What did you do to your WJ today? - Page 1814 - JeepForum.com
 909Likes
post #27196 of 45328 Old 01-12-2014, 02:35 PM
BasuraBlanco
Bought a new catalytic converter to be able to pass state emissions testing.
Levi U.
2002 WJ 4.7 H.O.
"Its people like me that make people like you need medication."
BasuraBlanco is offline
post #27197 of 45328 Old 01-12-2014, 02:43 PM
Jaketit
How much that set you back?
Jaketit is offline
post #27198 of 45328 Old 01-12-2014, 02:50 PM
BasuraBlanco
It was only $105 for the universal. I am not getting the ones for the down pipes.
Levi U.
2002 WJ 4.7 H.O.
post #27199 of 45328 Old 01-12-2014, 02:53 PM
Thomahawk
Originally Posted by 2ndhandWJman
Pardon my ignorance, but how can you visually tell a lifter has gone bad? I'm not at all familiar with this 4.7 engine..
Your right, misunderstanding after looking at youtube vids, new lifters can be compressed, lifters full of oil wont, therefor assuming, since rocker arms still was in place, and cant find anything Ells wrong, and stetoscop doctor best bet is 99% on cam lifter noise, not valve.
Buildthread
Thomahawk is offline
post #27200 of 45328 Old 01-12-2014, 03:31 PM
rdkendrick
2003 WJ
Originally Posted by Thomahawk View Post
A103 socket i believe.
Socket? The bulbs in the CC have no socket. They are soldered directly into the circuit board. Unless I am misunderstanding you.
Sent from my iPad using my fingers
rdkendrick is offline
post #27201 of 45328 Old 01-12-2014, 03:35 PM
rdkendrick
2003 WJ
Originally Posted by Locutus View Post
5 of these for the gauge backlight https://www.superbrightleds.com/more...l-led/709/974/ 4 0f these for the heater controls. You will have to remove the old bulb from the twist socket and replace with these https://www.superbrightleds.com/more...base/228/1069/ 4 of these in 3mm for the EVIC buttons. i also believe ( i have not looked yet. im only 75% on this) these will work for the ac and defrost buttons and the heated seats toggle. https://www.superbrightleds.com/more...l-led/220/992/ under the hood https://www.superbrightleds.com/more...toon/244/1166/ third brakelight https://www.superbrightleds.com/more...-base/203/899/ ashtray and glove https://www.superbrightleds.com/more...-base/199/874/ vanity lights https://www.superbrightleds.com/more...toon/243/1162/ or if you want to be blind when you open the vanity http://www.ebay.com/itm/291002745677...84.m1423.l2649 this is as far as ive researched
The dual climate bulbs have no socket, from what I have researched, and are soldered directly into the circuit board.
Thanks, anyway. I still need heated seat LED's and the vanities.
post #27202 of 45328 Old 01-12-2014, 03:36 PM
rdkendrick
2003 WJ
Yeah, but the risk was part of the deal, i know i might got to eager on this phurcase, and some vacuum and exhaust leak noises covered over this tick, but learning new things (the hard Way), and still if i need to replace the whole F engine i will do... The HO have been a dream that luckily happened accidently, only 270pc sold here in 04, so they Are very rare, glad i have one, will replacec every F part needed until its perfect.
That's the spirit!
post #27203 of 45328 Old 01-12-2014, 04:06 PM
atvlifestyle
Made room for and put 285/75/16's on my 02.
atvlifestyle is offline
post #27204 of 45328 Old 01-12-2014, 04:18 PM
Hlude1
What size lift Nd how much trimming in the rear?
Hlude1 is offline
post #27205 of 45328 Old 01-12-2014, 04:23 PM
golfinWJ
Fixed the check engine light by finally putting on the new O2 sensor, which took several weeks to get due to several people ordering the wrong one. And put on a new battery connector after I broke the factory one trying to tighten up the connections
golfinWJ is offline
post #27206 of 45328 Old 01-12-2014, 04:37 PM
atvlifestyle
It sits on a pretty hokey 6" lift. Its still sitting the way it was setup when I got it. I did not trim the back yet because I plan to do a proper 6" suspension before it hits the trails and currently only rubs alittle.
post #27207 of 45328 Old 01-12-2014, 04:40 PM
Hlude1
Is that a short arm 6" lift or do you have spacers on top of 4" springs
Hlude1 is offline
post #27208 of 45328 Old 01-12-2014, 04:43 PM
4x4Jeep
replaced my drivers side axle shaft today.
Build -
SOLD
4x4Jeep is offline
post #27209 of 45328 Old 01-12-2014, 05:01 PM
atvlifestyle
Best I can figure is that it has the Rough country X 4" with 2" spacers.
post #27210 of 45328 Old 01-12-2014, 05:53 PM
Highschool_WJ
Originally Posted by cykaaro
Usually it's the idler or the belt tensioner pulleys. I just did mine this summer. Maybe just change them both to be safe, and if one of them is still good, keep for a spare. Only my alternator makes a racket now.
It was the idler pulley, however good old O'Reilly's parts were the right size but don't attach quite the same way :/. (I work there though so it was worth a try cause of my employee discount). Tomorrow I'll be going down to carquest to get the right one
,,,soooo I graduated in 2013...
Highschool_WJ is offline
wj
GhostJeepWJ
