What did you do to your WJ today? - Page 1771 - JeepForum.com
 826Likes
post #26551 of 45004 Old 12-17-2013, 01:42 PM
LarryDallas
Put a nice dent in the rocker panel under the passenger door and crunched the pinch seem a bit. Ordered sliders from JRC the end of November but couldn't wait to go have some fun. They will finally arrive this Friday so i will ahve them on before my next outing. Christmas present for me!
2001 WJ 4.7L Quadra-drive, UC springs w/ 2" BB, Bilstein 5100s, double cardan front axle swap, Moog Trail Boss SS, 245/70/17 General Grabber AT2 tires,
1.5" Spidertrax spacers, Rola rack, Uniden CB w/ 4' Firestik, JCR Stage 3 rock sliders, JKS HD Adj. track bar, IRO 3" rear sway end links, Akebono swap.
LarryDallas is offline
post #26552 of 45004 Old 12-17-2013, 02:11 PM
Locutus
Wj
Originally Posted by Hytek View Post
Washed the salt off.
Ditto
Its snowing like a MoFo here in Boston. ill be going out at midnight to do some 4 wheel drifting
Locutus is online now
post #26553 of 45004 Old 12-17-2013, 02:24 PM
brouwmat
Originally Posted by PeteYJTJ View Post
Drove mine to work. Brr..... That says -2F
Ha! -18 the other day here!
Sent from AutoGuide.com Free App
brouwmat is offline
post #26554 of 45004 Old 12-17-2013, 04:50 PM
joshtarmy1
Ran some sea foam through the vacuum line and some in the tank. It seemed to run a bit better at first but right back to misfiring on cyl 7 again this morning. Time to swap some injectors.
joshtarmy1 is offline
post #26555 of 45004 Old 12-17-2013, 04:53 PM
aralph30
2003 WJ
Someone wanna help I can't get the stupid running boards off :/ the bolts r stuck
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #26556 of 45004 Old 12-17-2013, 04:59 PM
1999wjlimited
Spray them down and let them soak with pb blaster.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #26557 of 45004 Old 12-17-2013, 05:45 PM
Hytek
That's exactly how I got mine off. Took a few days of spraying and letting them soak though.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #26558 of 45004 Old 12-17-2013, 05:50 PM
Chris00WJ
Today I got my Elmscan 5 compact USD OBDII cable in the mail. And I ordered the Lava OTG & Charging cable for my Galaxy Tab 2 10.1.
The mount should be here any day too. I also downloaded Torque and a new theme pack for it. I need a few more things to get everything buttoned up and installed properly, but the system is well on its way. Huge thanks to Theksmith for his writeup with his xoom. It got me wanting to do it with my tab!
Still waiting for the fender flares in the mail. I'll likely be waiting atleast another month. Oh well.
Chris00WJ is offline
post #26559 of 45004 Old 12-17-2013, 05:52 PM
WJ_allday04
Went winter "urban" wheeling in parking lots the last 3 days here in WNY...gotta love the lake affect snow changed the plugs as well and threw in new low beam bulbs since one of my fog lights died and i dont feel like chipping the ice off.
2004 WJ 4.7 - 7in lift
Rustys Long Arms//Rustys f+r springs//Rustys crossmember
CSL RLCA//Poly D30 bushings//IRO A arm
Skyjacker Nitro's//JKS trackbar//242HD+IRO SYE
WJ_allday04 is offline
post #26560 of 45004 Old 12-17-2013, 06:07 PM
platinum5.9
2003 WJ
WJ_allday04 Dunkirk NY huh. I'm in Olean not to far from you.
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #26561 of 45004 Old 12-17-2013, 07:39 PM
Jeeples
Jeeples's Avatar
Noticed the engine was chugging at idle and sputtering when taking off from a stop on my '00 4.7. No CEL or codes stored. I changed the plugs last weekend and noticed one of my coils was cracked near the tip where the plug seats. On a hunch I went ahead and pulled that coil, here's what I found:
Yep, looks like the coil is arching against the spark plug tube through the crack. Good news is since my wife's WJ is down with a leaky water and PS pump, I'll just rob a coil from her WJ until my Mopar replacement from Amazon shows up.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #26562 of 45004 Old 12-17-2013, 08:27 PM
pmdowd6
Just curious as to why you didn't go with a wireless bluetooth OBDII plug in? That's what I was planning to do and to hook it up with the torque app
pmdowd6 is offline
post #26563 of 45004 Old 12-18-2013, 04:16 AM
texlurch
Ordered my 285/75 Duratracs.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #26564 of 45004 Old 12-18-2013, 06:29 AM
spud2388
This was over the weekend, but changed out the intake/exhaust manifold gasket, valve cover gasket, CCV elbows and grommets, throttle body gasket, and cleaned and checked everything for any vacuum leaks. Wasn't too hard of a project, except the bottom manifold bolts that were impossible to find without having somebody else guide my ratchet from underneath. The only hickup was I cracked my intake when I was installing it. It must have been caught on something and when I attempted to install the third bolt, it cracked all the way through the 3rd intake runner, about 80% around (the aluminum around the injector hole held it together). Ended up taking it to a family friend and he welded it up for $30, so I got off lucky there. I couldn't find anywhere on the gasket where it was leaking, but the newer gasket seemed to be made better and I have not heard any whine since. It also runs smoother now, idle and everything.
Intake ports after I pulled them off. Kinda gunky in my opinion...
spud2388 is offline
post #26565 of 45004 Old 12-18-2013, 08:31 AM
Thomahawk
Replaced Crank case > intake tubing + Fuel filter today, easy 30 min Fix
Buildthread
Thomahawk is offline
wj
CarolinaWJ25
