What did you do to your WJ today? - Page 1823 - JeepForum.com
 558Likes
post #27331 of 43591 Old 01-17-2014, 08:56 AM
Locutus
Wj
Originally Posted by Locutus View Post
4 of these in 3mm for the EVIC buttons. i also believe ( i have not looked yet. im only 75% on this) these will work for the ac and defrost buttons and the heated seats toggle. https://www.superbrightleds.com/more...l-led/220/992/
took apart the climate control and ash tray panels to check for back lighting
The ac and defrost buttons use 4mm and the toggle for heated seats use 5mm
Locutus is online now
post #27332 of 43591 Old 01-17-2014, 08:59 AM
rdkendrick
2003 WJ
took apart the climate control and ash tray panels to check for back lighting The ac and defrost buttons use 4mm and the toggle for heated seats use 5mm
NEOX twist out style? AZC?
Sent from my iPad using my fingers
rdkendrick is offline
post #27333 of 43591 Old 01-17-2014, 09:02 AM
Trxgedy
Anyone ever do the window and lock button lights in the doors?
Trxgedy is offline
post #27334 of 43591 Old 01-17-2014, 09:13 AM
LonestarWJ
Originally Posted by Trxgedy
Really? Do you rub?
I haven't wheeled it. I'm sure it would rub if it flexed but on the street it rubs a little if I crank it hard sometimes.
LonestarWJ is offline
post #27335 of 43591 Old 01-17-2014, 09:26 AM
cr8zynelly
Originally Posted by alfaitalia
It makes no difference at all if it is just the usual doors breaking up at the hinges (both mine had failed) whether its pass or drivers side. You get at them both from through the glove box. He may have meant its a problem if its the servo failure (much rarer) as to get to the back one its a dash out job. If that had happened its easier to link both the doors together so temp is just controlled from one temp knob. Most likely it will just be replacing the two doors and you are good to go as it is with most of us.
Alfa is right. I forgot to mention that I always have the "much rarer" problems happen to my jeep. I jumped the gun a wee bit. I actually had the actuator break but luckily it was the one controlling the heat to drivers side. So I could just go thru the glove box and it was right there.
cr8zynelly is offline
post #27336 of 43591 Old 01-17-2014, 09:31 AM
Locutus
yes sorry i forgot the link
here it is and its back in the quote above
post #27337 of 43591 Old 01-17-2014, 09:32 AM
Locutus
Wj
if you search this thread there is some info on that. they are hard wired in. you would have to remove the old and solder in new ones
post #27338 of 43591 Old 01-17-2014, 10:06 AM
ZB_WJ
Originally Posted by aralph30
Other guys insurance is covering everything
Go to the dealership for an estimate now if you can. That way you already have an idea on the damage. I got rearended right before Xmas and it netted me almost 3 grand for a cracked bumper, busted taillight and dent in rear quarter panel. Cost me less than $300 to fix and I got a 2012 maxima to drive for a week, been used to driving the 4.slo and the maxima was sooo fast I romped it the whole week.
What insurance does he have?
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #27339 of 43591 Old 01-17-2014, 10:17 AM
Starboard M
Originally Posted by LonestarWJ View Post
Installed my led light bar
Attachment 1004137
Attachment 1004145
What bar is that, and can you take any more pictures of how you mounted it to the rails?
Originally Posted by NoVaHunter View Post
Honestly, its dicks like you that make unnecessary comments via the internet that have no impact what so ever.
Starboard M is offline
post #27340 of 43591 Old 01-17-2014, 10:33 AM
Locutus
Wj
I put LEDs in the vanity mirrors and glove.
FYI 4mm do not fit in the EVIC. and the bulb i got for the glove does not fit in the ashtray. it needs a smaller diameter.
ordering LEDs for the ac/defrost buttons and for the heated seat toggles
post #27341 of 43591 Old 01-17-2014, 10:46 AM
rdkendrick
2003 WJ
I put LEDs in the vanity mirrors and glove. FYI 4mm do not fit in the EVIC. and the bulb i got for the glove does not fit in the ashtray. it needs a smaller diameter. ordering LEDs for the ac/defrost buttons and for the heated seat toggles
Strange, I got the Neo-x 3mm to work in my EVIC. They are a little small for the hole they go in, meaning they slide side-to-side, but they work when tightened down. Are you sure the neo-x twist in socket LED works in the dual-climate AZC heater/AC control unit? I had ALWAYS read they were solder in only. This link says instrument panel, meaning gauge cluster. You can re-use the socket for that, and it takes a pc74. Not sure if we are talking about the same thing.
If they work, that is awesome and I thank you so much for sharing. I will order some as soon as you confirm my question. I still need the marker lights for the inside of the front doors, and the inside of the grab handles on each door.
post #27342 of 43591 Old 01-17-2014, 10:47 AM
Locutus
dual zone CC are soldered in. single zone are replaceable
post #27343 of 43591 Old 01-17-2014, 10:49 AM
EmersonHart13
165k miles so it was time to replace the suspension, so I decided to do a cheap lift. Fat Bob's 2.5/2.0 spring and shock lift and used JKS adjustable track bar with all new Isolators. I also added the rear Addco sway bar. It has about 1/2 mile on it so it needs to settle still.
First 3 are before, last 6 are after.
EmersonHart13 is offline
post #27344 of 43591 Old 01-17-2014, 10:53 AM
rdkendrick
2003 WJ
RATS! Does anyone have the LED part number for the solder in LED for the dual CC? I have been searching and searching, but cannot find anything that tells me what it is. If not, just like my white-faced gauge cluster, I'll live with it, sigh.
post #27345 of 43591 Old 01-17-2014, 10:54 AM
rdkendrick
2003 WJ
Originally Posted by EmersonHart13 View Post
165k miles so it was time to replace the suspension, so I decided to do a cheap lift. Fat Bob's spring and shock lift and used JKS adjustable track bar. I also added the rear Addco sway bar. It has about 1/2 mile on it so it needs to settle still. First 3 are before, last 6 are after.
Niiice. 3 inch? I like those rims.
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
akinshake , WJ_MOOSE
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
