What did you do to your WJ today? - Page 1713 - JeepForum.com
 831Likes
post #25681 of 45043 Old 11-02-2013, 04:41 PM
JeepNowski
Replaced front brake pads. In the process noticed that the front rotors are in pretty bad condition and will need to be replaced sooner rather than later so I ordered some new rotors and will put new high quality pads on those when I get them. Boy those old rotors were rusty, the calipers were OK but not great so I might end up doing those also but I'll want to get a good brand and probably do all 4 at once.
JeepNowski is offline
post #25682 of 45043 Old 11-02-2013, 05:41 PM
rdkendrick
2003 WJ
FINALLY, finally, it warmed up, wasn't raining, and the wife is away, so no honey-do's. I had a whole day to work on the Jeep, that is, after I slept in. Got up, got everything together, the window sill wipes that I put black RTV on, cured. I removed all the old, rusted out window seal wipes, cleaned up, put rust-inhibitor on any spots that needed it, touched up any spots underneath that needed it, and put the new wipes on. (i don't remember who told me to use "Mother's" to remove the rust stains, but thank you, it worked fantastically). I might sell the 2nd set of Sill Wipes that TGC sent me. Painted the Rock Rail end caps, primered the Rock Rails and if it is nice tomorrow, I will finish painting them. Put the Jeep in a ramp, cut off 7 1/2 inches off the tail-pipe and went to put the chrome extension on and F-ME! The one I ordered is 3 1/2 inches OD, but my tail-pipe is 2 1/2 inches OD. I followed the page on WJJEEPS: http://www.wjjeeps.com/exhaust_tips.htm and it says the tail-pipe is 3 1/2 OD, I even measured, but I did it from the end and the tail-pipe narrows down after the weld.
Darn-it-all!
Luckily, Amazon is letting me return it, as I was only a week past the return cut-off date.
Sent from my iPad using my fingers
rdkendrick is offline
post #25683 of 45043 Old 11-02-2013, 07:18 PM
rdkendrick
2003 WJ
Originally Posted by samiam2187 View Post
Changed my lug nuts to gorilla solid chrome set. My old ones were a mess. It took about 20 minutes for all 20.
How much and where did you buy them?
post #25684 of 45043 Old 11-02-2013, 07:29 PM
colomatt
2008 WK
Went up into the hills for the afternoon. No luck on finding any solid trails though. :/
colomatt is offline
post #25685 of 45043 Old 11-02-2013, 08:55 PM
NOTW_WJ
Replaced my Ball Joints with some Moog Offset ones to regain some lost caster
NOTW_WJ is offline
post #25686 of 45043 Old 11-02-2013, 10:05 PM
Jaketit
Darn-it-all!
That is definitely a mod worth the price. Makes it look nice and clean.
Jaketit is offline
post #25687 of 45043 Old 11-02-2013, 10:44 PM
4x4Jeep
so i did something stupid today. was supposed to go on a night ride, started the jeep up to go get gas, heard a loud squealing noise, turned out to be the drive belt was split in half almost. so no big deal i'll change it out before i go. i've only changed one of these on a car many years ago, so i thought i was doing right. on the tensioner i turned it counterclockwise (as most things loosen when you do that )...broke right in half. so now no wheeling this weekend and i have to wait till monday to get it fixed.
Build -
SOLD
4x4Jeep is offline
post #25688 of 45043 Old 11-03-2013, 05:29 AM
jtcnj
Wj
Investigating the P1281 - taking too long to warm up.
Could be the coolant sensor or thermostat. The gauge was running a bit cold on the cooler days lately, I think the one sensor is for both ECU ops and the gauge.
Removed the cheap China T-stat I put in there 2.5 years ago. Wasn't stuck open, but I replaced it with an Advanced Auto one. We'll see.
Investigating little coolant leak at top radiator hose inet to radiator. Found my overflow hose clogged with crud in bottom of tank. Cleaned it all up. NG.
Closer look shows plastic inlet at radiator is cracked, so now I'm radiator shopping.
"Lay Down Sally" Silverstone Metallic 2001 xj sport 4.0L/AW4/231/8.25 mostly stock.
"Dubyuh" or "Blue Bayou": Patriot Blue 2001 Up-Country WJ Limited 4.7L V8 Quadra Drive: for now known as "Al-Dente" after my wife's "mod".
New Addition 12/2011: "Pearl" Forest Green Pearlcoat 1999 xj SE 4.0L/AW4/231/8.25 mostly stock for now.
____________________________________________
I didn't agree, but hoped for Hope and Change.
I got change for myself and my family: for the worse.
This is the reality of: Barackalypse Now. Again.
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Wilson Reagan
jtcnj is offline
post #25689 of 45043 Old 11-03-2013, 07:12 AM
alfaitalia
Fitted this to replace my front drive shaft that I bent on a stump last weekend!..........shiney! Only took half an hour.
But im glad I did replace it because with a TC rezeppa like this I dont think it would have lasted much longer. Only the faintest trace of grease remaining and lots of play. Funny thing was, no noise or vibes......there would have been soon no doubt! Its the original and done 110,000 so cant complain.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #25690 of 45043 Old 11-03-2013, 07:48 AM
alfaitalia
Also sat in my car looking at JF on my phone whilst sheltering from the rain......and laughed out loud when I read the the 2016 Wrangler will most likely NOT have solid axles. What possible use will they be then?? Neither form nor function! Haa Haa !
post #25691 of 45043 Old 11-03-2013, 08:45 AM
wjidaho
I know right , what are they thinking taking icon off road rig and screwing it up. :-( good thing I am so into this wj and the LJs don't have to worry about the 2016 wangler Sent from my iPhone using JeepForum
My build thread
wjidaho is offline
post #25692 of 45043 Old 11-03-2013, 02:12 PM
Morphine
Disco on my WJ
http://youtu.be/F7CKegQkQIs
Morphine is offline
post #25693 of 45043 Old 11-03-2013, 02:26 PM
Trxgedy
Originally Posted by Morphine View Post
Thats kinda cool lol I like it
Trxgedy is offline
post #25694 of 45043 Old 11-03-2013, 04:59 PM
rdkendrick
2003 WJ
Isn't that illegal? I thought no one but police could have blue lights. That's not to say that I don't like it. I think it's cool.
post #25695 of 45043 Old 11-03-2013, 05:15 PM
flucero28
Today I added the express down feature to my 2002 overland front passenger window with one of these I got for a few bucks at my local pull n pay
Well worth the hour or so it took.
flucero28 is offline
wj
GhostJeepWJ
