What did you do to your WJ today? - Page 1682 - JeepForum.com
 599Likes
post #25216 of 43875 Old 10-16-2013, 07:40 AM
99WJ539918
Originally Posted by PinePig View Post
Got the front Bushwacker flares on tonight along with some new front tow hooks
I am hoping the rears are less of a PITA than the fronts were....
Looks awesome. I heard they were a real pain to install.
Build Thread
99WJ539918 is online now
post #25217 of 43875 Old 10-16-2013, 08:53 AM
NOTW_WJ
Originally Posted by theksmith View Post
interesting, i recently had to replace my antenna and got a new MS48, i couldn't get it to tune below SWR of 3... but the base on it was different than my old one, cheaper looking. so i ordered a different brand with the same picture as my old one and it also came with the newer style base and wouldn't tune for crap.
this was what my old one looked like:
http://www.amazon.com/Truckspec-30in.../dp/B005UUQ8TM
and this is what all the new ones were coming looking like:
http://www.amazon.com/Solarcon-Tunab.../dp/B005UUPYX8
i returned them both and got a completely different style and it worked out fine (swr of 1.something)
also i think the firestik type ones also tune better when mounted on the corner because they are a top loaded design, i used to have a firefly and was able to get it below 1.
I definitely got the second version you mentioned and wasn't impressed with the plastic looking base(they must have found a cheaper supplier)
What did you end up using after returning the two?
Why did you switch from the firefly if it dialed in so well?
I'm gonna get a meter hooked up and see how it looks but the firefly was second choice, and it looks like I may need to go that route.
NOTW_WJ is offline
post #25218 of 43875 Old 10-16-2013, 10:05 AM
SirSilvia
new fog housings came in finally
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline
post #25219 of 43875 Old 10-16-2013, 10:06 AM
thechainrule
thechainrule is offline
post #25220 of 43875 Old 10-16-2013, 10:09 AM
04beachwheeler
Installed RC quick discos yesterday! Have yet to get my full flex on but it's still early! Will post pics when I find a loading ramp at the back of a Macy's...muhaha!
04 WJ: 4.5' Clayton F, 4" IRO R, IRO adj front control arms, Ruffstuff OTK one ton tie rod, OBA.
04beachwheeler is offline
post #25221 of 43875 Old 10-16-2013, 10:13 AM
jwilliamson1987
Originally Posted by thechainrule View Post
got my stroker motor installed...
It says the video is private... sad day
JW
2004 WJ- Grand Cherokee, Limited, 4.7L V8, Quadra-Trac II, Pewter
Mount Prospect, IL
jwilliamson1987 is offline
post #25222 of 43875 Old 10-16-2013, 10:46 AM
thechainrule
Fixed it. Thanks
post #25223 of 43875 Old 10-16-2013, 02:32 PM
jeepinjeepin
Originally Posted by NOTW_WJ
Sounds like you got it set-up nice now. Do you think it was the whip causing the issues or were you able to pinpoint the culprit? I know of others using 4' firesticks that have been able to get some pretty respectable numbers mounted in the same location/method so I'm hoping for the best.
It had to be the antenna. Whips aren't loaded in any way and thus resonate along their entire length. A top loaded design like the following poster recommends would likely be a better choice, but I didn't have one to try so I went to the roof where I knew I would get results.
i returned them both and got a completely different style and it worked out fine (swr of 1.something) also i think the firestik type ones also tune better when mounted on the corner because they are a top loaded design, i used to have a firefly and was able to get it below 1.
Sub 1:1 SWR? That's impossible.
jeepinjeepin is offline
post #25224 of 43875 Old 10-16-2013, 03:31 PM
Merc1973
Had Viper 20% film installed on the front windows. Matches very well from the outside, but seems slightly darker when sitting inside.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #25225 of 43875 Old 10-16-2013, 06:54 PM
sixmikey9
2003 WJ
I continued to hate my transmission, well, not so much the tranny, but my rebuild job. Still trying to figure out what I did wrong.
sixmikey9 is offline
post #25226 of 43875 Old 10-17-2013, 01:02 AM
cykaaro
Originally Posted by aralph30 View Post
Does anyone have a cb radio with PA system I installed mine. But don't know where to put the external speaker. I can't find a good spot to mount it outside the car.
Have mine mounted under the hood, but it's damn loud even with the hood down.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #25227 of 43875 Old 10-17-2013, 01:09 AM
cykaaro
Originally Posted by 99WJ539918 View Post
I had a productive weekend. I went through 4.5 cans of Krylon Fusion satin black on my WJ. The most time consuming thing was my roof rails. Anyway, I painted my roof rack, cowl, front wiper arms, rear bumper cover, door cladding, both side view mirrors, all five door handles, and the hatch bezel. All I have left to do is the front bumper cover, rear glass hinges, the rear wiper arm, and possibly the fuel door. I want to paint the front grill, can I use the Krylon Fusion on that or should I use plasti-dip? I think it looks a lot better, here's a quick before and after...
If it's the chrome grill, you're better off getting a painted one and swapping it out. Easier to do than doing the chrome one.
cykaaro is offline
post #25228 of 43875 Old 10-17-2013, 06:10 AM
aralph30
2003 WJ
where under the hood do u have it because I don't see it being that loud.
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #25229 of 43875 Old 10-17-2013, 06:13 AM
aralph30
2003 WJ
Got my wheel spacers yesterday. Planning on mounting them td. Any pointers while I'm doing them ?
aralph30 is offline
post #25230 of 43875 Old 10-17-2013, 08:44 AM
brouwmat
Use Loc-tite on the hub threads. Tighten them down well.
brouwmat is offline
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
GhostJeepWJ , gscouten , UFONT1
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 11 02-09-2017 05:03 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
