What did you do to your WJ today? - Page 1715 - JeepForum.com
 827Likes
post #25711 of 45025 Old 11-04-2013, 06:05 PM
Hytek
Night #2 with my HIR2 bulbs and I'm still not satisfied. I can't understand why the beam's scattering all over. My lenses are clean and clear too.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #25712 of 45025 Old 11-04-2013, 07:50 PM
sjtinc
Lost the keys to it.
sjtinc is offline
post #25713 of 45025 Old 11-04-2013, 11:26 PM
rdkendrick
2003 WJ
I ordered some Tiles just for that, but they won't ship until after the new year. They are like remote finders. You can use an iPad or iPhone to hone in on where they are.
Sent from my iPad using my fingers
rdkendrick is offline
post #25714 of 45025 Old 11-05-2013, 12:40 AM
Trxgedy
Originally Posted by Hytek View Post
Put in Philips 9012 HIR2 bulbs to replace the low beams. They're brighter and whiter for sure. I no longer need the fog lights on all the time like before. I'm not to keen on the beam pattern though. You can see in the pics below that it's not a capped bulb like the OEM 9006XS. We'll see how it goes but so far no one flashed me. I had to modify the tabs for them to fit which was fairly easy. The hardest part was getting the actual headlamp housing out and even snapped a tab. I learned my lesson after the first one and sprayed wd40 on the other tabs and greased them per WJJeeps.com recommendation for easier future removal.
Against the garage door the one on the left is the hir2 and right is oem. Kinda hard to see the difference in this pic though.
Here you can see the tab I had to modify
I have the hirs I like them alot. I didnt modify the tab, if you take the clear plastic thing off the back of the headlight, ( its the thing where you line up the tabs to put the bulb in) and put the bulb in and put the clear thing back on yoh dont have to even cut the tab to fit. Took 2 extra mins with a torx screwdriver.
Sorry my descriptions kinda bad lol.
Trxgedy is offline
post #25715 of 45025 Old 11-05-2013, 03:30 AM
hullfm
bench bleed a new master cylinder and installed it, better but think it needs lines bleed again
hullfm is offline
post #25716 of 45025 Old 11-05-2013, 01:25 PM
Hytek
Lol I followed u. Those torx get in the way of the base too. How's your beam on the ground? Does it look scattered at all? I'll try and capture it in a pic later.
Hytek is offline
post #25717 of 45025 Old 11-05-2013, 03:37 PM
golfinWJ
Got my 3 inch IRO lift delivered today
golfinWJ is offline
post #25718 of 45025 Old 11-05-2013, 04:11 PM
Butterbuddha
2010 JK Wrangler
Was standing on the back tire adjusting a new roof rack, when I felt the tire shift under me. Thought it was loose on the lugs, not good. (Its the Mrs' DD afterall!) Turns out worse, all the lugs were rock solid, yet I can shake the assembly what feels like 1/2in. Methinks the bearings are done. Not making any noise or driving weird though.
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #25719 of 45025 Old 11-05-2013, 04:23 PM
Hytek
Picked up a screw in the tire....dammit
Hytek is offline
post #25720 of 45025 Old 11-05-2013, 05:22 PM
djpeters
Bought 5 new Cooper Discoverer AT3's in 245/65-17...
2004 WJ Overland
djpeters is offline
post #25721 of 45025 Old 11-05-2013, 06:40 PM
NU_WJ
Ordered new end-links from Kolak. If this doesn't resolve the clunk in the rear, then may have to explore upper control arm and ball joint. -fingers crossed-
NU_WJ is offline
post #25722 of 45025 Old 11-05-2013, 06:54 PM
rdkendrick
2003 WJ
That's why I always buy the road hazard warranty.
post #25723 of 45025 Old 11-05-2013, 07:05 PM
aralph30
2003 WJ
Can someone help. I bought after market headlights a while back. I was trying to install my bed xenon bulbs but theirs a price of plastic in the way behind the headlight housing and I can't push the headlight back in. Has anyone had this problem. Online it claims this is the right size bulb and everything maybe I have to just trim some plastic.
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #25724 of 45025 Old 11-05-2013, 07:09 PM
Highschool_WJ
Washed and waxed her. And found a set of oem overland rock rock rails! Unfortunetly one of them has a dime sized hole from rust but since its the only set ive been able to find in two years ill take my chances fixing it!
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #25725 of 45025 Old 11-05-2013, 07:11 PM
TJSWJ
Lowered it. Decided to turn in the 15" soft 8's for a set of 30" spokes
just kidding, its sitting on its bumpstops.
TJSWJ is offline
wj
