What did you do to your WJ today? - Page 1653 - JeepForum.com
 1086Likes
post #24781 of 45717 Old 09-26-2013, 08:54 AM
aralph30
2003 WJ
Originally Posted by tim0
Check your air filter. Check for codes. Check for a lead weight on the gas pedal.
I bought a k&n air filter when I bought the car
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #24782 of 45717 Old 09-26-2013, 08:55 AM
aralph30
2003 WJ
and How do I check codes ?
aralph30 is offline
post #24783 of 45717 Old 09-26-2013, 09:08 AM
tim0
Easiest way is to use a scan tool. If you don't have one, any autoparts store will check for codes for free. Your owners manual will explain how to check them with out the scan tool.
4.0 I6, 265/75/16 Treadwright Claws, IRO adjustable track bar, 4" RCX short arm lift with Adjustable control arms all around.
tim0 is offline
post #24784 of 45717 Old 09-26-2013, 09:22 AM
gcjeeping
gcjeeping's Avatar
Easiest way is to use your key. Turn the ignition switch to on-off-on-off-on without starting it. The odometer will show codes or done if not any.
_____________
gcjeeping is offline
post #24785 of 45717 Old 09-26-2013, 09:58 AM
theksmith
2003 WJ
+1 for the key trick. it will even show pending codes (when the MIL is not on yet)... some of the cheap scan tools don't.
theksmith is offline
post #24786 of 45717 Old 09-26-2013, 10:19 AM
aralph30
2003 WJ
i tried it it didn't work
aralph30 is offline
post #24787 of 45717 Old 09-26-2013, 10:31 AM
Jaketit
You have to do it 3 times in a row
Jaketit is offline
post #24788 of 45717 Old 09-26-2013, 10:39 AM
aralph30
2003 WJ
so do I turn the key till my dash lights up?
aralph30 is offline
post #24789 of 45717 Old 09-26-2013, 10:49 AM
dadamets
Originally Posted by dadamets View Post
Went to replace my Map Sensor today and all I can say is that it was a disaster! So upon removal of the Coolant Temp Sensor plug, I heard a crack and the I look down and the sensor is cracked at the base....now isnt that special.....
So I move on to the map sensor and on a 4.7L it is tucked between the alternator and the AC compressor so getting to the 2 bolts is not easy. Well anyways, I dropped one of the 2 bolts and I cannot find it after 45 minutes of looking.........
Any ideas as to what the part number may be for the bolt?
All I have been able to come up with is this...
http://www.factorychryslerparts.com/.../06101946.html
Any help would be appreciated.
(I already tried to get a bolt at Menards and according to their little display it is a 4mm bolt, which I purchased and cant get it started. The new bolt is a straight cut at the end and the factory bolt is kind of conical at the end)
I have a 2002 Overland with the 4.7L
Tried the dealer for the bolts and that was a no go....... Said it would take 3-4 days to get some from a central warehouse.
Ended up going to a local u pull it place and got them.
dadamets is offline
post #24790 of 45717 Old 09-26-2013, 11:47 AM
Jaketit
Yes three times then look at your odometer.
Jaketit is offline
post #24791 of 45717 Old 09-26-2013, 11:48 AM
roadcrew
Read here. All the info you need.
http://www.wjjeeps.com/faultcodes.htm
roadcrew is offline
post #24792 of 45717 Old 09-26-2013, 12:52 PM
Hytek
I'm starting to think my 4.7 doesn't like synthetic oil. These last few days it's been chilly in the morning and it's noisier than usual. Reminds me of the rattle sound the 4.0 in my old XJ used to make lol.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #24793 of 45717 Old 09-26-2013, 01:46 PM
Geo-Nemesis
suffered for not having vari-locks
'02 Black Overland H.O. V8
Geo-Nemesis is offline
post #24794 of 45717 Old 09-26-2013, 01:52 PM
wsar10
2003 WJ
what oil is it ?
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #24795 of 45717 Old 09-26-2013, 02:01 PM
JimmydaGreek
2015 JK Wrangler
I'm on Mobil 1 fully syn on my 4.7 and no probs.
2015 JK Unlimited Rubicon Loaded and Modded
JimmydaGreek is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
