What did you do to your WJ today? - Page 1646 - JeepForum.com
 559Likes
post #24676 of 43595 Old 09-22-2013, 10:42 AM
bgohsman
Plasti-Dipped my aluminum wheels. They were oyster shelled and the clear coat was stained in several places. Even after power washing them, cleaning them by hand and de-greasing them with Zylene, they still looked like crap. I'm amazingly happy with how they turned out. First time I've used Plast-Dip.
Brandon Gohsman
bgohsman is offline
post #24677 of 43595 Old 09-22-2013, 10:56 AM
Jeeples
Jeeples's Avatar
Hammer on wheel weights FTL. Should have had a local shop replace them with stick on weights before you dipped them.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #24678 of 43595 Old 09-22-2013, 11:29 AM
cykaaro
Originally Posted by wjidaho View Post
Headed out to wheel ;-) night wheeling is so fun when you got six kc daylighter's lighting your way :-D
Now change them to run HID's in all of them and see what kind of output you get!
I have 4 sets running now. Quad retro, fogs and the WARN's I changed. Still have my rack lights which will add another 2 sets of HID's but haven't hooked them up at all as really not needed. But will eventually just cause they're there!
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #24679 of 43595 Old 09-22-2013, 11:47 AM
cykaaro
Originally Posted by 03azwj View Post
Well after a little over a year its starting to overheat. I just replaced fan relay and thermostat and it will still climb to 260 when idling and no tow package.
Sounds like something else is going on. Adding another fan will only bandaid the issue. Relay and thermostat are done, so should rule those out as the issue. First question is was the system bled properly. Air trapped can be an issue. Also the waterpump could be an issue itself. This is of course that the fan is ok.
cykaaro is offline
post #24680 of 43595 Old 09-22-2013, 12:34 PM
03azwj
2003 WJ
Well I do know I need to replace the water pump. That will be the first thing...for now. And then I'll go from there.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #24681 of 43595 Old 09-22-2013, 12:43 PM
cykaaro
Once you do make sure you get the air bled out. Hopefully it'll solve the issue.
As for doing anything on mine today, nope. Need to switch out the rear springs but too damn sick. Instead hacking up a lung or two.
cykaaro is offline
post #24682 of 43595 Old 09-22-2013, 12:56 PM
03azwj
2003 WJ
Ok thanks. Rock auto has the pump for 35 or so and says it includes the gasket.
03azwj is offline
post #24683 of 43595 Old 09-22-2013, 01:02 PM
Jaspah
Yep, I had the same problem. Previous owner let them corrode really bad to the point where it wasn't removable.
Picked up a few cans of Plastidip and couldn't be happier.
Jaspah is offline
post #24684 of 43595 Old 09-22-2013, 01:02 PM
Linus
Replaced the transfer case fluid, wish all the maintenance on the WJ was that easy.
04 WJ - 4.0L and Selec-Trac
BDS 2", 3/4" spacers, Bilstein 5100, and 31" General Grabber AT2's
Linus is offline
post #24685 of 43595 Old 09-22-2013, 01:41 PM
zephyr80
Loaded her up to go to the dump today, and it was the first time i got to use the winch!!!
Sent from your back seat!!!
zephyr80 is offline
post #24686 of 43595 Old 09-22-2013, 03:02 PM
flightmedic238
2003 WJ
Originally Posted by BigAl63
Started the bb install. Got the front on and realized I must have some serious sag going on. It's now level with 2" spacers on the front! I don't guess there's any problem leaving it like this is there? Before and after: Thanks to jpat30!
I may do the same to mine. I have the BB in the garage. I'll have to see how mine looks with just the fronts. I don't see an issue leaving it like that. Looks much better!!
flightmedic238 is offline
post #24687 of 43595 Old 09-22-2013, 03:31 PM
bcvetter
Put some mopar hooks on. Took less that 45 mins to do.
bcvetter is offline
post #24688 of 43595 Old 09-22-2013, 05:10 PM
StormChaserTim
Cleaned!
Still didn't come out good, the paint is pretty trashed out. Lots of places where sap and bug guts have ate the paint off. But, all shined up, I don't think it looks bad for an $1800 car.
Tim
2000 Grand Cherokee Limited 2wd, 4.7L V8 - It's blazing fast, blue, and the heap of Jeep.
2002 Dodge Ram Quad Cab 2wd, 4.7L V8 - Hailstoned, windshield cracked, storm chasin' truck. But dependable.
StormChaserTim is offline
post #24689 of 43595 Old 09-22-2013, 05:46 PM
rdkendrick
2003 WJ
Originally Posted by StormChaserTim View Post
Cleaned! Still didn't come out good, the paint is pretty trashed out. Lots of places where sap and bug guts have ate the paint off. But, all shined up, I don't think it looks bad for an $1800 car. Tim
Looks nice and shiny to me.
Sent from my iPad using my fingers
rdkendrick is offline
post #24690 of 43595 Old 09-22-2013, 06:57 PM
Hytek
Oil and filter change for the first time, well first time since I bought it.
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
