What did you do to your WJ today? - Page 1665 - JeepForum.com
 826Likes
post #24961 of 45006 Old 10-02-2013, 01:15 AM
alfaitalia
Originally Posted by OffroadOran View Post
Not that hard at all. Just make sure u have the rear on jack stands and remove the rear wheels . Otherwise its just 2 bolts, didnt take long at all
Why? You don't need to remove the wheels or put it on stands. The weight is on the springs not the shocks. I just undid top and bottom bolt with the car stood on the ground, pulled old shock put. Bolted new shock on at top, compressed new shock by hand a bit from the bottom and put bottom bolt in. Torqued up.Five minutes per side tops.
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #24962 of 45006 Old 10-02-2013, 04:40 AM
OffroadOran
We found that taking off the rear wheels and letting the rear axle droop helped fitting the shocks into place much,much easier. But yes, you can just do it on the ground. But for us it make life easier to take off the wheels and let the axle hang a bit. Plus my buddy has a lift in his garage so we put it om that!
04 Steel Blue Pearl laredo WJ 4.0L, NV242 TC, 42RE Trans, Dana 30 & 35C, 3.55 gears: 99% stock.
OffroadOran is offline
post #24963 of 45006 Old 10-02-2013, 06:42 AM
vagov
rear shocks are easy bottom nut is a dummy nut. on mine. no need to counter spin its welded so the bolt comes right out. and if you are replacing stock fronts and dont plan on keeping old i found it easiler to cut away the plastic cover so you can get a hold of the top of shock under wheel wheel with a pair vice grips to keep it from spinning. 15mm deep socket on top and your done.
vagov is offline
post #24964 of 45006 Old 10-02-2013, 09:03 AM
bgohsman
Originally Posted by PHAL23 View Post
I'll try this...and I typically drive with the windows up cause I like the darkness from the tint lol, but it never has smelled of coolant...and wsar10 I'll try and find one of those shops...never heard of it....figured everything should be good cause the PO had the engine rebuilt by a shop and I had the radiator thermostat and cap replaced all when I bought it
Honestly, I've had "mystery" disappearing coolant, at one time or another, in nearly every vehicle I own. I hate that sinking feeling that it could be nothing or everything. lol. If the oil doesn't look like pudding on my dipstick, and steam isn't coming out of the tailpipe, I can usually relax. There's just so many points that can leak. And if it's onto the engine and a small leak, it dries instantly and you can't see jack.
When you do eventually find it, let us know where it was. I'm curious.
Brandon Gohsman
bgohsman is offline
post #24965 of 45006 Old 10-02-2013, 09:55 AM
PHAL23
Originally Posted by bgohsman
Honestly, I've had "mystery" disappearing coolant, at one time or another, in nearly every vehicle I own. I hate that sinking feeling that it could be nothing or everything. lol. If the oil doesn't look like pudding on my dipstick, and steam isn't coming out of the tailpipe, I can usually relax. There's just so many points that can leak. And if it's onto the engine and a small leak, it dries instantly and you can't see jack. When you do eventually find it, let us know where it was. I'm curious.
I'll be sure to let y'all know, it's definitely no leaking and gettin under the carpet, I checked all that...the dipstick is perfect...it not like pudding at all...I'll be changing the oil here soon in about 1500 miles...but the level hasn't changed or anything since I've changed it. I order to UOA kit to get a sample when I change it..we'll see if it's anything, but I don't think so. It's probably gonna be a mystery too.
PHAL23 is offline
post #24966 of 45006 Old 10-02-2013, 11:30 AM
aralph30
2003 WJ
Thinking about putting a PA system in my car. Don't know if I should or shouldn't tho
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #24967 of 45006 Old 10-02-2013, 12:09 PM
wsar10
2003 WJ
your looking for hi potassium in your UOA, maybe calcium. Although allot of oils have calcium in there add-pak.
Well let me re-phrase that HOPEFULLY you DON'T find hi potassium !
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #24968 of 45006 Old 10-02-2013, 01:16 PM
texlurch
Swapped the chain in the transfer case, and replaced some seals. No more leaks or popping in 4WD.
Also did the quick discos on my rear seats so they can be out of the way for camping.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #24969 of 45006 Old 10-02-2013, 03:56 PM
alfaitalia
Wired in a 1000w 230v inverter. Unit hidden behind knee panel below steering wheel. Extra PC cooling fan fitted dues to the relatively enclosed location. Illuminated switch on dash that turns on the inverter via a 100 amp relay. One socket in passenger footwell (see pic below) and one in the back next to the 12v power socket. Powers my wifes hairdryer no probs (well over 1000watts but the nearest thing I had to test it with!)
post #24970 of 45006 Old 10-02-2013, 04:13 PM
atinari
Noticed things are pretty moist down there. Someone want to help out? What could be causing whatever this is and should i address it?
atinari is offline
post #24971 of 45006 Old 10-02-2013, 04:17 PM
brouwmat
Anytime you have a leak it is bad and could potentially be an issue. I would keep a close eye on it. Is it oil?
brouwmat is offline
post #24972 of 45006 Old 10-02-2013, 04:22 PM
BigAl63
Plasti-dipped the driver's side wheels this afternoon after work. Too tired to do the other side, maybe this weekend.
2" BB, 1.25" wheel spacers
BigAl63 is offline
post #24973 of 45006 Old 10-02-2013, 04:31 PM
a77ferrel77
Gave my jeep a little liposuction today, cut out about 4" out of the spare tire area, was not a fun process. Hopefully be able to lift up the fuel tank this weekend.
a77ferrel77 is offline
post #24974 of 45006 Old 10-02-2013, 04:48 PM
atinari
oil or atf im not positive
atinari is offline
post #24975 of 45006 Old 10-02-2013, 05:10 PM
texlurch
Looks like oil, most likely a rear main seal. I would also check the rear corners of the valve covers.... you might get off easy if it's those.
texlurch is offline
wj
Uniblurb
