What did you do to your WJ today? - Page 1692 - JeepForum.com
 925Likes
post #25366 of 45356 Old 10-21-2013, 09:12 AM
Trxgedy
I think the hose is missing completely, someone got a pic of it going to the dif?
Trxgedy is offline
post #25367 of 45356 Old 10-21-2013, 09:31 AM
Jeeples
Jeeples's Avatar
You should see what remains of the hose or the nipple it attaches to on top of the differential. Just crawl under the Jeep and look at the front axle from behind the driver's front tire.
BOT:
Found out the ECM on the $900 WJ was DOA, I had it narrowed down to either that or the SKIM. I noticed SKIM light was constantly illuminated and CEL was not on with the igntion on. I also wasn't getting any reading from my fuel level and battery voltage gauges, the other thing was the fuel pump wasn't running either.
I pulled the SKIM apart and noticed the capacitor on the circuit board looked a little discolored and bulgy. Went ahead and replaced it with one from Radio Shack for $1.50, but unfortunately that made no difference with the no start condition.
Swapped out the ECM for the one in my wife's WJ and got my dash to come alive again. Just to double check I put the ECM out of the $900 WJ into my wife's and had a dead dash. Found a used ECM at the local wrecking yard and tossed it in, decided to try starting it and it ran for a few seconds then the SKIM shut it down.
Just need to get the used ECM flashed for the correct VIN and it should be up and running.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #25368 of 45356 Old 10-21-2013, 09:46 AM
JeepJeepMoF04
Originally Posted by alfaitalia View Post
They are MOPAR....but they are the very heavy stainless version, not the feeble aluminium version I have seen on a couple of Wjs that are just to look pretty!
Anyone have a link for these ?
JeepJeepMoF04 is offline
post #25369 of 45356 Old 10-21-2013, 10:04 AM
swkenobi
2003 WJ
Just did front brakes and rotors. I really do hate Chrysler and whoever thought putting the bolts where they are. Simply replacing the pads was easy, getting the rotors off was much more fun. Good news is my son and I got it done and now no more squealing and superb stopping. I think of it as a win.
2003 Grand Cherokee Limited - Mostly Stock
swkenobi is offline
post #25370 of 45356 Old 10-21-2013, 10:44 AM
HiPERnx
Originally Posted by aralph30
do u notice a difference in the way it runs with the better grade gas ?
Not in normal driving conditions , but during Swedish winter when it is -20 *C (-4*F) the 99 octane is a lifesaver.
Gustaf Nilstadius,
Jeep WG -99 v8, see ^ for full info
HiPERnx is offline
post #25371 of 45356 Old 10-21-2013, 10:45 AM
Ikelovey
2015 WK
Originally Posted by aralph30 View Post
Has anyone lost mpg with a budget boost ?
I run 91 and see appreciable better gas mileage than when I run 87.
Probably +2 mpg.
Ikelovey is offline
post #25372 of 45356 Old 10-21-2013, 11:08 AM
TimMcc
Carolina Driveline building some nice shafts. My front CV joint shaft blew up. No more CV joints on my rig.
__________________________
01 Laredo 4.0, 4" RC X Lift, Aussie, JK Rubicons, 32's
TimMcc is offline
post #25373 of 45356 Old 10-21-2013, 11:11 AM
doorjamm
Here ya go. Sorry for the portrait oriented photos, I wasn't thinking ahead
doorjamm is offline
post #25374 of 45356 Old 10-21-2013, 11:22 AM
aralph30
2003 WJ
Originally Posted by Ikelovey
I run 91 and see appreciable better gas mileage than when I run 87. Probably +2 mpg.
is it bad for the truck to use a higher grade gas. When it is supposed to use regular ?
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #25375 of 45356 Old 10-21-2013, 11:43 AM
MattJeep
2003 WJ
No. You just waste money. Higher octane is not higher performance. Higher octane is higher resistance to burn. Keeps high compression engines from igniting the fuel prematurely and detonating.
MattJeep is offline
post #25376 of 45356 Old 10-21-2013, 01:03 PM
cykaaro
I disagree with wasting money. I will run 91 shell for a bit here and there, and been testing mileage vs price. in tracking mileage I typically break even or get better mileage. What I do gain regardless is that the engine runs much better and definitely more responsive. Part of that is supposedly due to it not having ethonal in it.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #25377 of 45356 Old 10-21-2013, 01:41 PM
nmay
Found these on Craigslist, buddy talked em down to 200, was just wondering how much trimming/much I'd have to lift to fit these with no rubbing
http://chicago.craigslist.org/nwc/pts/4129792579.html
nmay is offline
post #25378 of 45356 Old 10-21-2013, 04:19 PM
DarkStarr
2003 WJ
Stock 235/65R17s are a 29" tire. 255/75/R17s are a 32.1" tire. They are also about 3/4 an inch wider.
DarkStarr is offline
post #25379 of 45356 Old 10-21-2013, 05:51 PM
rugsWJ
U think it is worth it ? I have a 2003 jeep grand Cherokee limited I currently get 13.3mpg but idk if ill get the same as u with the +2mpg
Hmm, If you're planning on just doing the intake than I'd say no. If you want to do a full catback exhaust though to really improve air flow than maybe you'll see a drastic difference in mileage.
Follow my build on Instagram ---> @mattruggiero
rugsWJ is offline
post #25380 of 45356 Old 10-21-2013, 07:54 PM
Jayybirdd
How cool it is to get a Rola roof rack for $80
Jayybirdd is offline
wj
4xTroy
