What did you do to your WJ today? - Page 1757 - JeepForum.com
 1099Likes
post #26341 of 45738 Old 12-06-2013, 02:58 PM
Highschool_WJ
Forgot to take a picture but started the jeep at -21 degrees F this morning, cranked over a few times and fired right up!
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #26342 of 45738 Old 12-06-2013, 03:00 PM
1999wjlimited
Originally Posted by wjidaho
Changed my oil at 28f burr it was cold, but before snow wheeling tomorrow I wanted to check all fluids and make sure everything is in order :-)
Not trying to make you feel bad but....
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #26343 of 45738 Old 12-06-2013, 03:09 PM
wjidaho
Yeah but I get to go snow wheeling tomorrow :-D it makes it worth it ;-)
My build thread
wjidaho is offline
post #26344 of 45738 Old 12-06-2013, 03:14 PM
mdrum93
Yeah its pretty nice here in NC right now
Bumper Thread
mdrum93 is offline
post #26345 of 45738 Old 12-06-2013, 03:28 PM
wjidaho
Cold in Idaho. Hear a big storm is coming to, probably be 3 or 4 ft of snow in the mountains we are going tomorrow :-D it should be epic
My build thread
wjidaho is offline
post #26346 of 45738 Old 12-06-2013, 04:05 PM
Jeeples
Jeeples's Avatar
You guys suck. It was 3* this morning at my house just outside SLC with a high of 18*. On the bright side, I finally got my WJ titled and licensed.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #26347 of 45738 Old 12-06-2013, 04:18 PM
brouwmat
-15 here this morning in SoDak! We had a high of -3
Sent from AutoGuide.com Free App
brouwmat is offline
post #26348 of 45738 Old 12-06-2013, 04:31 PM
mrcangi
-8 and a high of 5 in central Wisconsin. I put a new radiator and thermostat in today. Little turbo heater kept it about 35-40 in the garage and sum carhartt bibs and it was a toasty morning for me!
mrcangi is offline
post #26349 of 45738 Old 12-06-2013, 04:51 PM
mrcangi
mrcangi is offline
post #26350 of 45738 Old 12-06-2013, 04:59 PM
TJSWJ
Replaced the 3 u-joints in my rear driveshaft, the proceeded to break a strap bolt off in the pinion flange. Looks like its time for u-bolts.
TJSWJ is offline
post #26351 of 45738 Old 12-06-2013, 05:00 PM
Hytek
Found the culprit of my rattle in the front end. Top shock bolts appear to be a little loose. I tried tightening them but can't get the goofy plastic clip with the hose on it off the top drivers side shock bolt and my hands to big to fit down there. Any suggestions?
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #26352 of 45738 Old 12-06-2013, 06:34 PM
no2tracks
Hytek Put your left hand down around the engine side and use a loonng pry bar with your right hand. Good luck. I zip tied it to those little tubes that are in the way rather than remounting it.
2000 Wj Laredo,4.0, New struts & wipers, 2"BB from Fat Bob's, Bilstein 5100's, General Grabber AT2's studded, Rancho steering stabilizer, Rugged Ridge floor mats, led taillights.
no2tracks is offline
post #26353 of 45738 Old 12-06-2013, 08:27 PM
Hytek
Thanks for the tip. I ended up using a really long nose pliers to yank the booger off. Turns out the bolts weren't loose after all....the upper shock bushings look shot. That would explain why I'm hearing that loose rattle sound more now that it's cold out. I was planning on Bilstein HD's eventually but that might get bumped up now if that all has to come apart.
Hytek is offline
post #26354 of 45738 Old 12-07-2013, 10:20 AM
Thomahawk
2006 XK Commander
Headlights!!!
CCFL Are deff much brighter than my old led's
Buildthread
Thomahawk is offline
post #26355 of 45738 Old 12-07-2013, 07:05 PM
jmarler25
Installed my 3" Kolak lift. Super jacked.
jmarler25 is offline
wj
Frambo , Soem0
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
