What did you do to your WJ today? - Page 1668 - JeepForum.com
 1012Likes
post #25006 of 45561 Old 10-04-2013, 07:32 PM
rdkendrick
2003 WJ
Originally Posted by Jaketit View Post
I think I'm in the same boat. Doesn't make a sound while going fast. Just when I'm slow in a parking lot up to 20 miles an hour. So big Dave, what does this work entail?
When I drive it slow in a parking lot, turn slowly to the left, it groans as I come to a stop to put it in reverse to back into my parking space. No sound if I turn to the right. Could be my front diff. I really need to change the fluids on front and rear before it gets too cold. TC too.
Sent from my iPad using my fingers
rdkendrick is offline
post #25007 of 45561 Old 10-04-2013, 07:58 PM
akinshake
akinshake's Avatar
Just finished up my BB install and got my satin black moabs on too. Super stoked on how it turned out! Going to the junk yard tomorrow hoping to finish up all of the little broken things inside.
99 4.0 Laredo Selectrac, 6.5" IRO long arms front and rear, 35" KM2, 17" Moab JK wheels,IRO transfer case skid, Clayton D44A truss, 4:56 gears and LSD axle swap.
akinshake is offline
post #25008 of 45561 Old 10-04-2013, 08:07 PM
zakary0811
Replaced that damn crank sensor make sure you have at least 3 feet in extensions a swivel and an 11mm socket. It was pretty easy to do once I got it figured out.
1999 Jeep Grand Cherokee Laredo. JK Takeoffs on 265/70/17 Cooper Discoverer AT3's. 2.5" BB.
zakary0811 is offline
post #25009 of 45561 Old 10-04-2013, 08:18 PM
Jaketit
If its groaning then its definitely your diffs. No biggie just change your diff fluids. Mine is a rattle and from the last person who posted on this said something about front DS. and I'm interested.
Jaketit is offline
post #25010 of 45561 Old 10-04-2013, 09:48 PM
Jeeples
Jeeples's Avatar
Originally Posted by 2ndhandWJman View Post
I washed off a ton of bird poop, they must have been teaching the younger ones how to nail a windshield! Then I went and looked at a '96 Bronco. I'm thinking it would be nice to have a full size SUV that can bolt on a set of 31" tires without having to lift it and trim sheet metal.
Yeah but Ford's TTB front suspension is a nightmare that can't maintain an alignment and eats ball joints. Not to mention the E4OD transmission leaves much to be desired in terms of longevity.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #25011 of 45561 Old 10-04-2013, 10:23 PM
aralph30
2003 WJ
yea me too but I'm really worried. I'm not trying to spend mad $$$ on a fix I hope it is nothing serious maybe something loose
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #25012 of 45561 Old 10-04-2013, 10:32 PM
Highschool_WJ
Ordered a set of kc slimlites to add to the roof of the dub, put vinyl covers on the hids already to add some protection from the crazy cold weather we having coming through the Dakotas. Also reprinted the grill insert and tow hooks yellow to match the light covers
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #25013 of 45561 Old 10-04-2013, 10:34 PM
aralph30
2003 WJ
where did u buy your two hooks I wanna buy a pair for not to much tho I'm on somewhat of a budget rn
aralph30 is offline
post #25014 of 45561 Old 10-04-2013, 10:47 PM
Highschool_WJ
My bad I should've specified a little more, I have d ring shackles on it from fawkes fabrications. They're reasonably priced for how well built they are. These things will rip the unibody apart before they break!
post #25015 of 45561 Old 10-04-2013, 10:53 PM
aralph30
2003 WJ
I paid 125 for them?
aralph30 is offline
post #25016 of 45561 Old 10-05-2013, 08:11 AM
99WJ539918
I'm Ron Burgundy? Ha ha.
I really haven't been around much lately. I've been trying to close on my house. Looking to finally start overhauling the suspension. All 4 front ball joints and tie rod ends are done so far. Next are some control arms. I'm still not sure about what lift I'll be running, but it'll probably be either the Rusty's 2.5"/2.0" or the IRO 3". What control arms does everyone recommend? I don't wheel crazy trails, but if I have to replace all this crap I might as well upgrade. Thanks.
Build Thread
99WJ539918 is offline
post #25017 of 45561 Old 10-05-2013, 11:30 AM
brouwmat
Bought mine on Fleabay for $35. They are the factory ones.
brouwmat is offline
post #25018 of 45561 Old 10-05-2013, 04:40 PM
Hytek
Attempted to put a reese hitch on this morning and getting the rear bumper off was a bit of a pita. Said **** it and towed with the niner.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #25019 of 45561 Old 10-05-2013, 05:55 PM
vanillathrilla
We drove the WJ an hour and a half to the Pick-N-Save and looked at all of the GC's they had. Most everything that we needed was already picked apart, but I did manage to get a gauge cluster from a Limited (the white face gauges) that I'm going to put up for sale since it doesn't seem to mate up perfectly... I think it was from a slightly older WJ; Ours is a 2004, and when I installed it, the air bag light stayed on. Taking reasonable offers if anyone wants it!
Also managed to get one piece of trim to replace the damaged piece on the dash. I was trying to get the wood trim from the nicer interios, but I found out the hard way that the dash apparently has to come apart to get the trim off from above the airbag cover. I thought it just popped in/out. Doesn't someone make decent looking stick-on applications to cover up the trim?
Other than that, I discovered that the dummy outlet in the back doesn't seem to have the harness behind the panel like some apparently do. I didn't pull the whole panel off, but I pried the fake outlet out and there's nothing obvious behind it. Kind of bummed because I wanted to (easily) add an outlet to the back. Ordered LED's for the rear license plate light... Uhhh... I guess that's about it.
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #25020 of 45561 Old 10-05-2013, 06:24 PM
Trxgedy
Tried pm for that gauge cluster, but your inbox is full.
Trxgedy is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
