What did you do to your WJ today? - Page 1652 - JeepForum.com
 556Likes
post #24766 of 43587 Old 09-25-2013, 08:22 PM
rdkendrick
2003 WJ
Originally Posted by imaguy3 View Post
If you have the dual climate control and have it on automatic sometimes it will kick on, especially if conditions are right for the windshield to fog... The AC helps draw moisture from the air to prevent that.
I never use automatic. In the fall, it switches from defrost to front vents. Heat in the morning to air in the afternoon. Sometimes, in the morning, with the heat on, and the switch on defrost, I look down and see the AC light has turned on.
Sent from my iPad using my fingers
rdkendrick is offline
post #24767 of 43587 Old 09-25-2013, 08:23 PM
doorjamm
Originally Posted by dadamets
Thanks for the part#
I just did a search and the only jeep this part number is showing is for the compass and patriot?
I just want to make sure I get the right one.
Well it shows it works on multiple dodge 4.7 v8s. It's very cheap, so you could just take a shot and let us know. Or you could always go to a junker and just pick one off for free except for the gas to get there.
doorjamm is offline
post #24768 of 43587 Old 09-25-2013, 08:28 PM
dadamets
OK Thanks!
dadamets is offline
post #24769 of 43587 Old 09-25-2013, 10:23 PM
Hytek
Originally Posted by wjidaho View Post
X2 a couple weeks ago I had a guy in a Jk flip me off when waved to him :-( that's okay since I think he was a mall crawler ;-)
Same thing out here. I don't think those pretty little things will ever see mud.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
post #24770 of 43587 Old 09-25-2013, 10:27 PM
Hytek
I have dual climate but never leave it on auto. But that brings up a good point, maybe it thinks it's in auto mode. Think I'll pull it apart and clean the connections in back this weekend.
Hytek is offline
post #24771 of 43587 Old 09-25-2013, 10:27 PM
wjidaho
Right lol that's ok if they want a cookie cutter rig. I like the fact that most have to build tire carries or bumpers since their is not a lot options in the market for the wjs :-D
My build thread
wjidaho is offline
post #24772 of 43587 Old 09-25-2013, 11:27 PM
mdrum93
truuuuuu thatttt, we are forced to be creative and build custom stuff!! Built not bought!!
Bumper Thread
mdrum93 is offline
post #24773 of 43587 Old 09-26-2013, 12:06 AM
Timbo24
Bought a 40 inch dual row led light bar, some hella 40a waterproof relays and a 15a wireless relay for my switch
Timbo24 is offline
post #24774 of 43587 Old 09-26-2013, 12:18 AM
wjidaho
:thumbs up: bro I want to see how bright that is I am thinking about doing a led bar when I finally do my bumper, I finally found a fab guy that dose great work. And he is local too :-D thinking tube bumpers with a wench mount.
My build thread
wjidaho is offline
post #24775 of 43587 Old 09-26-2013, 12:27 AM
Timbo24
Sounds good man. And you should pm his number. I might need a rear tire carrier
Timbo24 is offline
post #24776 of 43587 Old 09-26-2013, 06:39 AM
patnewk76
returning window parts I got today in the mail. using the old motors and they don't match up to the new gears. frustrating
91 YJ "Tonka" 4.0/ax15, stock/stock axles,
99 WJ 4.0 work in progress
patnewk76 is offline
post #24777 of 43587 Old 09-26-2013, 07:02 AM
bgohsman
I actually disconnected my AC for this reason. However, in my case, the AC has never worked since I've owned my Jeep and causes a lovely squealing sound with the serpentine belt when it tries to engage. I can have the temp set on 85 and it may turn on. I'd like to just replace that whole dual climate control with a basic temperature selector and fan switch with automatic nothing.
Brandon Gohsman
bgohsman is offline
post #24778 of 43587 Old 09-26-2013, 08:37 AM
theksmith
2003 WJ
finally got around to changing the diff fluid in both axles, JK drain plugs make it too easy
theksmith is offline
post #24779 of 43587 Old 09-26-2013, 09:29 AM
aralph30
2003 WJ
Hey guys if used to get around 15 mpg with my v8 but recently it's dropped like crazy to around 11.5-12.5 mpg any ideas on what may be causing this ? I'm almost due for an oil change and I was thinking about changing the Peale plugs too. Please let me know if anyone has had problems like this recently !!
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #24780 of 43587 Old 09-26-2013, 09:51 AM
tim0
Check your air filter. Check for codes. Check for a lead weight on the gas pedal.
4.0 I6, 265/75/16 Treadwright Claws, IRO adjustable track bar, 4" RCX short arm lift with Adjustable control arms all around.
tim0 is offline
RonSwanson
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
