What did you do to your WJ today? - Page 1671 - JeepForum.com
 1008Likes
post #25051 of 45549 Old 10-07-2013, 05:27 PM
wjidaho
Got my new cb ready for install, but it's my wife's birthday and I know better to work on the dub how can I mount it on the dash without drilling holes it's a cobra 29, so "full sized"
My build thread
wjidaho is offline
post #25052 of 45549 Old 10-07-2013, 07:37 PM
go-big
Originally Posted by JeepsOLot
Got my RB1 for the WJ and installed it:
Jerry
Nice I just put one of them in mine not long ago I added a Bluetooth to mine for my iPhone
go-big is offline
post #25053 of 45549 Old 10-07-2013, 07:42 PM
aralph30
2003 WJ
I just bought a cb radio from someone on the forum. How r u wiring like what too fuse or battery
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #25054 of 45549 Old 10-07-2013, 08:06 PM
doorjamm
I tapped mine into the radio power so it comes on as an accessory with the ignition
doorjamm is offline
post #25055 of 45549 Old 10-07-2013, 08:28 PM
aralph30
2003 WJ
So than what do u plan to mount it too?
aralph30 is offline
post #25056 of 45549 Old 10-07-2013, 08:57 PM
Highschool_WJ
Well had her in the shop for new ball joints, no time to do it myself with school, picked it up and the abs light came on. Drove it home and checked for loose wires. Found nothing. So I went back and they found a busted wire going to the sensor and denied it all saying they didnt touch the wires. (they had to as one of the retainers is connected to the ball joint bolt, which isnt there anymore) and took it off the lift and gave me back the keys and walked away. Kinda pissed off about it. :/
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #25057 of 45549 Old 10-07-2013, 09:06 PM
MattJeep
2003 WJ
Jerry
Whats up with this? Anyone have a writeup? Does our factory harness plug in? Looks nice.
MattJeep is offline
post #25058 of 45549 Old 10-07-2013, 09:25 PM
rdkendrick
2003 WJ
Got my RB1 for the WJ and installed it: Jerry
If it's not too personal, how much did you pay for it? Did you get the latest DVD for it? AL is the latest. Did you mount the satellite antenna for the GPS? Pretty easy install, all in all.
When I get around making my extender cable, I will put in my Mopar iPod Integration Kit. I am going to see if the box will fit behind the gauge cluster, first, before I make the cable.
Sent from my iPad using my fingers
rdkendrick is offline
post #25059 of 45549 Old 10-07-2013, 09:40 PM
rdkendrick
2003 WJ
Ughhh, in between dropping off the kid to practice. And having to go to the store, I worked on my rock rails. I got them for $200, and the guy told me they only had a little surface rust, but it's a little worse than that. I could turn it up on end and hear stuff falling from one end to the other like a rain stick.
When I finally took the end caps off, this incredible mound of rust and probably sand or dirt came out. Here are the pictures of the piles of "just surface rust" that I have been wire brushing, by hand. I need to get a wire brush wheel for my dremel tool or drill. One rail is worse than the other.
I have been reading about stopping rust, on here, lately. I bought Loctite Extend Rust neutralizer. Then I will prime them. Then paint the rails a hammered silver, and keep the end caps gray. I bought the mounting hardware, because they did not come with it. M8 x 1.25 extruded u-nuts, M8 x 1.25 x 40 bolts and some lock washers.
Looking at the mounting holes on the ends of the rails, it looks like I will need bigger washers, too. Does anyone have a picture or list of what all the mounting hardware consists of? I have most of it, already, I just want to see if I missed anything.
**Edit** never mind, I saw a picture of the bolt on WJJeeps.com and the bolts I ordered a just regular machine bolts without washers. I will have to go buy flat washers to go on them, too.
post #25060 of 45549 Old 10-07-2013, 10:01 PM
Trxgedy
Jerry
Nice I want one of these.
Trxgedy is offline
post #25061 of 45549 Old 10-07-2013, 10:02 PM
wjidaho
I plan on running it off the main fuse box in side my cab with a 10 amp inline fuse and mounting the radio on the dash, I have already made up a bracket so I don't have drill holes into my dash :thumbs up; ad my antenna will be mounted in front off my driver side brush guard, that might change if I end up getting a whip ( I really want to get a whip) I will be doing a write up in my build :-D
My build thread
wjidaho is offline
post #25062 of 45549 Old 10-07-2013, 10:24 PM
SirSilvia
how do you add bluetooth to that?
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline
post #25063 of 45549 Old 10-08-2013, 05:06 AM
JeepsOLot
I got my RB1 for $155 on ePay, but, they said it wouldn't read the Nav disc. It didn't come with a Nav disc, which I'm getting from a person on here, and didn't come with the GPS antenna, which is cheap. I have several ways of getting the DVD reader to read the disc, and I still think it was worth the gamble.
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #25064 of 45549 Old 10-08-2013, 05:32 AM
JeepsOLot
Thanks! If you have an '02-'04 WJ, it's just plug and play. For '99-'01 WJ's, there's an adapter harness you need.
Jerry
post #25065 of 45549 Old 10-08-2013, 08:47 AM
MattJeep
2003 WJ
Very cool, thanks. Wonder if they made a factory radio with the 6 disc built in. My Yukon has that, its super convenient.
MattJeep is offline
wj
HarryH3
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
