What did you do to your WJ today? - Page 1678 - JeepForum.com
 1093Likes
post #25156 of 45729 Old 10-12-2013, 05:14 PM
wjidaho
Just waxed her before hunting again tomorrow
My build thread
wjidaho is offline
post #25157 of 45729 Old 10-12-2013, 06:11 PM
Trxgedy
Did my jeep emblem today, and touched up the cladding since it was looking pretty bad. I got a random idea, not sure if itll work since ive never seen anyone ever mention it. Ill try it out and share once I get paid.
Edit: I also did my wiper arms as they were getting pretty bad too, forgot to take pics if them, they look so much better
Trxgedy is offline
post #25158 of 45729 Old 10-12-2013, 07:56 PM
Timbo24
Originally Posted by jziegler
Reflashed pcm.
Why did you have to do that?
Timbo24 is offline
post #25159 of 45729 Old 10-13-2013, 12:36 AM
Trxgedy
Soo I am sitting at work like I always do at night just looking for crap to do to the WJ and just decided I am going to do the dash lights green, this is the right bulb right? And since they come in pairs I need 5 pairs, 5 bulbs in the instrument cluster and 4 for the heat/ac controls, and ill have a spare bulb? Just wanna make sure before buy them.
http://www.vleds.com/bulb/74-led/gre...74-1-pair.html
Trxgedy is offline
post #25160 of 45729 Old 10-13-2013, 01:51 AM
rdkendrick
2003 WJ
Originally Posted by Trxgedy View Post
Soo I am sitting at work like I always do at night just looking for crap to do to the WJ and just decided I am going to do the dash lights green, this is the right bulb right? And since they come in pairs I need 5 pairs, 5 bulbs in the instrument cluster and 4 for the heat/ac controls, and ill have a spare bulb? Just wanna make sure before buy them. http://www.vleds.com/bulb/74-led/gre...74-1-pair.html
The bulbs in the heater control are soldered in, how are you going to replace those with the wedge? I bought sockets, but haven't done anything with them, yet.
Sent from my iPad using my fingers
rdkendrick is offline
post #25161 of 45729 Old 10-13-2013, 03:26 AM
Trxgedy
I read that the auto heater controls are but if you have the manual ones like me they arent. But I guess there is only one way to find out now, ill have to take it apart and see. Also anyone know what bulbs id use for the evic? Theyre really small. And what about the doors?
Trxgedy is offline
post #25162 of 45729 Old 10-13-2013, 06:54 AM
theksmith
2003 WJ
http://www.wjjeeps.com/lamps/lamps.htm
theksmith is offline
post #25163 of 45729 Old 10-13-2013, 07:54 AM
03grndcherokee
2003 WJ
The manual ones aren't soldered. I switched mine out for LEDs, they just twist out and back in. The LEDs only work one way so you might have to rotate them if they aren't working
03 Grand Cherokee Laredo 4.0
Video with pics of my old truck.
03grndcherokee is offline
post #25164 of 45729 Old 10-13-2013, 11:51 AM
Jeeples
Jeeples's Avatar
Fixed the speaker noise issues we were having in the wife's WJ. Turns out I had some loose connections in the wiring harness I made when I did the install a couple years ago.
Went back soldered everything up this time. Just need to reprogram the steering wheel control adapter and should be good to go.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #25165 of 45729 Old 10-13-2013, 12:45 PM
wjidaho
I cleaned her really good washed and waxed vacuumed and wiped down the inside and even wiped all my trim (cladding) on the outside, she is one clean wj :-D
My build thread
wjidaho is offline
post #25166 of 45729 Old 10-13-2013, 12:53 PM
Thomahawk
2006 XK Commander
Bought a Winter DD/BEATER ZJ so i can be patiance in the search for a perfect low milage 04HO
Buildthread
Thomahawk is online now
post #25167 of 45729 Old 10-13-2013, 01:04 PM
wjidaho
I have to thought about buying a ZJ just to go beat the hell out of it :-D :thumbs up:
My build thread
wjidaho is offline
post #25168 of 45729 Old 10-13-2013, 02:50 PM
MattJeep
2003 WJ
Great idea. That will keep you focused on your goal. I understand, searching for exactly what you want can be exhausting.
MattJeep is offline
post #25169 of 45729 Old 10-13-2013, 05:33 PM
jziegler
trying to figure out slow fan issue.
2002 wj limited 4.7 h.o.265/70/17 hankook dynapro atm 4in rough country lift, adjustible track bar, rough country steering stabilizer.
jziegler is offline
post #25170 of 45729 Old 10-13-2013, 07:04 PM
bgohsman
Finished removing the bearings, races and seals from my surrogate axle assembly. Oddly, the thing that fought me the worst was the pinion seal.
Brandon Gohsman
bgohsman is offline
wj
jamesrw30
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
