What did you do to your WJ today? - Page 1761 - JeepForum.com
 861Likes
post #26401 of 45153 Old 12-09-2013, 09:50 AM
DarkStarr
2003 WJ
Originally Posted by Locutus View Post
Yep
just bought them
We had a set for our 01 (but we paid full price from amazon for those) and since I now have my 03 I needed a set and I noticed the price. It dropped since I ordered mine in fact, however amazon gave me back the difference. I may pick up the full back set for mine though in addition to the front set.
Originally Posted by 03azwj View Post
How well do those fit in the dub? Soery I didn't see what they were specifically for.
They are exact fit for the front. Rugged Ridge makes exact fit mats for vehicles. We have a set up front on our 01 and I really like em.
DarkStarr is offline
post #26402 of 45153 Old 12-09-2013, 11:20 AM
TwinchargedRX7
How did you get amazon to give you back the difference? I ordered mine last week and had to pay full price
TwinchargedRX7 is offline
post #26403 of 45153 Old 12-09-2013, 11:48 AM
rugsWJ
Originally Posted by dcampbell4 View Post
Where did you get that shorty antenna? Looks very clean I like it.
Amazon for $15 dollars. 5 inch billet screwed on in 5 seconds.
Follow my build on Instagram ---> @mattruggiero
rugsWJ is offline
post #26404 of 45153 Old 12-09-2013, 02:36 PM
WJefy
Put 20.124 gallons of gas in it.
WJefy is offline
post #26405 of 45153 Old 12-09-2013, 02:54 PM
DarkStarr
2003 WJ
I just called em. I had paid $46.83 and when I called I got the $6.73 back but it has dropped even more. If it drops again I may see about trying to get that as well but if it stays here its not even $3.
post #26406 of 45153 Old 12-09-2013, 03:03 PM
aestrad1
Swapped in a 242HD T Case. Love the extra drive options!
aestrad1 is offline
post #26407 of 45153 Old 12-09-2013, 04:57 PM
Chris00WJ
Ordered the knockoff Iceland flares from ebay. Im pretty proficient in fiberglass so Im not too worried about any mods they might need (like adding the hardware for mounting).
Also started buying parts to integrate my Galaxy tab 2 into the WJ.
Chris00WJ is offline
post #26408 of 45153 Old 12-09-2013, 04:59 PM
wjidaho
Originally Posted by Chris00WJ
Ordered the knockoff Iceland flares from ebay. Im pretty proficient in fiberglass so Im not too worried about any mods they might need (like adding the hardware for mounting). Also started buying parts to integrate my Galaxy tab 2 into the WJ.
eBay flares ?? Link please
My build thread
wjidaho is offline
post #26409 of 45153 Old 12-09-2013, 05:01 PM
docster
started dipping my new wheels. Couldnt use index cards, so ill have to peel off tires later. Its going to take a few days since its been in the teens and I am needing to wait about an hour for each coat to get a little tacky, even with the heater blasting in the garage. But hey, took the fat bike out for a few rides while it was drying, so that was fun.
Pictures do no do it justice.
2002 WJ Ltd. QD, 4.7L. , Superchips, Magnaflow 12256 muffler and custom 3 inch piping, 2" IRO springs, Procomp 9000 Shocks, JK Moabs, 265/65/17 tires, Moog SS.
Diff fluid change DIY, http://www.jeepforum.com/forum/f310/official-diff-fluid-change-diy-1534883/
docster is offline
post #26410 of 45153 Old 12-09-2013, 05:24 PM
206wj
Went and got a tree in the Mountains today! Didn't take pics with the tree on the jeep cuz I got dirty as hell dragging it off the side of the Mountain.
Was a great time though. I did realize I should get some bump stops though since I'm not running any in the front right now.
Factory 242HD, 4.5 Lift with LAs, 285/70/17s, OME SS, Arb Front bumper with WARN 9.5xp with MasterPull synthetic line, Piaa 550 Driving lights, JCR sliders, Custom rear bumper with tire carrier, and piaa 510 backup light, ARB, 4.56 Gears, Viair 200psi OBA kit with dual tanks, LED rock lights,
206wj is offline
post #26411 of 45153 Old 12-09-2013, 05:31 PM
Chris00WJ
http://www.ebay.com/itm/JEEP-GRAND-C...ae3763&vxp=mtr
post #26412 of 45153 Old 12-09-2013, 05:41 PM
mollydodger
2009 FSJ Cherokee
2004 stock commuter w/64K
R&R Valve cover gasket
R&R Thermostat
R&R front and rear diff fluids
R&R shocks
R&R serp belt
R&R spark plugs
Found wiring harness at back of valve cover damaged from wear against bolt. Repaired.
Broke the wiring harness support at rear of block
Broke the plastic tube between the valve cover and intake manifold
Off to stealership tomorrow for tube and wiring harness
mollydodger is offline
post #26413 of 45153 Old 12-09-2013, 06:14 PM
Timbo24
i am thinking about getting some of these and selling my bushwhackers. They would look a lot better with my iceland bumper
Timbo24 is offline
post #26414 of 45153 Old 12-09-2013, 06:45 PM
derekmac
Originally Posted by derekmac View Post
I finally got around to changing my output speed sensor. It sure is nice to have full use of 1st and OD!
Originally Posted by narnwv View Post
Any insight as to what diagnostics lead you to replace that speed sensor?
I had code P0731 come up. I had this same code about two years ago and replaced the input speed sensor.
The Jeep would only stay in 1st until 20kph then would shift hard out of that gear. I also had no overdrive. Both of these symptoms were the same as when the input speed sensor went, so I figured since I already replaced that one, it must be the other, and it was.
I also did test both sensors with my multi-meter set on the 2k ohm setting, and the bad one didn't have any reading, while the good one and new one were in the 500 range I believe.
2005 TJ Rubicon
derekmac is offline
post #26415 of 45153 Old 12-09-2013, 06:56 PM
wjidaho
Do it Tim and I will buy your bushwhackers if the price is right,, or better yet I will buy them for you and you give me your bushwhackers lol
My build thread
wjidaho is offline
wj
