What did you do to your WJ today? - Page 1744 - JeepForum.com
 866Likes
post #26146 of 45175 Old 11-26-2013, 09:51 AM
wjidaho
Originally Posted by Rough Country
Got the 4in Rough Country kit installed on my own Jeep. Now time for some trimming and 33s!
Long arms or short?
Sent from my WJ to yours
My build thread
wjidaho is offline
post #26147 of 45175 Old 11-26-2013, 09:59 AM
Rough Country
Vendor
Rough Country's Avatar
Originally Posted by wjidaho View Post
Long arms or short?
Short arm x-series for now. I will be picking up a new DD next year so I may go long arm then.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
  • 731-288-6803
Rough Country is offline
post #26148 of 45175 Old 11-26-2013, 01:53 PM
PetrolPete
I tightened up the lower track bar bolt that had loosened, and ordered a 12mm bolt from the dealer. Nobody has a grade 8 12mm bolt around here other than them.
I'll be throwing that on tomorrow with some red locktight.
PetrolPete is offline
post #26149 of 45175 Old 11-26-2013, 04:48 PM
Mullins420
ordered much 3" lift from kolak... :-)
i can't wait for it to arrive!
Mullins420 is offline
post #26150 of 45175 Old 11-26-2013, 04:53 PM
formeraudi
Found a set of Rubicon wheels and tires on CL for $350. Hopefully the 32s fit with minimal trimming on the 3" IRO lift.
formeraudi is offline
post #26151 of 45175 Old 11-26-2013, 05:36 PM
WJChris01
They will. You'll have to trim the front bumper a bit, and they will scrub on control arms when cranked hard in reverse, but not too bad.
- 2001 WJ Laredo
4.0, d30/d35(for now) and 242
3" OME lift with JK Rubicon Moabs and 255/75/17 BFG MT's
- 1998 XJ Sport
Bone stock for now......
WJChris01 is offline
post #26152 of 45175 Old 11-26-2013, 05:37 PM
WJChris01
Originally Posted by PetrolPete
I tightened up the lower track bar bolt that had loosened, and ordered a 12mm bolt from the dealer. Nobody has a grade 8 12mm bolt around here other than them. I'll be throwing that on tomorrow with some red locktight.
That's because grade 8 is for sae hardware. The metric equivalent is a 10.9 grade.
- 2001 WJ Laredo
- 1998 XJ Sport
post #26153 of 45175 Old 11-26-2013, 06:15 PM
STGjeep
Replaced my PCM, all is right with the world again
STGjeep is offline
post #26154 of 45175 Old 11-26-2013, 06:15 PM
YJSXJ
1993 XJ Cherokee
Originally Posted by djpeters View Post
How'd you do that? With a kit? Or'd ya hack into the radio? If so, how? I want an aux input bad....I have the RAZ HU, no nav....
just eliminated the stock CD Changer (since I havent bought or Burned a single CD in over 4 years). Tapped into wires 1,5,and 6 on the CD Changer. 1 & 5 are the audio Left and right, 6 is the audio ground. THere's also a way to do it fform the front, But I couldn't find a good Pinout diagram for a RB1 radio and Didn't feel like tinkering with the electric tester tracing wires in the 32 degree weather that day. Installed the aux port just to the left of the glove box. Looks damn near factory finished. IT's flush with the panel.
looking for 33x12.5x18 tires.
Bruiser -- 93 XJ Sport. 9.5" lift on 35"" Claws, Locked front & Rear, and some other crap. Rolled it
Cruiser -- 1998 XJ Classic. 3" RC lift. 32" Kuhmo Ventures. Sold it
1999 WJ Limited V8. 4" Mix-n-Match Lift. Nothing special.
YJSXJ is offline
post #26155 of 45175 Old 11-26-2013, 06:20 PM
djpeters
The changer has to be working for this to work, right? I'm really looking for a way to tap into the HU....Ideally...
2004 WJ Overland
djpeters is offline
post #26156 of 45175 Old 11-26-2013, 06:29 PM
YJSXJ
1993 XJ Cherokee
correct, I left the rest of the wires alone. also, I left 1 CD in there on repeat, otherwise, it wont work if the radio doesn't pick up a signal that the changer isn't running
YJSXJ is offline
post #26157 of 45175 Old 11-26-2013, 06:38 PM
YJSXJ
1993 XJ Cherokee
YJSXJ is offline
post #26158 of 45175 Old 11-26-2013, 07:35 PM
rdkendrick
2003 WJ
If you have the tape player, there is a thread on here that tells you how to tap into that and add a 3.5 mm jack. Just search for it.
Sent from my iPad using my fingers
rdkendrick is offline
post #26159 of 45175 Old 11-26-2013, 08:01 PM
bgohsman
Welded new coil spring perches on the surrogate, rebuilt axle assembly. Got it coated with rust encapsulator. Tomorrow...front end dismantling...
Brandon Gohsman
bgohsman is offline
post #26160 of 45175 Old 11-26-2013, 08:24 PM
djpeters
You are right, found it, and going to try it....
www.nagca.com/forum/showthread.php?t=49090"]http://www.nagca.com/forum/showthread.php?t=49090
2004 WJ Overland
djpeters is offline
wj
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
