121 of 45326 Old 02-16-2014, 10:25 PM
SpitFyre79
Why isn't this compatible with my 2002 Overland? Does it stick out too far? Hhhmmmm. http://bit.ly/193NTYu
Is Jeep gonna pay you for free advertising? LOL! That looks like dog sheet! :-)
post #28122 of 45326 Old 02-16-2014, 10:39 PM
MuddyWJ
It sat outside calling my name ALL day.
MuddyWJ is offline
post #28123 of 45326 Old 02-16-2014, 11:45 PM
Trxgedy
Watched her get towed away...
Trxgedy is offline
post #28124 of 45326 Old 02-17-2014, 12:01 AM
rdkendrick
2003 WJ
Originally Posted by SpitFyre79 View Post
Ha ha ha! Key in ignition turned off, then turned it to where shift lock disengaged, applied ebrake, then shifted safely into reverse, walked around back and took a pic. You have to look under the sellers other items, that's why I posted the link. I am gonna try tomorrow night and see if these will work in the turn signals and brake lights. If they work with out issues I am buying two more sets. JERSEY STRONG - KCCO
You'll need a couple of load resistors for the turn signals. I don't think they'll work in the brake light, as they only have one set of leads, whereas they need an extra lead for the tail light, but check the site, they might also have them for the brake/tail-light, too.
post #28125 of 45326 Old 02-17-2014, 12:04 AM
wjidaho
Why did she get towed away ?
My build thread
wjidaho is offline
wj
MacNCheese
