What did you do to your WJ today? - Page 1670 - JeepForum.com
 1095Likes
post #25036 of 45730 Old 10-06-2013, 01:54 PM
JeepsOLot
For my wife's WJ, the memory buttons on the door as well as the different fobs control unlocking, both side mirror positions, driver's side seat position, and radio presets for each driver.
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #25037 of 45730 Old 10-06-2013, 02:04 PM
Hytek
Took the dogs for a cruise.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #25038 of 45730 Old 10-06-2013, 05:04 PM
4xTroy
4xTroy's Avatar
Ignition could not be saved? WTF? The ignition cylinder is easy as pie to set to any key you could care to imagine. Just 8 pins to fuss with, not hard to do (just make sure you have plenty of light).
On the fobs, color doesn't matter. The colors are simply to tell them apart for the memory seats and mirrors (I think).
To add a new transponder key, you need 2 working keys. To add a fob, you need 1 key and 1 fob (I think).
4xTroy is offline
post #25039 of 45730 Old 10-06-2013, 05:53 PM
Big_Wall
2010 JK Wrangler
Originally Posted by BigWheel7 View Post
So if I am the only one who drives the WJ would I still need the two different colored fobs or would one color work?
"""If it comes and goes, I would say that you have a short in the wireing for the door. Check your wires, they get brittle and break in the insulation. """
Well could it also be the key itself. The reason I ask is because the new key for the outside of the door is like a normal house key and not the transponder key like the ignition is.
You don't need a transponder key for the alarm. I recently had to rewire the door because my key would not turn off the alarm. There is a security alarm key switch on the back of the lock cylinder that you may have to replace. Check the wiring first.
Big_Wall is offline
post #25040 of 45730 Old 10-06-2013, 06:33 PM
BigWheel7
Someone had broken the windows out and tried to steal the WJ (wasn't mine at this time). The ignition cylinder had been torn apart for the fools trying to hot wire it and break it to get it started.
BigWheel7 is offline
post #25041 of 45730 Old 10-06-2013, 06:36 PM
BigWheel7
My only way to unlock my doors at all is the flat house type keys that aren't chip. Then the standard jeep key for the ignition. I did try to trick where you unlock it and wait to make sure the lights on the inside came on and this worked and my alarm hasn't gone off all day.
post #25042 of 45730 Old 10-06-2013, 06:49 PM
Jeeples
Jeeples's Avatar
Spent part of the day at the junkyard. Found a couple of Varilok equipped WJs and contemplated pulling the axles.
Ended up pulling out a cd changer cubby w/lid to replace the standard half height cubby. Also scored a 4 disk cd changer for my SRT4.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #25043 of 45730 Old 10-06-2013, 07:23 PM
Jaspah
I remember reading somewhere that Grand Cherokees are one of the harder vehicles to steal.
Jaspah is offline
post #25044 of 45730 Old 10-06-2013, 08:58 PM
cykaaro
Hit the wreckers yesterday and nothing new in the way of WJ's. Did find a 5.9, so grabbed the hood louvres. Not sure if I'll use or not, but have in case I do. One of the drip trays needs to be repaired, but easy enough to do. Louvres themselves are perfect shape.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #25045 of 45730 Old 10-06-2013, 09:00 PM
bgohsman
Finished painting my surrogate axle assembly with Eastwood's chassis black over the rust encapsulator. Differential carriage removed. Time to remove the [stubborn] pinion nut...master rebuild kit in the wings...
Brandon Gohsman
bgohsman is offline
post #25046 of 45730 Old 10-07-2013, 02:39 PM
go-big
go-big is offline
post #25047 of 45730 Old 10-07-2013, 03:11 PM
Jaysun1994
tucked the tank
Jaysun1994 is offline
post #25048 of 45730 Old 10-07-2013, 03:18 PM
aralph30
2003 WJ
Originally Posted by Jaysun1994
tucked the tank
how did U do tht ?
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #25049 of 45730 Old 10-07-2013, 03:55 PM
Jaysun1994
Originally Posted by aralph30 View Post
how did U do tht ?
followed a write up on mall crawlin i think and winged most of it lol.
edit found the write up http://mallcrawlin.com/forum/showthr...uel-tank-on-WJ
post #25050 of 45730 Old 10-07-2013, 04:42 PM
JeepsOLot
Got my RB1 for the WJ and installed it:
Jerry
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
