What did you do to your WJ today? - Page 1698 - JeepForum.com
 866Likes
post #25456 of 45178 Old 10-25-2013, 09:54 PM
StickinMud
I installed the following in my 04 special ed.
Kenwood kdc bt555u
Rockford fostgate 551s
Rockford fostgate 4600x
2 Rockford Fostgate he 12s
Stock rear door speakers
Memphis audio 6.1 in front doors
Memphis audio 2.75 dash speakers
Sounds pretty darn good to me. I'm really liking the Bluetooth audio streaming. I didn't think the sound quality would be that good but it really isn't bad at all. I'll probably replace the sick rear door speakers eventually but right now they are doing ok.
Next thing I want to do is add a steering wheel audio interface to get back my volume buttons. I never knew how much I used them until today.
StickinMud is offline
post #25457 of 45178 Old 10-25-2013, 10:25 PM
adavis39
Went out to the garage....remembered I sold it did a burn out in the 9er to make myself feel better
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #25458 of 45178 Old 10-26-2013, 01:16 AM
Dynamo138
2015 JK Wrangler
Replaced the throttle position sensor, that solved a few problems (wouldn't idle right, kept down shifting randomly and check engine light was on). Replaced the socket for one brake light. Fixed the wiring to one fog light and since I was on a roll I tackled my cruise control problem, just had to replace a vacuum line. Tomorrow its time to bleed the brakes and order a new driver door window regulator.
Dynamo138 is offline
post #25459 of 45178 Old 10-26-2013, 08:53 AM
HiPERnx
12 Buttons, the relay box can provide 10amps/channel but maximum of 40 amps/row (the two rows are independent, but have the same relay box but have separate power sources)
Upper (closest to instruments) will be powered on with ignition (tips where I can find a hot with acc wire under the steering wheel that can activate a relay ?)
The lower is on all the time
Upper will be used to control extra lights relays.
It was really cheap!
Gustaf Nilstadius,
Jeep WG -99 v8, see ^ for full info
HiPERnx is offline
post #25460 of 45178 Old 10-26-2013, 10:04 AM
wjidaho
Just got done changing oil, coolant flush, and greased the whole front end... Now getting ready to take her to lost trail for some wheeling :-D today should be a good day
My build thread
wjidaho is offline
post #25461 of 45178 Old 10-26-2013, 12:58 PM
vagov
just got my 1.5 wheel spacers in the mail today but I think im going to change out my rear rotors first do you trad lock them on as well
vagov is offline
post #25462 of 45178 Old 10-26-2013, 04:33 PM
Hytek
Looking at headlights and was hoping to pick up some Sylvania Silverstar Ultras but apparently they're not made in our size. Tempted to try the 9006st and see it they'll fit.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #25463 of 45178 Old 10-26-2013, 05:20 PM
JeepNowski
For what it's worth, IMO those aren't worth the extra $$$ you spend on them. They're marginally brighter at best, and they don't last as long. They can claim 50% brighter or whatever it is, but I put a set of those in my wife's car and the only difference I could tell is that the light was a slightly different shade......a little more blue in it than standard headlights, but they didn't shine any further than the standard lights and didn't give any wider beam or anything like that.
IMO You'd be better off spending the money on either re-polishing your existing lenses or buying all new ones...I did that to mine and holy smokes does it ever look better!
JeepNowski is offline
post #25464 of 45178 Old 10-26-2013, 06:15 PM
wvracer821
wvracer821's Avatar
Philipps HIR bulbs....google it.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #25465 of 45178 Old 10-26-2013, 07:10 PM
NU_WJ
Finished the rigid industry D2 install and ordered supplies and parts for preventative maintenance before either hits. Spark plugs, fuel filter, oil&filter, both diffs, and transfer case.
NU_WJ is offline
post #25466 of 45178 Old 10-26-2013, 07:12 PM
NU_WJ
And big props to Kolak for the hookup on TREs, isolators, and the SS.
NU_WJ is offline
post #25467 of 45178 Old 10-26-2013, 07:27 PM
Hytek
I've used them for years in other vehicles and have always had good results. My route to and from work is unlit back roads and side streets with random deer. So anything brighter than OEM works for me. My lenses are good still and I just replaced the housings in my zj. Just read a few threads about the hid retrofit. That'd be awesome but I don't have the patience to do something like that lol.
Hytek is offline
post #25468 of 45178 Old 10-26-2013, 07:28 PM
JeepNowski
Wife was feeling down due to noisy kids, elderly parent woes, and general boredom on a do-nothing Saturday so I suggested we load up in the WJ and I took her for a little spin on a local light trail. Plenty of mud, a few rocks and some nasty deep ruts in the road full of red muddy water. The Jeep handled it perfectly and got a little muddy in the process and the wife enjoyed herself and is now a calm mama. LOL She wants to know when we can go back now.
post #25469 of 45178 Old 10-26-2013, 07:30 PM
Hytek
Will do thanks!
Hytek is offline
post #25470 of 45178 Old 10-26-2013, 07:33 PM
JeepNowski
Yeah I should have noted that I've only used these bulbs in one car.....That car being a 2000 Lincoln Town Car which has HORRIBLE headlights to begin with. The brights on her TC aren't as bright as the dims on my WJ and that's WITH the new bulbs. But the diff. between the original bulbs in her car vs the new bulbs was minimal at best. YRMV, if they work for you then great.
wj
