What did you do to your WJ today? - Page 1759 - JeepForum.com
 1173Likes
post #26371 of 45902 Old 12-08-2013, 11:23 AM
TwinchargedRX7
Finally new wheels and tires.
-JK moabs painted black
- general grabber 245/70/17. Multiple threads say that's the largest that will fit in the spare well. But that must not be for A/T tires. These go in, but don't sit all the way down in the well so the rear cover won't close all the way
Before:
After:
I love it. This is on a Kodak HD lift with OME HD's and bilsteins. No I have to move on to fixing a bunch of stuff (heater core, airbag control module, rear wishbone control arm and ball joint, etc....
TwinchargedRX7 is offline
post #26372 of 45902 Old 12-08-2013, 11:41 AM
alfaitalia
Looks really good. If you have on board air or carry a compressor like me, you could always try airing down the tyre a bit (or a lot!) to see if it will squeeze into the well a bit lower down.
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #26373 of 45902 Old 12-08-2013, 11:42 AM
platinum5.9
2003 WJ
TwinchargedRX7 the WJ look OKs real nice but I would of gone with bigger tires.
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #26374 of 45902 Old 12-08-2013, 11:51 AM
Teflon916
Drove mine through the snow for the first time yesterday. Drove from sacramento to Tahoe.At fist I was really put off by the way the quadradrive acted. I would be driving around a bend, I would start getting some oversteer then I would shoot back straight once the fronts kicked in. I didn't like it at first and thought selec trac part time mode would be so much better for this. After driving for a while and having the same thing happen on numberous occasions I found out that giving a little gas while going around the corners actually helped with control. Kind of seemed like the Tc would get more responsive as I kept breaking loose. Like the transfer case had to warm up. If that makes any sense. Might be my imagination. I did a few doughnuts in a parking lot and scared the **** out of myself. Thought I was going to tip over. Never done that before either. By the end of the journey I was quite happy and satisfied with how the wj performed and I'm in no hurry to swap my tc.
Sent from the top of my VISA card
Teflon916 is offline
post #26375 of 45902 Old 12-08-2013, 11:57 AM
alfaitalia
Strapped a Christmas tree to the roof to get it home from the hardware store. Christmas is a comin'. Can't wait. Who says Christmas us just got kids!
post #26376 of 45902 Old 12-08-2013, 12:34 PM
Thomahawk
2006 XK Commander
Originally Posted by TwinchargedRX7
Finally new wheels and tires. -JK moabs painted black - general grabber 245/70/17. Multiple threads say that's the largest that will fit in the spare well. But that must not be for A/T tires. These go in, but don't sit all the way down in the well so the rear cover won't close all the way Before: After: I love it. This is on a Kodak HD lift with OME HD's and bilsteins. No I have to move on to fixing a bunch of stuff (heater core, airbag control module, rear wishbone control arm and ball joint, etc....
That look tits for sure, what kinda grill is That?
I likeee
Buildthread
Thomahawk is offline
post #26377 of 45902 Old 12-08-2013, 01:11 PM
rugsWJ
Found a some trails near my house. Did a quick drive through last night and getting some friends to come again today.
Follow my build on Instagram ---> @mattruggiero
rugsWJ is offline
post #26378 of 45902 Old 12-08-2013, 01:52 PM
dcampbell4
Where did you get that shorty antenna? Looks very clean I like it.
dcampbell4 is offline
post #26379 of 45902 Old 12-08-2013, 01:56 PM
lvngtheJEEPlife
Originally Posted by 04dubjay View Post
TIghtened up pitman arm to gear box because I had lots-0-play! Also installed a class 3 hitch I got from a buddy for 80 bucks (brand new condition)! Been waiting about a year to get one second hand!
Did it actually help?
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #26380 of 45902 Old 12-08-2013, 02:22 PM
joshtarmy1
Changed my oil, transfer case fluid. Put in a new pcv and tps. found a broken ground strap going from the transmission to the frame so I replaced the with new connectors and a new wire. Also cleaned and sealed my wheels and flipped them so I got white letters out now.
joshtarmy1 is offline
post #26381 of 45902 Old 12-08-2013, 02:40 PM
1999wjlimited
Originally Posted by vanillathrilla
It's a little dark for her anyway... I was thinking about having it re-tinted somewhere around either 35% or 50%. The other reason for wanting to strip it, aside from the ticket, is because we bought it with an issue with the tint on the drivers side door. The tint is ripped and torn a little bit at the bottom in a little triangle. Not a big deal, but enough to bother me. Not bothered enough to have ripped it off yet, but it'll come off. As for court, all I have to do is take a picture of a navy blue WJ to court without any tint on it and I guess that should do the trick. LOL!
I had to take mine down to the dmv and let one of the state troopers look at mine so they would dismiss it. Here the law is 35% on the front doors and on SUVs and trucks all of the other windows can be as dark as you want. At one time I had 5% all the way around but I had to strip it recently to pass inspection and haven't got around to retinting it. Where in VA are you? I am up there somewhat frequently in Roanoke, Lynchburg and Brookneal to visit family and the police have never given me any problems about my tint.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #26382 of 45902 Old 12-08-2013, 02:41 PM
Thomahawk
2006 XK Commander
^^^White side out is Nice, you know the rule,,,
Pics or it didnt happen,,
Buildthread
post #26383 of 45902 Old 12-08-2013, 03:02 PM
vanillathrilla
I'm in Roanoke, actually!
I've always had tinted windows on everything, but it's never been a problem before. I knew it would happen eventually. 50% on the front two, and 35% in the rear is what's legal here. The windows on my TJ are just as dark, if not darker--but I also have my doors off or windows down (and the back windows out) as much as possible.
He followed me for a second I guess running the plate and making sure I had VA plates. It seems like you can do whatever you want in NC/SC and be legal as far as lights, tint, etc. If you're from out of state, it seems like they leave you alone. He was a ticket writing machine though
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #26384 of 45902 Old 12-08-2013, 03:08 PM
joshtarmy1
I'll take pictures after I take it to the car wash. Forgot how hard it is to keep a white vehicle clean. Gotta stop at the exhaust shop and get a muffler this week. I want to do Kolaks setup but can't afford it at the moment and my muffler is leaking out of all the seams. Think I'll just throw on a basic Magnaflow for now. Call me paranoid but I don't like having an exhaust leak with 2 kids in the back seat.
post #26385 of 45902 Old 12-08-2013, 03:13 PM
vanillathrilla
BTW, can anyone think of any good reason why the seal on the front door would always get sucked into the door panel against the glass? It makes the window roll down really slowly and will surely eventually kill the window motor. When we got it, the door panel had clearly been pulled off and had a broken clip or something causing it to be loose and squeaky. I asked them to fix it, and mentioned the window seal being an issue. They replaced the clips in it, but the rubber seal does the same exact thing. I want to fix it before it becomes a bigger issue.
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 09:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 02:58 PM
Died today... jimbo141 WJ Grand Cherokee Forum 29 03-26-2017 11:41 AM
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 11 02-09-2017 05:03 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
