What did you do to your WJ today? - Page 1695 - JeepForum.com
 798Likes
post #25411 of 44816 Old 10-23-2013, 10:33 PM
aralph30
2003 WJ
Originally Posted by PhantomWJ
You keep driving it....
something has to be wrong
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #25412 of 44816 Old 10-24-2013, 04:08 AM
4xTroy
4xTroy's Avatar
Did the axle seal (and bearings) last weekend. Tried to press the bearing and retainer with a hammer. Got the bearing seated, but the race fell apart. Not so lucky with the retainer, ended up having to pay $5 to have someone press it for me. 300 miles on it, and no leaks or issues (that I know of).
I'm starting to hear some rotational friction noises from the front end. Gotta get it up in the air and see if I can figure it out. Hoping it's not the CV, as I don't want to drop money on a new one and I can't afford the u-joint conversion yet. WTF is up with the cost there... I can replace both sides for like $100, but it's like $800 for the conversion?
15mpg down to 11? Wow... something wrong for sure. Last month, I did my plugs, cleaned the IAC and throttle body. Took a few runs for the computer to learn how to idle again, but my mileage went from 15 to almost 17 (100+ miles of highway a day).
4xTroy is offline
post #25413 of 44816 Old 10-24-2013, 06:21 AM
03grndcherokee
2003 WJ
Had to stop at autozone this morning after work for a new battery, just my luck.
Sent from my SPH-L710 using JeepForum
03 Grand Cherokee Laredo 4.0
Video with pics of my old truck.
03grndcherokee is offline
post #25414 of 44816 Old 10-24-2013, 09:07 AM
Galaxie500LTD
Replaced my Grease monkey beaten on, smashed, hammered, impact wrench half on, but just hit the trigger anyway, because it's not my F'n lug nut and I like ruining lug nuts because I'm a knuckle dragging idiot who you were foolish enough hand over the keys to, bad idea designed, filed down (by me) in order to attempt getting them to NOT stick in my 19mm socket, capped crappy factory lug nuts... with THESE!
2001 WJ V8 QuadraDrive Stock
1966 Ford Galaxie 500 LTD, 390 CI (6.4L) V8 4V, two door hard top, black on black
Galaxie500LTD is offline
post #25415 of 44816 Old 10-24-2013, 09:12 AM
Jeeples
Jeeples's Avatar
Fixed my non-functioning turn signals, snagged a relay out of the junkyard for $1 and they work perfectly now. FWIW, my hazards worked just fine, but the signals themselves were dead. I also pulled an ACM and tossed it in to see if that would fix my airbag light, which it didn't. The light shuts off for a second on startup and then comes back on, so I'm going to replace the clock spring and see if that fixes it.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #25416 of 44816 Old 10-24-2013, 10:01 AM
buger561
2003 WJ
Attachment 783442
Where'd you order those from? I replaced mine with ones from AmericanMuscle a year ago and they've started rusting where wrenches/impacts have worn down some of the chrome.
buger561 is offline
post #25417 of 44816 Old 10-24-2013, 10:03 AM
4x4Jeep
just got finished replacing my turn signal switch with this new one i got from rock auto
Build -
SOLD
4x4Jeep is offline
post #25418 of 44816 Old 10-24-2013, 10:25 AM
brouwmat
Originally Posted by troy70
Did the axle seal (and bearings) last weekend. Tried to press the bearing and retainer with a hammer. Got the bearing seated, but the race fell apart. Not so lucky with the retainer, ended up having to pay $5 to have someone press it for me. 300 miles on it, and no leaks or issues (that I know of). I'm starting to hear some rotational friction noises from the front end. Gotta get it up in the air and see if I can figure it out. Hoping it's not the CV, as I don't want to drop money on a new one and I can't afford the u-joint conversion yet. WTF is up with the cost there... I can replace both sides for like $100, but it's like $800 for the conversion? --- 15mpg down to 11? Wow... something wrong for sure. Last month, I did my plugs, cleaned the IAC and throttle body. Took a few runs for the computer to learn how to idle again, but my mileage went from 15 to almost 17 (100+ miles of highway a day).
There are lots of threads on here about rebuilding or swapping from compatible models. You don't have to spend that much. I have the I6 with Selec-Trac and I think I did mine for around $200 (and that was completely rebuilt). You might be looking at more depending on the type of TC and DS you have now.
brouwmat is offline
post #25419 of 44816 Old 10-24-2013, 01:37 PM
Jrboarder27
Replaced fuel filter/regulater and put in A new rugged ridge synthetic air filter. Made a good bit of difference. Next Im going to delete the air intake resonater.
Sent from my Galaxy S4 using JeepForum
Jrboarder27 is offline
post #25420 of 44816 Old 10-24-2013, 01:42 PM
aralph30
2003 WJ
Originally Posted by Jrboarder27
Replaced fuel filter/regulater and put in A new rugged ridge synthetic air filter. Made a good bit of difference. Next Im going to delete the air intake resonater. Sent from my Galaxy S4 using JeepForum
I was going to do my fuel filter. But I'm not capable lol I gotta bring it somewhere. What is deleting the air intake resonater Gonna do for u ?
aralph30 is offline
post #25421 of 44816 Old 10-24-2013, 02:57 PM
Galaxie500LTD
I bought them in person from my local auto parts store up here in Northern Ontario.
They're: Papco Acorn Chrome Wheel nuts 1/2-20 3/4 hex part #558-148
They were $2.50 each up here, but they're one piece and I like them I could not take one more day with those old Chrysler lugs. I plan on never letting a mechanic near them.
Time will tell how they hold up.
post #25422 of 44816 Old 10-24-2013, 03:53 PM
alfaitalia
Rolled over 109,000 miles....not a lot compared to some of you, but getting there. Added about 24,000in the 2 and a half years ive owned her...do a lot of miles in company trucks and a few in the Furhers SLK too.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #25423 of 44816 Old 10-24-2013, 06:09 PM
Hytek
Continued my research for some better tires now that I've determined what I have from my zj won't fit without a bb, which I don't want to do at the moment since it's my dd. Of all the tire sizes in the stickies, I don't see any mention of 255/65-17, which is 30.06" tall. I'm assuming these will fit fine...possibly? Considering the Falken Rocky Mountains.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #25424 of 44816 Old 10-24-2013, 06:16 PM
Jrboarder27
Don't know for sure, I've heard different things. I've heard better throttle response, and better economy. but I've also heard it does nothing. So I figured I'd try and see what happens.
post #25425 of 44816 Old 10-24-2013, 06:18 PM
atvlifestyle
I run the 255/65-17 Rocky Mountains on my WJ. Had them on with stock suspension and just had rubbing that made a easy acess hole to the fog light. Still running the tires with 2.5 springs.
atvlifestyle is offline
wj
Kxf327 , Russ02Overland
