What did you do to your WJ today? - Page 1650 - JeepForum.com
 925Likes
post #24736 of 45355 Old 09-25-2013, 01:56 AM
cykaaro
Got the 1st line one from NAPA last christmas when Mine was toasted when the steering pump went. Try not to get 2nd line for most things. Prefer the premium quality when I'm able to. Had a gator one on my ZJ which I liked.
Just drove mine hopped up on benylin and advil. God I hate being sick.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #24737 of 45355 Old 09-25-2013, 07:09 AM
brouwmat
Changed the drivers side upper CA bushing over the weekend and put longer bolts in my upper rear CA spacer. Also, changed the Diff Fluid front and rear w/ Royal Purple @$22 a bottle. That added up fast! :-) Trying to get things finished prior to winter.
brouwmat is offline
post #24738 of 45355 Old 09-25-2013, 08:30 AM
bgohsman
Originally Posted by bushido7seven View Post
Took 6 six hours to finish this. Only because there was rust spots.
So, is that Plasti-Dip? Or just a kind of matt, satin paint? Either way, looks fantastic!
Brandon Gohsman
bgohsman is offline
post #24739 of 45355 Old 09-25-2013, 08:44 AM
bushido7seven
Plasti-dip. And thanks
bushido7seven is offline
post #24740 of 45355 Old 09-25-2013, 08:57 AM
Locutus
2014 WK
replaced grey center console with a black one
Locutus is offline
post #24741 of 45355 Old 09-25-2013, 08:58 AM
BigDaveWJ
Did you check the Fan relay for your electric fan?
Originally Posted by 03azwj View Post
Well after a little over a year its starting to overheat. I just replaced fan relay and thermostat and it will still climb to 260 when idling and no tow package.
Is the electric fan running at temperature? The relay failing is very common on these.
BigDaveWJ is offline
post #24742 of 45355 Old 09-25-2013, 09:05 AM
hammered1
Originally Posted by little_Jeep View Post
I just put a battery in mine a few days ago as well... I was shocked at how much the price of a battery had increased.
i paid 205.00 for mine, which is a lot to me for a battery, but it was better than paying for the Odyssey name.
hammered1 is offline
post #24743 of 45355 Old 09-25-2013, 09:08 AM
bgohsman
Wj
Ordered a master overhaul kit for my Dana 30 diff. USA Standard Gear kit from RockAuto.
http://www.usastandardgear.com/Produ...px?ProdID=6591
Downloaded the installation procedure PDF. Should be interesting...
Brandon Gohsman
bgohsman is offline
post #24744 of 45355 Old 09-25-2013, 12:09 PM
steveandhiswj
FedEx just came with my iro 3" lift took 3 weeks but its finally here. Can't wait for this weekend to install it if anyone has any tips before I start that would be great thanks.
steveandhiswj is offline
post #24745 of 45355 Old 09-25-2013, 01:03 PM
03azwj
2003 WJ
Well it normally stays around 210 or lower. My new water pump should be here today so ill replace that and see what happens.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #24746 of 45355 Old 09-25-2013, 01:25 PM
liftedWJ03
2003 WJ
I finally got my roof rack on today
03 WJ Laredo 4.0L - Fawkes shackle tabs, Addco rear sway bar, double cardon front driveshaft, IRO adjustable short arms, JKS adjustable trackbar, OME 2.5" springs w/ 1in bb, Bilsteins, 265/75/16 Goodyear Wrangler Duratracs on Jegs d-windows
liftedWJ03 is offline
post #24747 of 45355 Old 09-25-2013, 01:34 PM
Mav-Jason
^^^looks nice, what kind?
Jay.
Black '99 WJ 4.0 Selec-Trac~ OME MDs w/ .75" Spacers, Bilseins, JKS ADJ. TB,
Moog SS, Moog HD TREs/ Sleeves, Ext Rear Links, 16x8 Ion Alloys, 32" BFG Wrangler Authorities
Mav-Jason is offline
post #24748 of 45355 Old 09-25-2013, 01:49 PM
Jaketit
Got the same one. Kinda hard to get used to the look of it. Sometimes I love it and sometimes I just want to rip it of cause I only used it a handful of times. Pretty easy to install though. I coated mine with a few coats of bed liner spray before I threw it up there though. The seam kind off sux. But your rig looks tight man!!
Jaketit is offline
post #24749 of 45355 Old 09-25-2013, 01:52 PM
Linus
Looks like a Rola brand rack, I have the same one. Try putting some silicon around the the joints to keep water out. I could hear water sloshing around in mine whenever I took it off and sometimes it dripped a little rusty water on my Jeep after a wash. I gave up and drilled a few drain holes to let the trapped water out. Then I let it dry and hit it with some black paint. Other then that it's a great roof rack.
04 WJ - 4.0L and Selec-Trac
BDS 2", 3/4" spacers, Bilstein 5100, and 31" General Grabber AT2's
Linus is offline
post #24750 of 45355 Old 09-25-2013, 02:04 PM
JimmydaGreek
2015 JK Wrangler
Cant' tell from the front pic but did you also put the 18" extension on it?
2015 JK Unlimited Rubicon Loaded and Modded
JimmydaGreek is offline
wj
Redjeepwj
