What did you do to your WJ today? - Page 1766 - JeepForum.com
 925Likes
post #26476 of 45352 Old 12-14-2013, 09:31 PM
ZB_WJ
Got rearended, too dark for pictures
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #26477 of 45352 Old 12-14-2013, 10:55 PM
Trxgedy
Just some pics from today
Sent from the front lines of the zombie apocalypse.
Trxgedy is offline
post #26478 of 45352 Old 12-14-2013, 11:12 PM
PhantomWJ
2003 WJ
35's....
Stil need to trim...but it is street drivable at this time.
PhantomWJ is offline
post #26479 of 45352 Old 12-15-2013, 09:39 AM
Son-of-Beast
2010 JK Wrangler
Reporting back in on seat heater replacement, the Dorman kit is great, went in easy and works - Wifey will have toasty buns on Christmas Trek.
I found that if I got a corner or edge of the original pad up with the x-acto I could fold it back flat 180 degrees and pull it off without damaging the foam.
Sorry no pics, I was on a mission.
2010 JKU Rubi, 6-spd, AEV Frt, Warn 9.5, SRC Side Armor, Rancho Rr Carrier, 730RER, BFG M-T KM's
Son-of-Beast is offline
post #26480 of 45352 Old 12-15-2013, 10:23 AM
cykaaro
Been getting a p1763 code here and there. Two days this week put the transmission in limp mode. Once the code is clear all is fine until it decides to trip again. It's always when I start up leaving work that it happens. Go figure. Wiring checked out fine so was looking like the sensor. Had a tramsmission shop take a look and was show it was acting a bit flakey. Got it changed and the filter since it was opened up. Hopefully this will fix the issue, and it is shifting better. Asked about if the bands needed adjustment etc. Said everything is working exactly as it should. Just in the summer when I do a fluid change and service to change the selenoid as well. We'll see but hope that the issue is fixed.
Hard enough dealing with the posibility of losing everything right now unless I can get a second job, but at least I'm still working as long as the jeep is running and can get me there since there's no transit where I am. Not looking like a very good end to the year and beginning of the next. Hoping that the sensor is indeed the issue as the code is saying and not something else worse.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #26481 of 45352 Old 12-15-2013, 10:47 AM
Jason1992
fixed the recirculation door today so have air flow again
also disconnected front tweeters and had a quick go cleaning the headlights up a little looking better now
Jason1992 is offline
post #26482 of 45352 Old 12-15-2013, 03:24 PM
joshtarmy1
Swapped in some new battery terminals. Haven't gotten a chance to do the fuel filter. Might send it over to the shop next to my work tomorrow. Haven't had the time to do it.
joshtarmy1 is offline
post #26483 of 45352 Old 12-15-2013, 05:16 PM
no2tracks
New led taillights. Fixed brake switch which was leaving the brake lights on while I walked away. Replaced third brake light bulb.
2000 Wj Laredo,4.0, New struts & wipers, 2"BB from Fat Bob's, Bilstein 5100's, General Grabber AT2's studded, Rancho steering stabilizer, Rugged Ridge floor mats, led taillights.
no2tracks is offline
post #26484 of 45352 Old 12-15-2013, 06:55 PM
TJSWJ
Ordered a switch, relay, solenoid, and battery box for the dual battery upgrade.
TJSWJ is offline
post #26485 of 45352 Old 12-15-2013, 07:46 PM
Hytek
Thought I fixed my front end rattle by replacing the shocks but no. The upper bushings were shot and I was sure as hell that was it. Now I'm thinking it's the upper or lower spring retainers. Only happens when cold out and hitting bumps. Any thoughts on them causing it?
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #26486 of 45352 Old 12-15-2013, 08:57 PM
gcjeeping
gcjeeping's Avatar
Where are you putting the 2nd batt?
_____________
gcjeeping is offline
post #26487 of 45352 Old 12-15-2013, 09:26 PM
mdrum93
Is there a thread for this?
Bumper Thread
mdrum93 is offline
post #26488 of 45352 Old 12-15-2013, 09:30 PM
Highschool_WJ
Ive been told this happens in cold weather when the front sway bar bushings are worn out. I have the same problem and intend to solve it over winter break from school by trying this
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #26489 of 45352 Old 12-15-2013, 10:09 PM
gcjeeping
gcjeeping's Avatar
Mine.... http://www.jeepforum.com/forum/searc...9&pp=20&page=2
Was wondering how he was gunna do his.
Also theksmith did one too... http://offroadpassport.com/forum/showthread.php?p=28671
_____________
post #26490 of 45352 Old 12-15-2013, 10:13 PM
wjidaho
Originally Posted by gcjeeping
Mine.... http://www.jeepforum.com/forum/searc...9&pp=20&page=2 Was wondering how he was gunna do his. Also theksmith did one too... http://offroadpassport.com/forum/showthread.php?p=28671
I like yours the best just wish I had half your skills
My build thread
wjidaho is offline
wj
