What did you do to your WJ today? - Page 1661 - JeepForum.com
 1095Likes
post #24901 of 45730 Old 09-30-2013, 09:11 AM
bendafinga
2015 WK
Pulled the carpet out to clean and dry it properly.
bendafinga is offline
post #24902 of 45730 Old 09-30-2013, 09:29 AM
visualj
visualj's Avatar
Changed the plugs and gave it an oil change. Similar look to the plugs as post above but the center post was even or worse with most plugs.
But the thing that helped most was cleaning and resurfacing the headlights. Added .0004 MPG.
Always do what you said you would do drunk. That will teach you to keep your mouth shut. Ernest Hemingway
98 SE 44 Front/Rear geared 4.88 - Ox Locker in the rear - Trutrac in the front
35 MT - On board air - In cab winch control
Latest Dent 8/23/2009
Old Guy Jeep Club#1024
visualj is offline
post #24903 of 45730 Old 09-30-2013, 10:31 AM
MichaelS75
Finally fixed my stalling/surging problem. Threw a p1296 and p0121 code which pointed towards the map sensor. Discovered the connector was broken causing the wires to periodically touch which threw off the voltage. I decided to replace the crappy wiring to that sensor and fixed the harness. After taping the sh*t out of the connector and sensor all is well so far.
MichaelS75 is offline
post #24904 of 45730 Old 09-30-2013, 10:33 AM
Uniblurb
Uniblurb's Avatar
Originally Posted by Ravie View Post
Yeah...freezing them of course contracts the ball joint while heat expands the hub bracket holes...
The first time I did ball joints it took a VERY long cheater bar and a lot of swearing. This time using heat I didn't have to use anything bigger than a breaker bar. I did have air(borrowed a compressor) but only used it a couple of times just to speed things up.
I used Raybestos ball joints. No opinion other than they're inexpensive and a brand I recognize.
I'm in KS, so not far out of the rust zone...originally from MN. The Jeep was bought in Nebraska originally. I didn't have to useany heat on those. Just a breaker bar and a grunt. I put a bit of anti-seize on them for install.
This was the 1st time for me in replacing ball joints so gained a lot of experience while info from others here helped a bunch. The huge C-clamp in the kit had such a long threaded shaft I couldn't get anything but a box end wrench on top since don't have a lift installed and didn't feel like dropping the axle. Would have been nice if my ratcheting wrenches would have gone up to the 7/8" size but wouldn't doubt they couldn't take the high torque.
Moog is outsourcing more and more parts and they couldn't even drill/tap the grease fitting hole in the middle of the ball joints. Then followed the directions where I had to put the rubber cover on before pulling it through the top and ended up with about 3/16" of the shaft not covered by the boot. And yeah it's in all the way.
Was kind of worried the hub bearing assembly bolts may back out with anti-seize on all the threads but sure coated the ends of the threads where they rust/seize up. They salt/brine solution the roads around here in Ohia so much it's ridiculous since it eats my Jeeps up while no bolts/nuts are easy!
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #24905 of 45730 Old 09-30-2013, 10:50 AM
surfer4life
Fixed my rear brake light and tail light, and fitted new windscreen washers. First time in 12 months all lights are working and we can wash the windscreen
surfer4life is offline
post #24906 of 45730 Old 09-30-2013, 12:57 PM
vanillathrilla
Trying to diagnose hard starts in the new WJ... I had her (over the phone) prime the fuel pump multiple times before actually attempting to start it, and it doesn't seem to be helping. Supposedly the little dealership replaced the fuel pump right before we bought it. Any ideas what else to look for? I can't help but to be a little pissed off.
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #24907 of 45730 Old 09-30-2013, 01:17 PM
Hytek
Ordered her a Reese hitch and Curt harness. I wanted to stay as close to OEM look as I could without paying OEM prices.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #24908 of 45730 Old 09-30-2013, 02:31 PM
jpat30
We celebrated her first year with me by turning 100K. In honor of this momentous occasion, I gave her a bath and let her sleep in the garage.
-Carpe Diem Phil 1:20
jpat30 is offline
post #24909 of 45730 Old 09-30-2013, 02:55 PM
gcjeeping
gcjeeping's Avatar
Went with a small group on here for a Nor Cal coastal beach run this weekend. Ran a few logging roads and mountain trails along the way to visit beaches. Also ran some roads through the Giant Redwoods.
_____________
gcjeeping is online now
post #24910 of 45730 Old 09-30-2013, 03:34 PM
Highschool_WJ
Got a little pissed off, shop I had put my new tires on screwed up the tire balance and then destroyed two lug nuts (they spin freely) when they fixed the tire balance. They failed to tell me this had happened either. I'm glad I checked them! :/
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #24911 of 45730 Old 09-30-2013, 03:49 PM
brouwmat
How would you fix a lug nut that spun freely after it was installed?
brouwmat is offline
post #24912 of 45730 Old 09-30-2013, 05:08 PM
MattJeep
2003 WJ
Wow. Real nice. Make sure you get what you deserve when you go back.
MattJeep is offline
post #24913 of 45730 Old 09-30-2013, 05:14 PM
Highschool_WJ
I have no idea how they will fix it. But they said they would fix it for free
post #24914 of 45730 Old 09-30-2013, 05:34 PM
rdkendrick
2003 WJ
Originally Posted by wsar10 View Post
the issue is you may be setting yourself up for a new axle period, the seal goes bad the bearing goes bad and than wears a groove in the axle. At that point you HAVE to change the axle. Money may be tight, but I would rather come up with less than $50 now vs a few hundred later.
That's what happened to me. I bought it from the PO, probably with the bearing leaking, but I didn't notice it. I drove it and it just started to get louder. Took it to Midas and they replaced the rear right bearing. I drove it for another 5-6 months, maybe and it started making noise again. Took it back and the told me that the bearing had worn a groove into the axle and that I would need another axle.
They found a used axle to replace it with and put new bearings and seals in it. It has been quiet ever since. I am not sure if the used axle was the same part# or not. I remember the Midas mechanic saying something about this axle being the best one for it. (I wasn't really paying much attention) but I guess I could crawl under and see what the tag says.
Sent from my iPad using my fingers
rdkendrick is offline
post #24915 of 45730 Old 09-30-2013, 05:35 PM
rdkendrick
2003 WJ
Originally Posted by Kilopup View Post
Seized the engine...dang!
OOPS! Forget to change or add oil, or hydro-lock?
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
