What did you do to your WJ today? - Page 1756 - JeepForum.com
 551Likes
post #26326 of 43574 Old 12-05-2013, 09:31 PM
03azwj
2003 WJ
Originally Posted by wjidaho View Post
I did the whole bb thing and wheel spacers from rough country running 32s, I really wished I would have went with iro 4" long arms, I love my Wj but I am realizing the limitations of this rig unless you got a lot of money,
Veru true. I'm just under 4" with adj uppers and lowers up front. Wish I just went 6.5" long arm haha not even close to the budget though. Its still handled most of what I've thrown at it and I love my setup.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #26327 of 43574 Old 12-05-2013, 09:35 PM
NOTW_WJ
Originally Posted by joshtarmy1 View Post
Did some searching and actually starting to find some wheels that would work. Hmm $200 on spacers and keep my stock wheels or spring about $500 on a nice set of Pro Comp Alloys with 4.5" BS? Just not sure how they would look on a white WJ, windows are tinted black so that helps a little. Not a fan of chrome. Plus I have seen what salt does to chrome wheels.
http://www.4wheelparts.com/Wheels/Se...n=PXA7089-6873
I'd say go with new wheels
Too bad you're not closer, there is a guy selling a like new set of 5 on craigslist for $450... Anyway, amazon has them pretty cheap right now...
http://www.amazon.com/gp/offer-listi...&condition=new
NOTW_WJ is offline
post #26328 of 43574 Old 12-05-2013, 09:44 PM
joshtarmy1
Make that closer to $600, forgot about the spare.
joshtarmy1 is offline
post #26329 of 43574 Old 12-05-2013, 10:05 PM
zephyr80
Originally Posted by mdrum93 View Post
Spidertrax spacers say explicitly 90 ft/lbs, i guess over that you could run the risk of cracking the aluminum. I may have done 95 for good measure :thumsup: (I think you would have to go way past 90 for them to crack)
Any more than specified and you could Mar the aluminum and "unbalance" the fit. Even if every nut was torqued the same. If you can follow that. It won't crack the aluminum at that small of pressure. I've been drinking and cant come up with the right description.
zephyr80 is offline
post #26330 of 43574 Old 12-05-2013, 10:21 PM
mdrum93
Haha i wish i was!! But good job i get what you are saying.
Bumper Thread
mdrum93 is offline
post #26331 of 43574 Old 12-06-2013, 01:42 AM
Thomahawk
I have Procomp's 9" with 4.75 BS, protrude about 1",,,
Buildthread
Thomahawk is offline
post #26332 of 43574 Old 12-06-2013, 06:22 AM
alfaitalia
Replaced my 87 c thermostat with a 92 c one. The old one was not sealing properly so it was taking a while to warm up. Also when I tested it , it was opening at just over 70 rather than the 87 it should. Not good as it was only just over a year old. Car now warms up much faster and when up to temp the heater gives out more...ermm...heat! Hopefully might improve mpg a bit too. We will see. Gauge now sits just over the thin line before half way rather than on the thick quarter marker.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #26333 of 43574 Old 12-06-2013, 08:49 AM
NOTW_WJ
The risk is NOT the aluminum cracking or uneven balance, it is the established value set for the bolts themselves. If the spacers are torqued in a cross pattern and done in steps working your way up to the max torque value, they will be seated properly. The torque value is a calculated load established by Engineers (Reference the Engineering Hnadbook for details) and that is what all bolt manufacturers go by for each bolt size. The values are set to be tight enough to maximize the holding power of a particular size bolt. Over torqueing a bolt actually loses strength as a bolt will start to yield(bolt stretch or damage to the threads are common). In this case, too little and they may come loose, Too much and they will start to lose some their holding power and possibly either pull out or through the spacers, or weaken the threads. As long as you are close to the specified torque value you are fine, its just when you get to far either way from it that you'll have issues.
NOTW_WJ is offline
post #26334 of 43574 Old 12-06-2013, 09:17 AM
mdrum93
That didn't cross my mind when i commented earlier but I have heard of over torquing equals weakened fasteners, thanks for clarifying for us
Bumper Thread
mdrum93 is offline
post #26335 of 43574 Old 12-06-2013, 09:39 AM
Hytek
Took this sexy pic of it lol
2012 JKUR wheels and Nitto Terra Grappler 245/65-17
Love them so far!
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #26336 of 43574 Old 12-06-2013, 10:39 AM
nitromud
2003 WJ
I got my 1 1/2" spacers off ebay new a year ago for $100 shipped and they work great. I've never had an issue with them at all.
Sent from AutoGuide.com Free App
2003 Jeep Grand Cherokee Overland 3" IRO springs (actually got 4" from them) 4.7L HO, 1 1/2" wheel spacers, Magnaflow exhaust
TEOTWAWKI: The End of the World as we Know It (Acronym coined by Mike Medintz) (Spoken “Tee-ought-walk-ee”).
nitromud is offline
post #26337 of 43574 Old 12-06-2013, 11:22 AM
NOTW_WJ
No problem, So the best bet is to torque to the recommmended spec and use a dab of loctite
Love them so far!
Looks good, thats what mine looked like at one point and I had a set of those nittos on my full size Chevy truck and they were great.
NOTW_WJ is offline
post #26338 of 43574 Old 12-06-2013, 01:50 PM
samiam2187
Put new Rugged ridge floor mats in front.
Also put in a new Idle air control and it fixed my idling issues. Also had to create my own gasket for the idle air control housing.
samiam2187 is offline
post #26339 of 43574 Old 12-06-2013, 02:05 PM
Hytek
Thanks man. I keep saying I'm leaving the dub alone but I should know that's not possible lol.
Good choice. Love my Rugged Ridge mats.
Hytek is offline
post #26340 of 43574 Old 12-06-2013, 03:40 PM
wjidaho
Changed my oil at 28f burr it was cold, but before snow wheeling tomorrow I wanted to check all fluids and make sure everything is in order :-)
My build thread
wjidaho is offline
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
