What did you do to your WJ today? - Page 1736 - JeepForum.com
 861Likes
post #26026 of 45152 Old 11-21-2013, 10:29 AM
Hytek
Put the Superchips back in. Now that I've ran 5 tanks with the winter blend fuel and stock tuning I'll do the same with the 87 tune. We'll see how the mpg does. Not looking for huge improvements at all...just a test. However anything is better than the last 5 average of 13.17mpg lol.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #26027 of 45152 Old 11-21-2013, 11:32 AM
mdrum93
Originally Posted by brouwmat
It is not "Virtually Free" in the US.. it has gone up a lot since Obama came into office. So the environmental wackos are here already. Agreed it did go up the first time under Bush, but the difference here is that it went back down under him. It has stabilized under Obama at the higher price. Agreed that this is just the beginning. If the Dems get another crack at the White House it will continue to go up. http://www.smartplanet.com/blog/bull...ld-to-buy-gas/
Amen fellow Republican!
Bumper Thread
mdrum93 is offline
post #26028 of 45152 Old 11-21-2013, 11:41 AM
alicat48
I showed up a transmission repair man.....felt good to see his eyes pop out when I explained to him (from a woman) all about the quad drive and how you CAN drive without a front drive shaft and on how easy it was to remove and he could stick his $300.00 quote cause I could do it myself with a 8mm wrench, a small pump(for the oil), and a allan key....and I give all the thanks to everyone on here with there help to make that happen........
alicat48 is offline
post #26029 of 45152 Old 11-21-2013, 12:14 PM
EisBlade
EisBlade's Avatar
Way to go!!
JT
Harley-Davidson Touring Bikes (60K members strong)
EisBlade is offline
post #26030 of 45152 Old 11-21-2013, 12:17 PM
EisBlade
EisBlade's Avatar
2 days ago - Installed new custom seat covers from CarCoversPlanet. Black with "a different color" insert.
Dropped it off last night to get vinyl wrapped, from Flame Red to...a different color. :-) Before / After pics to follow.
JT
EisBlade is offline
post #26031 of 45152 Old 11-21-2013, 12:21 PM
veiri86
2003 WJ
I put my new Flowmaster Super 44 muffler, I kept the stock cat. converter and changed the muffler only for aggressive sound reasons, no gains were intended. The sound is so sweet with Zero drone noise while cruising.
And I had codes for the four O2 sensors (P0051, P0141, P0151, P0152 P0161), and rough idle, checked the harness for short circuit but it was ok, so I ordered one Mopar O2 sensor, the one sets upstream of the cat. which is on the passenger side, they had sent me the one upstream of the cat but on the driver side, both are the same but the wire for the passenger side supposed to be longer, so I had to splice my new 77 USD sensor wire and extend it, so I extended the wire, plugged it, disconnected the battery for five minutes to clear the codes and check engine light, then started it up, then drove it for 100 mile, now it idles better and no check engine or fault codes so far. Just one advise, if you wanna buy the Mopar O2, it is better to buy the Denso O2 sensor, because both are Denso and exactly the same sensor but different packaging and the for sure price, the denso is around 50-60 USD cheaper.
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #26032 of 45152 Old 11-21-2013, 12:26 PM
watts115
Trying to get a photo up.. "plasti-dipped" the stock rims matte black on my 04 WJ HO, tinted the front windows, and put some AVS window visors on for the winter. Then of course the WJ got a nice bath haha
watts115 is offline
post #26033 of 45152 Old 11-21-2013, 12:46 PM
NOTW_WJ
X2
NOTW_WJ is offline
post #26034 of 45152 Old 11-21-2013, 02:22 PM
PetrolPete
Stripped the tint off of the front windows to pass inspection.
I hate it.
PetrolPete is offline
post #26035 of 45152 Old 11-21-2013, 02:31 PM
Thomahawk
Orderd 3" Kolak exhaust with FM70 muffler, and a superchip, thx Kolak
Buildthread
Thomahawk is offline
post #26036 of 45152 Old 11-21-2013, 03:00 PM
alfaitalia
Did you not keep all that stuff from your previous WJ? Thought you had stripped it to virtually a shell before you sold it!
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #26037 of 45152 Old 11-21-2013, 03:21 PM
Hytek
Well...my blend doors have graduated from minor moans and groans to the sounds one would make from having one to many White Castle sliders. I suspect that's my final warning before they take a crap on me lol.
https://www.youtube.com/watch?v=GYuG...e_gdata_player
Hytek is offline
post #26038 of 45152 Old 11-21-2013, 03:34 PM
Thomahawk
Originally Posted by alfaitalia
Did you not keep all that stuff from your previous WJ? Thought you had stripped it to virtually a shell before you sold it! Sent from the Dark Side using only the Force.
Yeah, but sold it to the cost of a new one
And the 04 have different cat setup,,
Buildthread
post #26039 of 45152 Old 11-21-2013, 06:29 PM
PackLifeNC
I installed a 4" RCX kit today, along with a steering stabilizer
www.packlifenc.com
PackLifeNC is offline
post #26040 of 45152 Old 11-21-2013, 07:21 PM
rab62184
I sold my 03 overland. Sad day, but it had to happen. I keep hearing "you can get another one SOME DAY". I don't quite believe it! :-(
Sent from my MB886 using JeepForum
rab62184 is offline
wj
jamesrw30 , pkman
