What did you do to your WJ today? - Page 1769 - JeepForum.com
 864Likes
post #26521 of 45171 Old 12-16-2013, 08:01 PM
cde02ltd
Originally Posted by Hytek
Put stock shocks back on. Lesson learned: Monroe Sensa-trac shocks suck! On a positive note, I can now swap front and rear shocks in less than an hour now lol. Going for Bilsteins after Xmas.
What was bad about them? I was considering them, I am on my 3rd set of oem shocks, and only have 78k on it.
cde02ltd is offline
post #26522 of 45171 Old 12-16-2013, 08:15 PM
Hytek
They were pretty harsh for a supposedly smooth ride. Any roads with washboard type bumps made it unbearable, almost like a bucking bronco. I had a mustang with lowering springs on it and it rode comparable to that. It was like any road imperfection was amplified. When I came to a stop it bounced back and forth like a pogo stick. My lifted zj rides smoother. I'm sure after a few thousand miles it's not as bad but I don't have the patience to wait.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #26523 of 45171 Old 12-16-2013, 08:16 PM
rdkendrick
2003 WJ
Thanks, I will avoid them. I have been looking at shocks when I do my BB. Bilsteins seems to be in the lead.
Sent from my iPad using my fingers
rdkendrick is offline
post #26524 of 45171 Old 12-16-2013, 08:21 PM
Hytek
I only went that route because they were under $100 and had a rebate. I had Bilstein HD's on my ZJ with a bb and it was great, rode better than stock. Now with the IRO 3.5 lift I have Bilstein 5100's and it still rides great. I must've had a brain fart when I got Monroe for the WJ...but I'm back to reality now lol.
Hytek is offline
post #26525 of 45171 Old 12-16-2013, 08:43 PM
BOVWJ
Got the roof rack all done being fab'd and dropped off to get powder coated Get to pick it up in the morning cant wait. I'll post more picks when I get it back.
BOVWJ is offline
post #26526 of 45171 Old 12-16-2013, 09:42 PM
scorch05
Wasn't today but over the weekend I changed out the tstat. Found out that the radiator drain petcock is clogged or otherwise inoperable which made a 1 hour job into a 3 hour one.
scorch05 is offline
post #26527 of 45171 Old 12-16-2013, 09:43 PM
NOTW_WJ
Replaced my fuel filter and while I was under there, I noticed ANOTHER leak. I already have a leak at the input shaft of the transfer case and now I noticed oil running down the oil pan!! I'm hoping it's only the oil pan gasket and not the rear main leaking. At 118K, I'm wondering if I'm going to have to start going through the drive line one by one and freshening them up. I already have most of the parts to rebuild/upgrade the transfer case and It would be so much easier to pull and rebuild the engine/trans/transfer case at once but there's NO way i can afford that right now!!!
NOTW_WJ is offline
post #26528 of 45171 Old 12-16-2013, 10:07 PM
CheapGuy
2009 WK
You'll love the Bilsteins. Worth the money.
Crazy story - It was cold outside a few weeks ago and my SES light came on so instead of doing what I normally do - fix it myself, I dropped it off at a local shop. While it was there I told them to also check a clunk in the front end. They called me and said it looked like my shocks were OEM and likely the problem and suggested I go with Monroe Sensa-tracs! I didn't say anything until I got to the shop and said are you guys serious? I pointed out that Bilsteins have the distinct blue/yellow color which was easy to see. They said they were so dirty that they "'looked" like OEM despite the fact that I had washed it three days earlier. Needless to say I won't be going back to that shop; in fact I question if the SES fix was legit now.
Anyway - Lately my ignition switch has been acting up - not turning. After the shop experience today I just fixed it myself, including changing the tumblers. Easy half hour job, with most of that changing the tumblers.
2009 Grand Cherokee Limited - 4.7l, Quadra-Drive, Black Metallic
"My Cars are My Man Caves"
CheapGuy is offline
post #26529 of 45171 Old 12-16-2013, 10:10 PM
03azwj
2003 WJ
X2 second that. Have had mine for about a year and they ride great.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #26530 of 45171 Old 12-16-2013, 10:13 PM
mdrum93
Originally Posted by 03azwj
x2 second that. Have had mine for about a year and they ride great.
x3!
Bumper Thread
mdrum93 is offline
post #26531 of 45171 Old 12-16-2013, 10:20 PM
wjidaho
You'll love the Bilsteins. Worth the money. Crazy story - It was cold outside a few weeks ago and my SES light came on so instead of doing what I normally do - fix it myself, I dropped it off at a local shop. While it was there I told them to also check a clunk in the front end. They called me and said it looked like my shocks were OEM and likely the problem and suggested I go with Monroe Sensa-tracs! I didn't say anything until I got to the shop and said are you guys serious? I pointed out that Bilsteins have the distinct blue/yellow color which was easy to see. They said they were so dirty that they "'looked" like OEM despite the fact that I had washed it three days earlier. Needless to say I won't be going back to that shop; in fact I question if the SES fix was legit now. Anyway - Lately my ignition switch has been acting up - not turning. After the shop experience today I just fixed it myself, including changing the tumblers. Easy half hour job, with most of that changing the tumblers.
Sounds like a shop I had some bad experiences when I had my Toyota truck, the worse problem was when I was working 60 hours a week and I had a head gasket blow took it to a local shop, they changed it and when I went to pick it up they told me my oil pump was no good and they would have to go back in, I asked if they would redo the head gasket for no charge since that way why I hired them they said no. Then I asked when did they notice the oil pump they said when they first started, so I asked why did they not call and let me know all I got was I don't know. Need less to say I took it home and re did all the work they did plus fix my oil pump. Since that day I do not trust any shop. I did get revenge because of me they are no longer in business. I sat in front of their shop on public sidewalk and stopped their work for months on my free time. And went to the bbb. I think what really did it to them was word of mouth. I still bad mouth that shop haha
My build thread
wjidaho is offline
post #26532 of 45171 Old 12-16-2013, 10:47 PM
Timbo24
What shop?
Timbo24 is offline
post #26533 of 45171 Old 12-16-2013, 11:00 PM
wjidaho
A shop in CDa I think it was called Jimmy's imports
My build thread
wjidaho is offline
post #26534 of 45171 Old 12-16-2013, 11:04 PM
wjidaho
Originally Posted by Timbo24
What shop?
Have you checked out that overland/expedition thread? I think that what our Wjs are best for
My build thread
wjidaho is offline
post #26535 of 45171 Old 12-17-2013, 12:36 AM
Kilopup
Detailed it for the first time in 6 months. After the engine seized way back in June I just left it sitting in the driveway to collect dust until I scrounged up the cash to put a refurbished engine in. 400 miles left for the "break in" of the engine. I also started to PB blast the nuts and bolts to install my IRO 3" lift next Monday. Figured I'll give it a week of spraying just to make sure I don't break any bolts. (Fingers crossed).
-Doug 2000WJ 4.7, IRO 3", MB TKO 16 wheels, 245/75/16 Goodyear Duratrac's, Bilstein 5100's, JKS adj. trackbar, MOOG super trail boss SS
Kilopup is offline
wj
MrAb3z , Redjeepwj
