What did you do to your WJ today? - Page 1748 - JeepForum.com
 925Likes
post #26206 of 45355 Old 11-29-2013, 08:05 PM
Jaketit
Originally Posted by vagov
my buddy put a set of nittros on his ford 150 so far he is happy with them. wearing good
no no to niitos they always look like squares
Jaketit is offline
post #26207 of 45355 Old 11-29-2013, 09:37 PM
4x4Jeep
great day of wheeling...i don't think i broke anything either.
Build -
SOLD
4x4Jeep is offline
post #26208 of 45355 Old 11-30-2013, 07:20 AM
Locutus
2014 WK
Received my calipers and pads
Locutus is offline
post #26209 of 45355 Old 11-30-2013, 07:39 AM
alfaitalia
Just fitted underbody LED strip, rock lights or access lights ....whatever you want to call them. I can switch them on by themselves or they come on with the courtesy lights when you unlock the door with the remote. I would be lying if I said they would get much "rock light" use as there are next to no rocks around here....and if you go out night trail driving around these parts you will more than likely get arrested for poaching! I have to park off road a bit a get fed up walking back to the car and standing in a big puddle I did not see due to no car or street lighting! Hence the ability to come on with the interior lights!
Pics when it gets dark ....in 3 hours (UK time..winter is the pits!)
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #26210 of 45355 Old 11-30-2013, 08:45 AM
Thomahawk
^^^Waiting for pics,,,
Had another look at fluid leaks after radiator change today, wiped everything down again to locate it easier.
PS fluid conections at fan seems good and tight now.
Minor coolant dripping at big lower hose/clamp engine side, got the rubber tube wiggled alittle and moved the clamp some seemed to cure this
ATF leak at lower radiator conection, got it tightened up by half a turn, looks ok, but will keep an eye on this on.
This is my hand after radiator swap, no question that its tight behind there,,,
Buildthread
Thomahawk is offline
post #26211 of 45355 Old 11-30-2013, 12:53 PM
doorjamm
So fed up with my jeep. Ready to sell it or part it out right now. Drivers door latch stopped working on Monday. Gcjeeping helped me out and grabbed me one from one of his extra doors he has, but it wasn't a matching part. Mine had more doo dads and gizmos and was marked GL4 and the one he gave me was marked GL2. So I took mine apart, cleaned/regreased it, and reinstalled to find it working again. It went out again last night. Have to keep my windows rolled down and zip ties on the b pillar to keep it from swinging open and I get the whole EVIC beeping CONSTANTLY when I drive about it being open. So ****ing annoying. Then of course the motor I just spent 3 grand into rebuilding myself, leaks at the rear main seal some how and I have to pull the whole engine to get to that. Because of that leak, it falls onto the cat, and smoke billows from underneath the hood and you get a lovely smell wherever you go. And of course my radiator decided this would be a good time to start going out so that it could overheat.
Oh and I forgot, my death wobble is back. So done with my WJ.
doorjamm is offline
post #26212 of 45355 Old 11-30-2013, 01:04 PM
aralph30
2003 WJ
Originally Posted by doorjamm
So fed up with my jeep. Ready to sell it or part it out right now. Drivers door latch stopped working on Monday. Gcjeeping helped me out and grabbed me one from one of his extra doors he has, but it wasn't a matching part. Mine had more doo dads and gizmos and was marked GL4 and the one he gave me was marked GL2. So I took mine apart, cleaned/regreased it, and reinstalled to find it working again. It went out again last night. Have to keep my windows rolled down and zip ties on the b pillar to keep it from swinging open and I get the whole EVIC beeping CONSTANTLY when I drive about it being open. So ****ing annoying. Then of course the motor I just spent 3 grand into rebuilding myself, leaks at the rear main seal some how and I have to pull the whole engine to get to that. Because of that leak, it falls onto the cat, and smoke billows from underneath the hood and you get a lovely smell wherever you go. And of course my radiator decided this would be a good time to start going out so that it could overheat. Oh and I forgot, my death wobble is back. So done with my WJ.
we'll if u do part it out. Do u have any tow hooks I'll buy them from u.
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #26213 of 45355 Old 11-30-2013, 01:19 PM
doorjamm
Got Aspen creek offroad d ring mounts and shackles. I'll post up if I start selling things like the lift and all the mods
doorjamm is offline
post #26214 of 45355 Old 11-30-2013, 03:51 PM
alfaitalia
As I mentioned earlier I fitted under body lights. Here they are.
My camera really struggles to focus on bright lights when its dark so you cant really tell that there is a bright LED every 3/8 of an inch or so...looks like a neon but its not!
They are not blue at all...they are a bright white...the camera does lie! Also makes the light look tighter to the car than it is. Usable light is produced to about a foot away from the car.
Going to put some acroos the front and rear too which will have a beam pattern a little further away from the car so i can see the wheels....just in case I go off road at night...unlikely!
post #26215 of 45355 Old 11-30-2013, 03:52 PM
rdkendrick
2003 WJ
Originally Posted by alfaitalia View Post
Just fitted underbody LED strip, rock lights or access lights ....whatever you want to call them. I can switch them on by themselves or they come on with the courtesy lights when you unlock the door with the remote. I would be lying if I said they would get much "rock light" use as there are next to no rocks around here....and if you go out night trail driving around these parts you will more than likely get arrested for poaching! I have to park off road a bit a get fed up walking back to the car and standing in a big puddle I did not see due to no car or street lighting! Hence the ability to come on with the interior lights! Pics when it gets dark ....in 3 hours (UK time..winter is the pits!)
Where did you mount them, to your rock rails? And, how did you run the wiring into the cabin? I am assuming you wired it into the courtesy light?
Sent from my iPad using my fingers
rdkendrick is offline
post #26216 of 45355 Old 11-30-2013, 03:59 PM
alfaitalia
No they are on the flat panel just in from the plastic sill (you say rockers!) covers. The wires run up behind the front plastic arch liners, behind the wings (fenders!) and into the car through the door rubber boot. Yes they are wired to both the front footwell lights. This means toy can turn them on of off with the slider on the indicator stalk...but I might use a five pin relay and a switch so I can turn them on and off independantly as well. Was pushed for time today as I was supposed to be working....shhh...dont tell the Boss!
post #26217 of 45355 Old 11-30-2013, 04:02 PM
Chris00WJ
I checked my local JY bright and early this morning and saw online that they had a new WJ. So a buddy and I headed down bright and early hoping to replace my broken header panel. No such luck. It was in a front end collision.
HOWEVER, it had near mint leather seats that were the correct color, and was a limited so it had the white face cluster I needed/wanted. I havent been able to buy one online because they are all in MPH and Im in Canada and needed one in KM/hr. So everything got installed this afternoon.
I've gotta say, I love the leather. It really made me appreciate the Jeep again. She has been neglected for a while.
Chris00WJ is offline
post #26218 of 45355 Old 11-30-2013, 05:40 PM
joshtarmy1
Swapped in a new IAC fix a bad negative terminal on the battery that I just noticed and put in some new plugs. Gonna try to change the oil tomorrow. Idle is smooth now, no more hesitation and it doesn't shake anymore. Just hoping that my misfire code doesn't come back. The plug on Cyl 8 wasn't too bad but 7 was a pain in the butt. Looked like a rubber o-ring melted to the plug. Used an idea I found on here with the sharpened coat hanger and heated it up with a torch to break the rubber apart. Didn't feel like going to Napa for the stock champions so I went with a set of the Bosch Copper plugs.
joshtarmy1 is offline
post #26219 of 45355 Old 11-30-2013, 07:58 PM
fast540
Just picked ups 6" rock krawler lift. Super stoked as it's not made anymore
fast540 is offline
post #26220 of 45355 Old 11-30-2013, 08:34 PM
wjidaho
Went wheeling with some friends, sorry I was slacking on photos, good news my buddy with a truck now wants a jeep ;-) converted him
Sent from my WJ to yours
My build thread
wjidaho is offline
wj
johnnyboy559
