What did you do to your WJ today? - Page 1864 - JeepForum.com
 787Likes
post #27946 of 44780 Old 02-12-2014, 08:42 AM
wjidaho
Originally Posted by PeteYJTJ
Drove it to work, like every other day. Except today it was -8F. Man enough with the winter already.... Brrr.....
Yesterday it was in the 50s in Idaho seems winter missed again
My build thread
wjidaho is offline
post #27947 of 44780 Old 02-12-2014, 09:01 AM
cr8zynelly
Originally Posted by WJ_allday04
if that didn't look any more like a set up pic I dont what what is haha
Shhhh.
cr8zynelly is offline
post #27948 of 44780 Old 02-12-2014, 10:02 AM
Son-of-Beast
Stopped by Harbor Freight on the way home last night and grabbed a 4 1/2" Angle Grinder, a pack of Cut-Off Wheels and some Safety Shades - gonna make those rock rails fit!!
'Son-of-Beast' - '02 WJ Limited, 4.7, 545RFE 5-spd Auto, Quadra-Drive, KOR 2.5" BB, Rancho RS5000's, Firestone Destination AT 265/70R17's, Flowmaster DeltaFlow 40, KMA/TAG armor, JK Fuel Door, Spyder CCFL Halo Projectors, LED Taillights, LED Interior Lights - Build Thread:
Son-of-Beast is offline
post #27949 of 44780 Old 02-12-2014, 10:18 AM
biffs
First post here - Sunday I changed out my headlights, added a Light Bar, and started on a DIY Ski rack for the roof. Just got the Jeep about a month ago.
biffs is offline
post #27950 of 44780 Old 02-12-2014, 10:25 AM
01Sport
Welcome, biffs.
2002 Grand Cherokee Overland. 2" BB. Moab Wheels.
Sold:
2001 TJ Sport :(
01Sport is offline
post #27951 of 44780 Old 02-12-2014, 10:33 AM
golfinWJ
Getting the old girl ready for the big snow that is supposed to hit in the next couple hours. Supposed to get around 10 inches of snow...hopefully we get more
golfinWJ is offline
post #27952 of 44780 Old 02-12-2014, 10:40 AM
Son-of-Beast
Welcome biffs. FYI - in case you didn't notice, the vertical aiming adjuster for the Spyder projectors can be reached with a long screwdriver through the hole on top of the crossmember for the radiator.
post #27953 of 44780 Old 02-12-2014, 02:10 PM
rdkendrick
2003 WJ
I always thought Idaho got the same weather as Montana and the Dakotas. I guess I am wrong. I guess that's why they don't grow potatoes in Montana and the Dakotas.
Sent from my iPad using electrons
rdkendrick is offline
post #27954 of 44780 Old 02-12-2014, 02:12 PM
rdkendrick
2003 WJ
You are getting a good start. It's amazing how a new pair of headlights changes the look.
Welcome to JF!
post #27955 of 44780 Old 02-12-2014, 03:08 PM
wjidaho
Originally Posted by rdkendrick
I always thought Idaho got the same weather as Montana and the Dakotas. I guess I am wrong. I guess that's why they don't grow potatoes in Montana and the Dakotas. Sent from my iPad using electrons
Yeah I am in the treasure valley as in Boise little more mild then most of the state ha
My build thread
wjidaho is offline
post #27956 of 44780 Old 02-12-2014, 03:32 PM
brouwmat
They grow them in the Dakota's!
http://www.nppga.org
Boy it's been a year. Ready for some spring too!
Sent from AutoGuide.com App
brouwmat is offline
post #27957 of 44780 Old 02-12-2014, 05:03 PM
69junk
opened up the door, pulled the pin, tossed it in, closed the door, walked away 0_o
92 zj, 98 xj, 99 xj, 01 xj, 92 yj, 98 tj, 91 yj, 01 wj, 02 wj
I see a pattern forming here
Weehaa
69junk is offline
post #27958 of 44780 Old 02-12-2014, 05:49 PM
HiPERnx
Relocated my hid ballasts (2 x 75w). They were mounted on top of the fuse box. Now they are mounted on the underside if the batter tray. Looks much better ! Also covered the holes in the fuse box with black silicon.
Can recommend to mount big ballasts underneath the battery, lots of space for ballasts and you don't need to drill in to the body if the jeep (that can lead to rust), only drill in cheap plastic.
After shot : (forgot to take before shot)
(Yes, Saab battery in a jeep)
Shot of one of the ballasts. (Left is towards the front):
Shot of the lights (with the position lights on and the hid bulbs off):
Gustaf Nilstadius,
Jeep WG -99 v8, see ^ for full info
HiPERnx is offline
post #27959 of 44780 Old 02-12-2014, 07:35 PM
Kalel
2015 JK Wrangler
I used mine to get to an emergency shelter to help the get ready for the bad weather. CERT can be fun.
2015 Jeep Wrangler Unlimited Rubicon
Kalel is offline
post #27960 of 44780 Old 02-12-2014, 08:39 PM
Son-of-Beast
Started to cut on the mounting brackets for my TAG Rock Sliders. Measured the unibody frame rails vs the height of the mounting brackets as built, and am taking almost an inch off the top.
Measure twice, cut once - with an angle grinder (lots of fun, and sparks, and noise).
Curious about technique - for the first cut I basically cut along the tape line, made about 6 passes as I recall - with rest/cool-down periods for the cutting wheel and grinder motor between each pass - the inner brackets appear to be 3/16", while the outer brackets are thicker, about 1/4".
I am not a metal worker so want to ensure the approach I wrote, basically make a pass along the full length of the cut with grinder at speed, enough force to cut but not enough to bog down, is the right way to cut with an angle grinder.
Or can I start on an edge and get a cut all the way through the material and slowly work across the length of the cut in one long pass?
Once I finished the first cut I let it cool off then shot it with some paint to seal it against rust - any other recommendations?
Thanks
wj
99WJ539918
