What did you do to your WJ today? - Page 1745 - JeepForum.com
 831Likes
post #26161 of 45042 Old 11-26-2013, 09:57 PM
FedUp007
Originally Posted by aralph30 View Post
What do u have in ur tow hitch? That's holding the green hook ?
looks like the D-Ring hitch shackle from Harbor Freight... but he painted it green from the silver it was...
Failure is the chance to begin again, with increased intelligence... 100
FedUp007 is offline
post #26162 of 45042 Old 11-27-2013, 01:38 AM
theksmith
2003 WJ
drove it, first time since last friday, woot!
theksmith is offline
post #26163 of 45042 Old 11-27-2013, 11:12 AM
bgohsman
Removing the front axle assembly/differential in preparation to put on the rebuilt surrogate axle assembly. So far, have the brakes off, hubs and axles out, shocks disconnected and knuckles off. Just taking a coffee break before compressing the springs.
If I don't run out of daylight, I'll put it on a transmission jack and remove the last set of bolts holding it on.
Brandon Gohsman
bgohsman is offline
post #26164 of 45042 Old 11-27-2013, 11:32 AM
PetrolPete
Got the correct size lower track bar bolt with nut from the dealer.
They use a pinch nut so it doesn't back off on its own ;-)
PetrolPete is offline
post #26165 of 45042 Old 11-27-2013, 11:43 AM
YJSXJ
1993 XJ Cherokee
Making a 1500 mile round trip starting tonight. Fingers crossed.
YJSXJ is offline
post #26166 of 45042 Old 11-27-2013, 12:59 PM
trevord1
finished my tank tuck yesterday well worth the time wish i would of done it a long time ago would of made my axle swap so much easier
2004 wj freedon edition long arm lift on super swampers!
trevord1 is offline
post #26167 of 45042 Old 11-27-2013, 01:03 PM
aestrad1
Any write up on this? Been wanting to tackle this chore
aestrad1 is offline
post #26168 of 45042 Old 11-27-2013, 01:07 PM
wjidaho
Their is a bunch if I was not on my phone I would copy a link for you, if no one gets it done before I am off work then I will post up the info for you. I want to do this mod so bad also
Sent from my WJ to yours
My build thread
wjidaho is offline
post #26169 of 45042 Old 11-27-2013, 01:55 PM
Hytek
Washed all the salt off.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #26170 of 45042 Old 11-27-2013, 02:00 PM
Thomahawk
First thing in the morning, going to check PCV, damn thing cracked in pieces at the lightest touch
Imediatly threw check engine light,
Got lucky to find a overpriced at shelf at stealership, bought it and replaced it.
Also replaced licence plate bulbs with LED
Ok now check engine was gone but still idle high,
Started to investigate vacum leaks, have a air sucking/blowing sound coming from the rear of TB intake area, found That it raised the idle rpm when i sprayed start gas in That area,
Replaced brake booster vacum hose and some others That looked alittle cracked at the ends,
no dice
The vacum line going behind engine towards torpedo wall from one top to the another and have a t piece going to the resonator box was cracked at the ends going to the engine,
tried to tape them up with electro tape, but still no dice
Its still raises the idle rpm when i sårt start gas in the rear top end of the intake, behind TB,,, aaaaahhh!!!!
How sensitive is this vacum system???
This now starts to irritate the H out of me, cause idle at ~1000ish rpm, makes it shift hard from P>N>D, and fuel consumption is out of wack.
Any or all ideas apriciated, i really need this fixed, its my DD,,,
Buildthread
Thomahawk is offline
post #26171 of 45042 Old 11-27-2013, 02:07 PM
Thomahawk
And where the heck Are this ground strap going, comes one from right side engine compartment torpedo wall>engine>this one, i cant see to figure out where its going,,, Anyone???
Buildthread
post #26172 of 45042 Old 11-27-2013, 04:17 PM
steveandhiswj
Well this happened last night made it pretty hard to get home but I made it
steveandhiswj is offline
post #26173 of 45042 Old 11-27-2013, 04:21 PM
trevord1
http://www.pirate4x4.com/forum/jeep-...elocation.html
this what i did exactly worked great
trevord1 is offline
post #26174 of 45042 Old 11-27-2013, 04:24 PM
trevord1
anybody know what the unit thing is under my drivers side tail light after i did my tank lift that thing hangs down pretty far what is it and how do i get rid of it?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
trevord1 is offline
post #26175 of 45042 Old 11-27-2013, 04:25 PM
Thomahawk
Might be your Evap canister,,, post 02, have them in the rear bumber.
Buildthread
wj
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
