What did you do to your WJ today? - Page 1706 - JeepForum.com
 672Likes
post #25576 of 44122 Old 10-30-2013, 12:26 AM
NU_WJ
New valvoline fluid in both the front and rear diffs. Kind of a PITA to fill the rear diff with the Addco sway bar in the way but figured it out eventually.
NU_WJ is offline
post #25577 of 44122 Old 10-30-2013, 12:29 AM
NU_WJ
Oh, and got my rigid D2 amber covers in the mail. Bring on old man winter!
NU_WJ is offline
post #25578 of 44122 Old 10-30-2013, 04:17 AM
PAJeep6
Originally Posted by Hytek View Post
I've always thought those were cool looking. I'd totally put a set on my zj, but they're not the same bolt pattern.
They'd fit your 04.
02 WJ - 4.7 | Black Rocks | 33" Treadwright Guard Dogs | 3" exhaust | 6.5" LA lift...
PAJeep6 is offline
post #25579 of 44122 Old 10-30-2013, 05:44 AM
ctwistedpair
ctwistedpair's Avatar
Wj new engine
Bought a new engine from Rockauto. This jeep is worth 4000 on the street and 10,000 in new parts.
ctwistedpair is offline
post #25580 of 44122 Old 10-30-2013, 05:51 AM
WJ_allday04
I just ordered some Philips HIR2 bulbs. They're not xenon but supposed to give the best light output if you're looking for better visibility. They should be here tomorrow or Thursday, I'll report back after I get them in.
where did you find those bulbs? I couldn't find them.
2004 WJ 4.7 - 7in lift
Rustys Long Arms//Rustys f+r springs//Rustys crossmember
CSL RLCA//Poly D30 bushings//IRO A arm
Skyjacker Nitro's//JKS trackbar//242HD+IRO SYE
WJ_allday04 is offline
post #25581 of 44122 Old 10-30-2013, 06:57 AM
Ikelovey
2015 WK
Originally Posted by Sessi View Post
Today i did all the small mods i've been looking at waiting for my lift, transfer case fluid, differential additive and new headlights . I made a mexi-chrome grill insert, mexi-chrome bug shield, and darkened up my taillight just a touch to flow with the body color! I had to replace the plastic clips and screws to the top light since they broke when i was replacing the bulb!
GO Crimson Hawks!!! I am an IUP Alum (2006)
Ikelovey is offline
post #25582 of 44122 Old 10-30-2013, 07:42 AM
aralph30
2003 WJ
Rip to my radiator. Have to get a new one
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #25583 of 44122 Old 10-30-2013, 08:09 AM
Hytek
Originally Posted by PAJeep6 View Post
They'd fit your 04.
gotta leave the wj stock looking for as long as I can lol....the zj's my toy.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #25584 of 44122 Old 10-30-2013, 08:15 AM
Hytek
Amazon had the best price. http://www.amazon.com/dp/B00480N18G/..._M3T1_ST1_dp_1
Took some Googling as they're not called "HIR2" by name. Here's where I first found some info: http://store.candlepower.com/hirlighting.html
And here's how to modify the tabs so they'll fit in our 9006 housing: http://store.candlepower.com/mohirbuba.html
Hytek is offline
post #25585 of 44122 Old 10-30-2013, 09:55 AM
Jeeples
Jeeples's Avatar
Originally Posted by Timbo24 View Post
I can use my extra 2 homelink buttons for the off and on button.
That is an excellent idea. I may need to steal that one in the future
Taking a quick trip to the junkyard today. I attempted to replace my clock spring this past Sunday and was completely unsuccessful. I ended up separating the wheel from the steel hub that's pressed into it, then cut the hub in half with a dremel.
I broke one 2 ton gear puller and only managed to completely destroy the back side of the wheel using another 2 ton puller. Hopefully I have better luck removing one in the junkyard after work.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #25586 of 44122 Old 10-30-2013, 10:10 AM
99WJ539918
Wanna grab me one whole you're there, too? I've needed a clockspring for a while. They're only $67 online, too. Man I'm lazy. Good luck swapping them out.
Build Thread
99WJ539918 is offline
post #25587 of 44122 Old 10-30-2013, 10:27 AM
Jeeples
Jeeples's Avatar
Sure, they're pretty cheap. The wheel itself is only like $6 since it's half off day.
I know what you mean about the clock spring, I was being a cheap *** and pulled one off a WJ in the boneyard to use in mine. That steering wheel came off without out any issue, so I figured it would take me twenty minutes or so to do mine at home.
I was dead wrong, almost 2 hours later all I had was a destroyed wheel. I'd use the wheel from the Jeep I got the clockspring, but it was a tan interior
Jeeples is offline
post #25588 of 44122 Old 10-30-2013, 10:43 AM
rdkendrick
2003 WJ
Should have put some under the bumper, too, in the air dam, to protect the bottom of the condenser.
Sent from my iPad using my fingers
rdkendrick is offline
post #25589 of 44122 Old 10-30-2013, 10:56 AM
rdkendrick
2003 WJ
I replaced my clock spring , which did NOT fix my airbag issue, so I suspect it's still good. For $10 and shipping, I will send it to you, if you want to try it. I never had any problems with my steering wheel buttons, nor horn.
post #25590 of 44122 Old 10-30-2013, 02:39 PM
alfaitalia
Went to the hardware store to get a few panels and posts to repair the garden fence after the worst storm for 26 years (aledgedly)! Jobs like this is why I wanted my lights and light bar down low! (note small helper....useful for passing tools, getting beer and passing tiedown straps to me before the wind blew the panels off the car!).
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 08:20 PM
