What did you do to your WJ today? - Page 1851 - JeepForum.com
 1091Likes
post #27751 of 45726 Old 02-03-2014, 06:49 PM
thechainrule
Cleaned the snow off...twice!
thechainrule is offline
post #27752 of 45726 Old 02-03-2014, 06:55 PM
Son-of-Beast
2010 JK Wrangler
Started to mock-up and measure for TAG Rock Slider installation, after 4 years....
2010 JKU Rubi, 6-spd, AEV Frt, Warn 9.5, SRC Side Armor, Rancho Rr Carrier, 730RER, BFG M-T KM's
Son-of-Beast is offline
post #27753 of 45726 Old 02-03-2014, 06:56 PM
Kalel
2015 JK Wrangler
Here is the fire extinguisher pic.
2015 Jeep Wrangler Unlimited Rubicon
Kalel is offline
post #27754 of 45726 Old 02-03-2014, 07:32 PM
SpitFyre79
Just added some 2010 Wrangler Sport Rims. Time for the 2in budget boost
SpitFyre79 is offline
post #27755 of 45726 Old 02-03-2014, 08:27 PM
Kilopup
Finally got the alignment done.
-Doug 2000WJ 4.7, IRO 3", MB TKO 16 wheels, 245/75/16 Goodyear Duratrac's, Bilstein 5100's, JKS adj. trackbar, MOOG super trail boss SS
Kilopup is offline
post #27756 of 45726 Old 02-03-2014, 08:30 PM
Kalel
2015 JK Wrangler
Changed the Diff/Transfer case fluid, put on the front Diff Guard. Rear Diff Guard was wrong.
Kalel is offline
post #27757 of 45726 Old 02-03-2014, 10:10 PM
Son-of-Beast
2010 JK Wrangler
Originally Posted by ZB_WJ View Post
That's what I always say also, but I can't bring myself to pay someone else to work on it when I can do it, get upgraded parts AND still save money.
n topic: finished brakes yesterday. Feels a lot better, like it actually stops now. Front pads weren't bad at all, think I did them less than 30k ago. But one of the slide pins was toasted and the boot was torn, luckily I got the last hardware kit the parts store had. Will post up a review after a week or so.
Any update on the brake install? How are they working out so far?
post #27758 of 45726 Old 02-03-2014, 11:40 PM
rdkendrick
2003 WJ
Originally Posted by BigWheel7 View Post
Well it finally happened. I broke my driver side seat. Yes I know lose some weight. Just going to keep the darn thing until it gets warmer to even check out what the problem is but I am going to guess broken welds.
I remember someone talking about there being kits to fix WJ broken seats. Do a search, you should find it. I know I posted a link to it three or four months ago on this thread.
Sent from my iPad using my fingers
Edit** I should have read the next post before commenting.
rdkendrick is offline
post #27759 of 45726 Old 02-04-2014, 04:39 AM
cde02ltd
Is this the link?
http://www.jeepseatbracket.com
cde02ltd is offline
post #27760 of 45726 Old 02-04-2014, 08:22 AM
FailWheelDrive
Finally got my WJ with the new suspension setup put back down on it's wheels last night.
I installed IRO ajustable long arms up front, adjustable upper A arm, and adjustable lower short arms and stacked a set of Fat Bob's spacers on top of my IRO springs.
So now it's a 4" spring with 2.5" spacer in the front and a 3" spring with a 2" spacer in the rear.
Hopefully I'll get around to finishing the job tonight. Just need to:
  • adjust the trackbar
  • dial in the caster/pinion angles
  • center the steering wheel
The setup acutally looks pretty good. I'll post pics after I dial everything in and get is driving.
FailWheelDrive is offline
post #27761 of 45726 Old 02-04-2014, 09:38 AM
Jaketit
Originally Posted by FailWheelDrive
Finally got my WJ with the new suspension setup put back down on it's wheels last night. I installed IRO ajustable long arms up front, adjustable upper A arm, and adjustable lower short arms and stacked a set of Fat Bob's spacers on top of my IRO springs. So now it's a 4" spring with 2.5" spacer in the front and a 3" spring with a 2" spacer in the rear. Hopefully I'll get around to finishing the job tonight. Just need to:[*]adjust the trackbar[*]dial in the caster/pinion angles[*]center the steering wheel The setup acutally looks pretty good. I'll post pics after I dial everything in and get is driving.
Can't wait to see it. Just outa curiosity, why wouldn't you just get 6"springs, instead of using the pucks??
Jaketit is offline
post #27762 of 45726 Old 02-04-2014, 09:40 AM
DavisI
Originally Posted by cde02ltd View Post
I just checked out that link. $200 seems mighty steep to me for a seat bracket. Anyone know how well their "fix kit" works?
2002 WJ 4.7
4.5"/3.5" with 32"x10"
DavisI is offline
post #27763 of 45726 Old 02-04-2014, 10:37 AM
dcorn
Originally Posted by cr8zynelly View Post
So the heat comes out between the switches?
Yup. Might try to fashion some sort of grill in the holes to make it look better. I don't use the upper heat much anyway because the floor heat goes away when I do. Must have bad blend doors.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #27764 of 45726 Old 02-04-2014, 10:58 AM
ZB_WJ
Work great. Pretty happy. Wouldn't mind getting better pads from oreillys though. Gotta love lifetime replacement. But they stop great, haven't hauled anything yet, but they should do fine.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #27765 of 45726 Old 02-04-2014, 03:44 PM
FailWheelDrive
My IRO springs are like new, so instead of yanking them out and trying to sell them at a loss then buy new springs and pay for shipping I decided to be cheap/lazy and just drop in the spacers for $100ish.
I don't even need the lift to run bigger tires (yet) so I just kinda threw the spacers in because I have all the rest of the parts to support the taller lift.
I was cheap/lazy on the shocks too. I think my Bilstiens (also like new) are only supposed to be rated up to like 4" of lift.
I was able to get 2.5" shock extensions from a JK to work up front with the use of JK shock bushings (I had a spare set laying around from when I upgraded my JKU Sport to stiffer stock springs & Rubicon shocks) which should be fine.
The rear shocks are just going to be a little short but I'm just going to run it and hope they work ok.
wj
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
cr8zynelly , gcjeeping
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
