What did you do to your WJ today? - Page 1669 - JeepForum.com
 599Likes
post #25021 of 43874 Old 10-05-2013, 07:34 PM
vanillathrilla
Originally Posted by Trxgedy View Post
Tried pm for that gauge cluster, but your inbox is full.
I can't delete any messages and can't re-up my subscription yet.
can you email me at a d a m l y o n -at- cox dot net ?
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #25022 of 43874 Old 10-05-2013, 08:40 PM
Hytek
So pissed right now. Trying to install a hitch and the bolt into the unibody that the gas tank support bar is bolted on just stripped it was rusted so bad. Dammit
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #25023 of 43874 Old 10-05-2013, 10:16 PM
BigWheel7
Bugged Kolak (Nick) long enough and ordered complete new front braking set-up.
BigWheel7 is offline
post #25024 of 43874 Old 10-05-2013, 10:56 PM
SirSilvia
Took another whack at chasing the EVAP leak today. found a couple old rubber connections in the engine bay. need this thing inspected before i get another damn ticket.
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline
post #25025 of 43874 Old 10-05-2013, 11:50 PM
BigWheel7
Have a few questions for anybody in here to answer.
When I bought my WJ it had been a repo and then repaired before it was sold. I know the ignition and the door locks are two different keys because the ignition could not be saved. Last winter I was having problems when I would lock the doors then use the key to unlock the car, it would set the car alarm off. It had gone away and just the last few days has started back up. Anybody have this problem before or know what to look for to fix it.
My second question is on the key fobs for our jeeps, do you have to have one of the black fobs and one of the gray fobs or can you just get whatever fob you want and have them programmed?
Thanks in advance
post #25026 of 43874 Old 10-06-2013, 12:18 AM
SirSilvia
Wj
Thanks in advance
when you unlock with the key, wait till the interior lights come on. then pull the door open. I figured that out since my fob didn't work till recently.
the different colored fobs correspond to the driver 1 and 2. look at your driver door for the see preset buttons. you set seat position 1, then when ever the driver (ie husband or wife) unlock with the matching color on the door. the seat automatically adjusts, and driver two unlocks and the seat moves to position 2.
post #25027 of 43874 Old 10-06-2013, 12:22 AM
SirSilvia
there is a way to program an aftermarket one but would be worth it to get OEM
post #25028 of 43874 Old 10-06-2013, 01:36 AM
Big_Wall
2010 JK Wrangler
Thanks in advance
If it comes and goes, I would say that you have a short in the wireing for the door. Check your wires, they get brittle and break in the insulation.
Big_Wall is offline
post #25029 of 43874 Old 10-06-2013, 04:36 AM
alfaitalia
No to my Jeep but for my Jeep!.....paid my JF subs todays....so me and my Jeep are here for at least another year!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #25030 of 43874 Old 10-06-2013, 09:13 AM
cykaaro
Originally Posted by vanillathrilla View Post
We drove the WJ an hour and a half to the Pick-N-Save and looked at all of the GC's they had. Most everything that we needed was already picked apart, but I did manage to get a gauge cluster from a Limited (the white face gauges) that I'm going to put up for sale since it doesn't seem to mate up perfectly... I think it was from a slightly older WJ; Ours is a 2004, and when I installed it, the air bag light stayed on. Taking reasonable offers if anyone wants it!
Also managed to get one piece of trim to replace the damaged piece on the dash. I was trying to get the wood trim from the nicer interios, but I found out the hard way that the dash apparently has to come apart to get the trim off from above the airbag cover. I thought it just popped in/out. Doesn't someone make decent looking stick-on applications to cover up the trim?
Other than that, I discovered that the dummy outlet in the back doesn't seem to have the harness behind the panel like some apparently do. I didn't pull the whole panel off, but I pried the fake outlet out and there's nothing obvious behind it. Kind of bummed because I wanted to (easily) add an outlet to the back. Ordered LED's for the rear license plate light... Uhhh... I guess that's about it.
Some of the clusters do that depending on what years used. I have an '02 in my '00 which due to slightly different wiring the seatbelt and airbag light are always on. I just black them out. They still work perfectly fine. Using a DRBIII scanner, it even tells there's an issue with the guage lights and what they are, but the system works fine. I find them easier on my eyes at night driving than the black ones is why I switched them.
Wanted to change my trim to the brushed metal, but found the same on the trim. Seems they are put in, and the plastic tabs are melted from the back side of the dash. To pull them off only ruins them. Any good vinyl wrap would work in covering them. It's just choosing what you want to use.
As for the rear outlet, I've read some have the connector, some don't. Just grab the plug harness from one that has it, and then wire it up into one of your existing ones, or run a new line with it's own fuse. Not too hard to do.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #25031 of 43874 Old 10-06-2013, 12:59 PM
BigWheel7
So if I am the only one who drives the WJ would I still need the two different colored fobs or would one color work?
"""If it comes and goes, I would say that you have a short in the wireing for the door. Check your wires, they get brittle and break in the insulation. """
Well could it also be the key itself. The reason I ask is because the new key for the outside of the door is like a normal house key and not the transponder key like the ignition is.
post #25032 of 43874 Old 10-06-2013, 01:05 PM
brouwmat
So if I am the only one who drives the WJ would I still need the two different colored fobs or would one color work? """If it comes and goes, I would say that you have a short in the wireing for the door. Check your wires, they get brittle and break in the insulation. """ Well could it also be the key itself. The reason I ask is because the new key for the outside of the door is like a normal house key and not the transponder key like the ignition is.
You can buy fob casings in whatever color you want and just swap them out. So it is not needed to have a gray and a black one.. that's only to signify what fob you have in your hand.
The transponder is only needed for the ignition and since you said that the doors and ignition were different I don't think it'll matter. I have an extra key that only works the doors too.
brouwmat is offline
post #25033 of 43874 Old 10-06-2013, 01:22 PM
rdkendrick
2003 WJ
You either need a locksmith to change to door to the ignition key, or find out the key code to the door key, buy another ignition cylinder, key it to the door key, and have it programmed to the SKIM. Not sure what would be cheaper. Probably, having two keys :-) I keep a flat non-transponder spare in my pocket, just in case.
Sent from my iPad using my fingers
rdkendrick is offline
post #25034 of 43874 Old 10-06-2013, 01:31 PM
SirSilvia
yeah one color works, just won't have use of the pimpmobile feature
post #25035 of 43874 Old 10-06-2013, 01:32 PM
SirSilvia
Maybe also just buying a whole new set from ebay etc. locks, ignition and keys
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
1999wjlimited , gscouten , jdlpetty
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 11 02-09-2017 05:03 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
